Question about Sylvania GPS
The screen says please point the image's center area correctly when you turn gps on. can this be fixed?
    New Friend:
The screen shows a plus point with this message.Just click the plus symbol.It moves to somewhere else in the screen. Again press the point continuously till the point disappears. Normally six or seven times.Then the system start works.
Posted on Jul 28, 2014
2 Suggested Answers
pabloloco
  • 2335 Answers
SOURCE: GPS operation freeze up
Upgrading the system software of your GPSMAP 545s will most likely fix your freezing up problem.
I hope that helps.
Posted on Jan 31, 2010
Sylvania GPS SGPD432
The centering screen is pretty much useless, that failed to incorporate an escape or exit button, the best way to end the screen is to simply hold down the power off button, then release, this should reset the GPS when you turn it back on it will go back to it's usual startup screen.
Dec 18, 2012 | Sylvania SGPD430 GPS Navigator
It turned on and said touch dot several times now the screen is off center
Turn off Garmin. Pres top left screen and hold. While holding, turn unit on but keep holding corner. Once the black dot shows up again, use the eraser part of a pencil to chase the dot. That would give exact measurements. Your fingers may be wet or too large and are offsetting the screen area readings. Good Luck
Dec 02, 2012 | Garmin Nuvi 1300 GPS Receiver
I have a nuvi765T and when pressing the buttons to align to screen during a start up the buttons where not pressed correctly so now my screen is off centered. How can you reboot the nuvi to get back to...
To get to the calibraition screen, turn the nuvi off. While holding your finger anywhere on the screen, slide the Nuvi power switch to ON - then immediately slide the button to the LOCK position. Do not lift your finger from the screen UNTIL you see the calibration screen (about 15 to 20 seconds).
Use a pencil or other narrow tipped device to touch the calibration points on the screen instead of your fingers for an accurate calibration.
Please rate this reply if found to be helpful - good luck!
Jun 25, 2010 | Garmin nuvi 765T GPS Receiver
Only see half the screen - other half blank
Anytime you have a distortion in the image on the screen, this can NOT be reolved with a reset. You have a bad LCD module. Take a look at the pictures on this page and see if one is like the problem you are having.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
May 03, 2010 | Garmin nuvi 350 GPS Receiver
My Hitachi P50S601 has develpoped both sides to be brighter than the center. It is very noticable on a full screen that is white or light in color. Snow sports or hockey games it is very noticable. Tried...
Sounds like screen burn in. Does the center area fit for a 4x3 screen image, and the 2 ends would be the 16x9 image? I've heard of software programs that will age the uneven areas. Do an internet search.
Apr 23, 2010 | Hitachi 55HDS69 55 in. Plasma Television
When we zoom in we dont see depth i certain areas; but only grey colour. What are we doing wrong?
The image on my fish finder has a ghost like worm going across the screen. It doesn't read structure at all but will give you the depth. The arrow is pointing forward and I was told to point it in. I would think it would at least still have a picture when the boat is stopped. Any advice?
Jul 07, 2009 | Navman Trackfish 6600 GPS Receiver
Curved/warped and completely out of convergence Image
Sounds like you need the convergence amplifiers replaced. Cost approx. $300.00 for expert to repair.
Jun 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I hope that helps.
May 31, 2009 | Garmin GPSMAP 545s GPS Receiver
Color on screen is not uniform
get a degaussing coil. crt magnatized..or worst shadow mask broken loose inside crt.  to ck turn on hit crt with open palm. if colors move bad bad.
Nov 12, 2008 | Sanyo DS27800 27" TV
Faint screen image
when you first power on using lower right (power) button, wait 6 seconds for the intro screen to finish. The upper left (up) button increases screen contrast. Hold this one down for a few seconds and the screen should darken. The middle left (down) button decreases contrast.
If this doesn't work, try turning off by holding the power button.
Hold down upper left AND upper right while turning unit on. This initiates diagnostic mode and contrast is darker by default. Bottom of screen is a button test area which darkens a symbol for each successful button press. Use it to diagnose a button problem. Turn off power and on again to leave diagnostic mode.
I wish you success playing with the Etrex.
Dec 07, 2007 | Garmin eTrex GPS Receiver
GPS Logo
1,759 people viewed this question
Top Sylvania GPS Experts
Martin Murray
k24674
Tom Chichester
Are you a Sylvania GPS Expert? Answer questions, earn points and help others
