Question about Audiovox Xpress Satellite Radio Receiver with Vehicle Kit
Xm reciever got wet
Not recieveing anything after x-press xm radio reciever got wet, possibly while turned on
  • Audiovox Master
  • 2,794 Answers
That might be a tough one to fix. I know if you have had an account for some time there pretty good about getting you a new radio if you call them up.
Posted on Aug 05, 2008
SOURCE:
Reciever powers up and recieves signal (station and song titles are displayed) but doesn't transmit to car radio either through the assigned fm station or the aux cord.
IF you have a cord plugged into the audio jack, if will TURN OFF your FM transmitter. You have to leave it unplugged for the FM transmitter to work. Go to MENU and make sure your FM station is set and that the FM OUTput signal is turned up. Write back if you need more help.
Thanks,
John
Aug 19, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
We had an xm radio installed in our 2010 prius after we bought it. It was ''satellite ready'' but needed the radio. We signed up for xm radio and tried to get the signal. The radio was tuned to channel...
go to who installed you sat radio have them pull the antenna and receck the the receiver number it sounds like you have the wrong reciever number even one digit off and it will never conect even tho you have preview and sat radio paired with an antenna will recieve preview
Jul 10, 2009 | 2009 Toyota Prius
2006 vw jetta gli sat radio, sirius expired, now want xm
U can't change the provider, the radio's are built to recieve sirius or xm, u can't have both on the same radio.
Jun 13, 2009 | Car Audio & Video
I have clarion xmd1 in my new boat
yes you can hook up xm to it, but you have to have the xm reciever and interface to hook up to it
Mar 14, 2009 | Clarion XMD1-RET CD Player
Recording xm
Press "mode" button so that the reciever is receiving music from satellite signal on the station you want to record. Then press "2Go" button - screen will ask you to press again to confirm - press again, and it will record whatever was being received. It will record over what was already in 2Go. In menu, under "myXm" there are choices to clear the entire memory of recorded music.
Dec 31, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Old xm reciever not working with new car sterio
yes you will have to upgrade to a new reciever , the older sony xm receivers will not work on the newer model sonys
Aug 13, 2008 | Car Audio & Video
XM radio sounds like crap!!!
if the xm and gps antennas are close together this will happen. u will have to move one to the front and the other to the back of the vehicle.
Nov 03, 2007 | Kenwood DNX7100 Car Video Player
Loss of XM signal
The problem is amazingly simple.
The red wire goes to your ignition so it turns the radio off when you power down your car so as not to discharge the battery.
The YELLOW wire is usually your memory and it connects to the power side of your fuse box (anywhere will do as long as it's powered when the car is off completely). Occasionally this wire is blue but it's rare.
This wire draws a tiny little bit of power so your stereo doesn't 'forget' your station settings etc.
BTW Pioneer is one of my favourites :)
Apr 16, 2017 | XM Radio (XMP6000)
Xm radio
Egads, I imagine that the electrical system in your car is not properly shielded. You can attempt to locate the unshielded wires and cover them, shield the XM reciever (the interference is most likely within the reviever, not the antenna), or try repositioning the reciever in your car- unless it's in-dash. If it's in-dash, it may be that some of your audio cables aren't properly shielded also.
May 23, 2007 | XM Radio (XMP6000)
XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
Aug 26, 2006 | Delphi Roady2 SA10085 XM Radio Receiver...
Audiovox Xpress Satellite Radio Receiver with Vehicle Kit Logo
161 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Ekse
Mike Duncan
Mike Duncan
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
