Question about HP Photosmart 3210 Printer
Not printing in color
Does not print greeting cards in color but in gray
    Master:
    Sergeant:
  • 398 Answers
Click on print command, then click onto setup, then click on to properties, then click on color, if the print in greyscale is check, uncheck it. This will eliminate any false commands from the computer. If this does not work I have gone as far as I can go for you.
Posted on Aug 05, 2008
6ya staff
SOURCE:
Printing from coreldraw 5 to zebra p330i
Sounds as though your printer is dirty, there are unfortunately no different color matchin schemes for this particular printer. The printer operates on an RGB interface, even though it prints using YMC. As far as the speckled look, this typically is due to dust during printing.
Aug 08, 2012 | Zebra P330i Thermal Card Printer
I want to ask if there is way to print someting on greeting card, wiyh the canon PC860?
no,
there is no way to print on greeting card.
use century paper to print then make greeting card.
Nov 04, 2011 | Canon PC-860 Black and White Copier
I'm printing Xmas cards on mate greeting card paper. I've used 3 ink cartridges to print 50 cards!!!! Is this normal?
It is possbile, the inks usually last around 250-350 pages but its based at 5% coverage. If you are using a lot of color or doing photos, the coverage will now be closer to 40% thus lowering the # of pages printed.
also, check to see if you can use hi-capacity cartridges, will save you time and money if the machine can use it.
thanks
Nov 22, 2010 | HP Office Equipment & Supplies
How do you remove/clean/replace print head on pixma mp610 BK nozzle blocked.
Try this :
The gray-colored arm (it's not that small) is to the right of the cyan cartridge. It is the arm or extension of the gray-colored hinged cover. Remove all ink cartridges, lift the gray-colored arm up, and pull the print head out. Clean the print head with a cotton ball soaked with water or rubbing alcohol. Dry and re-install the print head.
Jun 16, 2010 | Canon PIXMA MP610 InkJet Printer
Print with single cartrige. I rarely use color. The color cartrige ran dry and nothing will print in b&w until I buy a new color cartrige ( for about $37.50) and install it. HOW DO I BYPASS THIS...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up and prompt you to chose this option, you should be able to tell the printer to print in black .
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | HP Office Equipment & Supplies
My magicard alto prints fine except the color quality is not very great. when i use the color ribbon and print black letters with it the letters come out gray and not black and it has a problem making the...
The printer driver must be set to print text with the K resin panel.
If the text is part of a bitmap image and not a true-type font then it will print from the coloured panels and be dark grey.
To create the correct green on the card you need to change the RGB values so it prints correctly but look wrong on the badge design program. Even different printers print the same colour differently.
Jan 29, 2010 | Magicard Alto Card Printer
I just updated Greeting Card Factory from 7 verson to 8. The first time I tried to print a card, a box popped up from Greeting Card factory saying ''failed to get double sided print options. Print...
I got the same message. I completed the window to set up the printer option and then it printed. But I didn't like the quality. I checked the box that said best but the lettering was grainy looking. Also the print preferences box won't open in my printer's window. I also am not showing the option to reducw size. It is there but only in light gray. I think they have issues to work out with this new program.
Dec 06, 2009 | HP Computers & Internet
When I am making a greeting card and try to print the text the printing is always too light to read.
I FOUND THAT IFI I START WITH CHOOSING THE COLOR AND THEN THE FONTS THE PRINTING IS STRONG COLOR. IF I CHOSE THE LETTERING AND THE SIZE FIRST, THEN THE PRINTED WORK IS UNSATISFACTORY BECAUSE IT IS TOO PALE TO READ.
Jan 26, 2009 | Nova Development Print Artist Version 22...
Printing greetings cards and envelopes
At the moment it is printing both sides of Greetings cards, but this printer appears to be very sensitive with regards to placng card in the exact position in the paper tray.
Why it will not print envelopes without smudging I still don't know, so I shall just have to write address by hand after I place graphic on the envelope
This 5300 was a Christmas gift from my wife and if I could afford to change it I would. The performance is very dissapointing
Kindest Regards
David Gray
Mar 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
