Question about Keurig Platinum B70 Coffee Maker
My Keurig B77 keeps leaking on the counter at different random times
  • 60 Answers
SOURCE: my b77 keurig coffee maker keeps shutting off
Call keurig 1800 cup brew
Posted on Mar 23, 2010
  • 8 Answers
SOURCE: I am boxing up my Keurig select b77 to move.how do
You cannot without fooling the "water out" sensor... to do that you need to make sure the float is up... and even then... you really would have to take the bottom metal pan off... and remove the plastic hose from the bottom of the heater... you will NOT get 100% of the water out... so if you need to ship... you also should stuff paper towel where the K-CUP holder is... snap out the kcup holder and stuff paper tower in there...as there is water in the plastic hose lines in the unit... enough to make a mess...
Posted on May 02, 2010
cmccune04
  • 213 Answers
SOURCE: Keurig coffee machine model B77 operating
http://iwantsweetdeals.com/Keurig-B70-Platinum-Owners-Manual-User-Guide-P1208235.aspx
Posted on Jun 14, 2010
espressonist
  • 1711 Answers
SOURCE: Keurig home model #B77 Will only brew half of
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Posted on Aug 15, 2010
SOURCE: Keurig coffee machine model B77 coffee maker will
Mine will not either. Yesterday it worked just fine now it's as if it is not plugged in. I checked the outlet, it's not that.
Posted on Dec 19, 2010
How do i change the filter on Keurig model B77 ?
Pull Filter from wand and dislodge, replace with new filter.
Oct 27, 2012 | Keurig B70, B77, Platinum, Ultra Coffee...
My keurig is leaking from bottom
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Oct 02, 2011 | Keurig B60 Coffee Maker
When I press the power button on my Keurig b77 it does not power on at all?
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Aug 01, 2011 | Keurig B70 Coffee Maker
Keurig home model #B77 Will only brew half of chosen size
Good luck
Jun 06, 2010 | Keurig B70 Coffee Maker
Need manual for B77 model
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Mar 31, 2010 | Keurig Platinum B70 Coffee Maker
The Water Reservoir is leaking on my keurig coffee maker.
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
Mar 23, 2010 | Keurig B70 Coffee Maker
THE KEURIG UNIT IS LEAKING, APPEARS,O RING AND SPRING NEED TO BE REPLACED .
Mar 04, 2010 | Keurig Elite B40 Coffee Maker
My Keurig B77 will not give a full 11-12 oz on the largest setting. The other settings are a little low as well. Is there an ajustment for the cup size?
These brewers (B77, usually from Costco) are defective & Keurig is replacing them with new units @ no cost. Just call the toll free # (866-901-2739) & they will ship out a replacement in 3 to 10 business days. I own (2) of these & they have both been replaced.
Feb 08, 2010 | Keurig Platinum B70 Coffee Maker
Our Keurig Select B77 brewer turns itself off after less than a minute of being on. "Menu" is not appearing at bottom of display screen (can't check auto on/off function -- although we never did "set...
Feb 05, 2010 | Keurig Coffee Makers & Espresso Machines
Keurig Platinum B70 Coffee Maker Logo
175 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
