Question about Kenmore 16764 Dishwasher
No water going to the top arm of the dishwasher
  • 2,510 Answers
Check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Posted on Apr 02, 2011
Upper spray arm on my Kitchen Aid dishwasher (8573025) doesn't work.
Arm operates(turns) by water pressure. If it does not turn no water is going to the top spray arm. make sure the setting washer is on does not preclude the top spray arm from operating(read manual). If not check arm by spinning by hand to make sure it is free. If arm is free and it still does not turn when DW is running than there is a restriction in the tubing to the upper spray arm or the check ball or solenoid are not operating correctly.
Mar 01, 2012 | Dishwashers
The top rack dishes are not getting clean. the spra arm is clear and the tube supplying water to the arm is clean. the float is also moving freely.
does this have the water conduit tube going up the inside of the rear wall where you can see it,if so,the conduit "horn" where it connects to the tube that feeds water to the upper arm with repeatedly opening and closing this horn wears out and lets water get past here and lowers water pressure to the upper arm
Aug 01, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
The top two water water arms do not spin
These spray arm will only get water several times in the wash and rinse cycle. They do not turn at the same time the lower (bottom large spray arm under the bottom rack).
There is a chamber that diverts water either to the bottom sprayer or to the top sprayers, not to both at the same time.
If your top spray arms never get water, then there must be an issue with that chamber motor to divert the water. A new sump assembly that has all the new parts.
Good luck.
Jul 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
Dish washer problem
check water going into unit. disconnect to make sure there is a strong pressure going through.
check the water valve with a meter if there is continuity the valve is good. if not the valve is bad a no water water will go through. let me know if this helps
Feb 23, 2010 | Dishwashers
Dishes all cloudy and spotty. Maytag Intellisense plus 1996 dishwasher. I have real hard water that leave white calcium build up. I can remove and clean all of the lower spray arms and filter. How do I...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Mar 11, 2009 | Danby 22 in. DDW399 Free-standing...
Bottom rotating arm doesnt spray water but top arm does
i have a similar problem. water is not reaching the bottom spray arm. there. i have an underwater case for my digital camera, so i'm going to put a torch or 2 in some waterproof bags and remove the bottom spray arm and run the dishwasher to see if there's water coming out of the bottom pipe, if not, i need to try and see if there's a blockage in the system, or a dodgy valve, could be that the soldering's or the control panel's buggered.
Nov 24, 2008 | Siemens 24 in. SE25T250 Free-Standing...
No water from top and bottom arm
I'm not familiar with that exact unit. However, all dishwashers use a solenoid valve and pump to either send the water to the drain or to the arms. If the water drains, the pump is good. Check the solenoid valve. It may be jammed (toothpicks and food particles are wonderful) or burned out. If the valve is good and working, your timer is a suspect.
Jun 01, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwasher
  This dishwasher does not feed water to top and bottom arms at same time.  It starts with bottom and then after awhile it switches to top and then cycles.  If water comes out arms but arms won't turn,  check all holes in arms.  It's the water spraying out these that causes arms to turn.   If arms spin freely by hand,  it's a plugged arm or holes in arm or insufficient water in tank.
  Being that it only sprays 4 inches suggests a water level problem or possible mineral build up restricting flow.
Oct 11, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Top rack arm doesn't spin.
matt, did you get down to the chopper screen? If that screen is clogged the flow to the upper arm will be restricted. Check out the pic, Catriver
Sep 29, 2007 | Kenmore 24 in. 17362 / 17364 / 17369...
Bottom Dishwasher arm not turning
have you seen whether water is pouring out of the bottom supply tube with the lower arm removed? not 100% sure on this model but some units have a half load switch but that should turn off the top one. there may be a blockage in the lower water supply tubeways.
Jun 15, 2007 | Bosch 24 in. SGS43C12 Classixx...
Kenmore 16764 Dishwasher Logo
93 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
