Question about Dryers
Dryer will heat for a little while then, no heat. If I unplug dryer and plug it back in it works for a short time.
  • 4,340 Answers
Check for proper air flow, it sounds like you may be tripping a thermal limiter. Pull the hose off of the back of the machine, turn it on and form an opinion about air flow,....hook back up, turn machine on again, go outside and feel the air from the exit port of the building,, if restricted, find and resolve the restriction.
A safety issue is PLASTIC hoses, not legal although still sold. Get the metal version of the flex hose and use that....
Also, look for folded/collapsed discharge hose, very common issue, that stops air flow, and trips thermal limiter (which auto resets at lower temp).
Posted on Apr 02, 2011
Hi just removed my dryer to clean, and had to pull out the dryer a little to pull plug. I then heard a spark tried to start dryer again and nothing on the display panel?
Musta flipped the breaker check the power is what i would do and find the short check the prongs of the power cord unplugged against the frame of the dryer. if get a reading check heating element dryers only require 120 volts to run but need 240 for heat if it uses electric elements. Me doing various checks on dryer
Dec 31, 2016 | Dryers
Our dryer wont start and the outlet doesnt give us power. The circuit breaker works until we plug the dryer in. Please help
most likely the heating element is shorting out or a wire is touching metal in the dryer or you have a problem with the house electrical,unplug it,pull it out and remove the vent line and the back panel,first check the connections where the cord connects to the dryer and make sure that's ok.if that looks fine go to the heating element connections down on the bottom right hand side,pull off the wires going to the element,check the element with a meter or make sure the wires aren't touching anything and plug it back in,if the fuse doesn't pop change out the heater,if it does pop again call an electrician to check the house circuit or and go through the dryer to see if any of the wires are shorting out,
Sep 22, 2011 | Whirlpool LER4634J Electric Dryer
I have a Bosch nextt 500 series dryer and after 2 years of use the problem I have is the heat will shut off and the dryer will keep running and I have to press the reset button on the backside of the dryer
Open the front panel, remove heat exchanger and clean. also clean out lint tray. this might help a little. Now lets check if the thermal sensor or heating element needs to be replaced.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button. To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the thermal sensor. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Feb 01, 2011 | Bosch Axxis WTL 5410 Electric Dryer
I have a Bosch WTL5410 dryer, which has no heat going to the otherwise functioning tumbler. Do you know where I could purchase another heating element and where I can get instructions regarding the...
Open front panel, remove heat exchanger and clean.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the switch. This is your reset button. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Mar 24, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Heat element
if your dryer isn't heating, it's possible that your heating element needs to be replaced.
are either of these pictures of your dryer?
Whirlpool dryer 1
whirlpool dryer 2
May 15, 2009 | Whirlpool WED5521SQ Electric Dryer
Pye300ayw electric dryer dryer starts however it wont heat on an
Hi, unplug the dryer, there is an electric element on the back of the dryer, it should be covered with a removable metal cover, remove this cover and plug it back in turn the dryer on if the element does not heat it is probably bad, also check if there is a broken spot or if the element has shorted out, Hope this helps.
Mar 18, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore dryer
IF THE DRYER COMES ON BY ITSELF WHEN THE TIMER IS SET AND THE DOOR IS CLOSED, THE PUSH TO START SWITCH IS SHORTED. THIS WILL CAUSE THE END OF CYCLE SIGNAL TO BUZZ WHEN THE TIMER IS IN THE OFF POSITION(END OF CYCLE).UNPLUG THE DRYER, REMOVE THE BACK PANEL OF THE CONSOLE, AND REMOVE ONE WIRE FROM THE PUSH TO START SWITCH. ISOLATE IT SO IT ISN'T TOUCHING ANYTHING AND PLUG THE DRYER BACK IN. SET THE TIMER AND CLOSE THE DOOR. IF IT DOESN'T START UP OR BUZZ, UNPLUG THE DRYER AND REATTACH THE WIRE. PLUG THE DRYER BACK IN AND SEE IF IT STARTS BY ITSELF. IF IT DOES, THE PUSH TO START SWITCH IS SHORTED AND WILL NEED REPLACED.
Apr 01, 2008 | Kenmore 62602 Electric Dryer
Replaced timer however time does not count down and dryer won't heat up
one thing to check it the voltage coming into the unit make sure you have 220-230 volts at the plug if so you want to open the back little panel where the cord goes in and check your terminal block and cord connection PLEASE unplug b4 you open the panel A dryer will still tmble but wont heat or advance if that leg(110volts) is not there and the other one is
Jan 20, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
