Question about Minolta Office Equipment & Supplies
Minolta magicolor 7300 message "print unit
Minolta magicolor 7300 message "print unit end" add CMY have replaced all toner and still get the message and printer will not print
  • Minolta Master
  • 6,168 Answers
Print head is passed its life which is the LASER get a new one.
Posted on Nov 22, 2015
SOURCE: cant replace a toner cartridge
It's done via the printers internal menu system:
On your Menu Select button press the arrow down once, then press the right or left arrow until it displays Menu Engine, then press down arrow again, then arrow right or left until it displays Engine Replace Toner (not Engine change toner SZ), then arrow down again, then arrow right/left till it shows the toner color you need to change, then hit the Menu Select button in the middle. The cartridges rotate until the one you selected appears, open the door and voila!
Posted on Jun 18, 2008
osiriscompu
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
thaurfen
  • 623 Answers
SOURCE: Konica Minolta magicolor 5440 DL
See if your printer has a clean print cartridges option. If running this a couple of times does not get ink on the page, you might have to clean nozzle manually
Posted on Aug 14, 2008
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
  • 97 Answers
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
The fuser temperature is too high. There is probably some residue from the transparency left on the thermister or the thermister went faulty that causes a wrong reading. The only solution would be to have the printer serviced.
Posted on Aug 05, 2009
Konica Minolta Unit A-1 empty
Yes they are the Image unit, replace the one required, they are not toner.
May 19, 2014 | Konica Minolta Office Equipment & Supplies
Magicolor 7300 print window says Ink/toner waste bin full! but it's new
The clear section of the waste toner box where that goes inside the machine check that area sensor located there might have toner on it so the printer thinks the waste toner box is full
Apr 16, 2012 | Minolta magicolor 7300 Laser Printer
All toner cart's replaced, new toner heads about 1000 pages ago, new waste tray. Printing colors ok but anything with black in it comes out blotchy or faded.
(1) If it takes developer as well as toner you will need to change the black developer.
(2) Also check the voltage is correct
(3) check that the toner path is not blocked
lets know how you get on
Feb 23, 2010 | Minolta magicolor 7300 Laser Printer
Color line along side of copies; doesn't always print; error message keeps blinking (no manual),
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
May 27, 2009 | Konica Minolta magicolor 2400 Laser...
Magicolor 7300 printing everything pink
hi
resetr youor printer settings.
change fuser assembly.
then try it.
Apr 02, 2008 | Konica Minolta magicolor 7450 Laser...
Minolta 7300 - tearing through consumables
I've had the same issue with this printer. Are you using Minolta own brand cartridges? You should be.
It sounds like it is wasting a lot of toner. You'll need an engineer to check the drum mechanism.
Jan 22, 2008 | Minolta magicolor 7300 Laser Printer
Streaks on printed page
You need to clean the printer. See your manual for instructions. It is probably dust on the laser lens
Jun 03, 2007 | Konica Minolta magicolor 2400 Laser...
57 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
