Question about Behringer Audio Players & Recorders
Bass amp speaker
This is a four ten cab the speaker has come apart how can i get a replacement
  • 31 Answers
Just order new drivers ( speakers ) from the driver manufacturer, or any manufacturer as long as the size and ohms are same as original, look at back of speaker on top of magnet end and there's usually the manufacturers name, can probably order new drivers from their website.
Posted on Aug 06, 2008
Does anyone know how i should hook up a pair of peavey sp118 Bxsubs with a pair of peavey pr15 tops and the behringer inuke nu6000 please help
You will require 4 heavy gauge 1/4" speaker cables in order to connect all 4 cabinets to the Behringer power amp. Usually two longer ones from the power amp to the sub woofer cabs. Then two short ones from the second "thru" jack to the upper 15" cabs. Remember the entire audio frequency range is going to all four speakers. Sometimes you will have problems balancing the low frequency levels between all four cabs depending on the loading of each. A more desirable way to do this is with a bi-amped arrangement. This way two seprate amps are used for the subs and 15" cabs and you control them independantly.
Dec 23, 2013 | Music
My amp keep going into protection mode everytime the bass is turned up,it didnt do this before.?
Chances are you have a shorted output or partially / completely blown speaker. Check all speaker output impedances. If one of them is significantly lower, disconnect that speaker/output and try turning the bass up again. If it works fine, trace that wire to the short or blown speaker. If all impedances look ok, or disconnecting that output doesn't help, then it's time to rip the unit apart and diagnose the amp.
Nov 08, 2011 | Car Audio & Video
My 200hd head is not putting out the full 200 watts i have a behringer 8x10 cab and before this head used to power this cab fine now even with the volume cranked you cant even feel the bass i have...
I am not sure how you are measuring the power output to verify it is less than 200 watts. With a true RMS voltmeter you should see 28.28 volts RMS across a net speaker load of 4 ohms. If you use only one 8 ohm speaker, you will get 120 watts. If you are getting the 28 volts there is nothing wrong with the amp. You MAY have blown the speakers OR not generating much bass due to processing in an EQ. I assume you are using at least 15 inch speakers if you want to feel bass. Look up your speakers specs... you will need speakers capable of 32 Hz to feel much. With this amp your speakers should have aa total rating not less than 400 to 600 peak watts or around 300 watts RMS continuous power rating. Using a lot of high end EQ will keep the amp busy at the high end and reduce the power available at the bass end.
May 06, 2011 | Kustom Deep End 200HD 200 Watt Bass Amp...
I have a bx4500h and a ultra bass 115 cabinet. the head is fine, but the crossover? is bad in the cabinet. what can i do? can i just by pass the crossover and just use a 1/4" jack straight to the...
does the cab have a horn like the one in the photo if it does then you must think again.
you must try to get a replacement crossover or get a speaker geek to fix it for you its not so hard you can get the burnt out components fro radio shack / maplin so on. most of the blown components will show damage or smell like they are burnt because thats what they are.
the cross over plays a very important job in the fact that it filters of the top frequencies so you only get subs on the bottom 12's bass / mid on the top 12's and hi frequencies on the horn.
you will loose all the quality if you go direct and could easily blow things up especially the horn.
this speaker cab looks like a Kenny i had and when working then they are fantastic. i blow one of the sub 12's and the cross over survived so unplug the speakers and test them 1 by one with a little power from an amp and a small amp that does not matter if it gets damaged
Apr 11, 2011 | Behringer Ultrabass BB410 1200W Bass...
I installed a Pioneer DEH-P800PRS head unit and 4 Kenwood KFC-1662S speakers in my 2003 Dodge Dakota extended cab truck. I used a Kenwood KAC-5204 2 channel amp connected in parallel. Sounds good at lower...
Hello.... sorry to hear about your problem. Bass is the ultimate evil of coaxial speakers. You have a couple of options here, and this is just my professional opinion because I do not know what your lifestyle details, such as truck space needs, type of music you listen to, budget, etc. If you are looking for alot of bass, the best bet would be to use 2 external amplifiers, 1 for the interior speakers, and 1 for a subwoofer. You would then need to purchase an electronic crossover. With this setup, you can remove all of the low frequencies from the coaxial speakers and put them where they belong, with the sub. You will gain EXCEPTIONAL clarity and a very high volume before distortion level. Again it will depend on what your budget is and if you are willing to compromise on some cab space. The only other option you have at this point is if you are wanting to play your music at high volume levels, you will just need to reduce the bass level as you increase volume. I hope this has helped. Good luck with your venture!!
20 year car audio/video installer
Bay manager
Mar 16, 2011 | Pioneer Car Audio & Video
What is this amp for is it for highs ad bass
To me, and it looks like a four channel amplifier. I would say it's used for speakers. Not sub-woofers. But you can use it for subs if that is what you want to do with it.
Jan 21, 2010 | AudioBahn A4004T Car Audio Amplifier
Bass amp not turning on: 2001 ford mustang convertable V6
hey you battery might be going low or some fuse might not be pushed in all the way if its not that then you probably got a blown amp
Nov 30, 2008 | 2001 Ford Mustang
Removing Driver from Sealed Cab
1. Remove the front cover.
2. Remove the four bushes that held it in place. Beneath them are crosshead screws.
3. Remove these screws, and the surround board they hold.
4. You can now see the bass speaker retaining screws. remove them and withdraw the speaker *carefully*. (A knife under the edge helps to get it going.) The wires are at the back mixed up with the damping wool.
5. The tweeter has its retaining screws under the rubber gasket stuck to it.
6. The connectors shoud slide off the lugs, but mine are pretty stiff. Careful with the tweeter's: mine pulled out the termnal completely, and I've had to replace the unit!
Nov 21, 2007 | Mission 780 Main / Stereo Speaker
32 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
