Question about Kenmore Elite 45986 Front Load Washer
My washer is giving us a f21 code - Kenmore Elite 45986 Front Load Washer
    Sergeant:
    Champion:
  • 202 Answers
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Apr 02, 2011
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Very loud and dose not spin clothes out. gives a f21 error code.
Googled this. Try this. http://www.youtube.com/watch?v=uWq0xdh8ZIA
Mar 11, 2015 | Kenmore HE2 Plus Front Load Washer
Whirlpool duet steam washer error f21
The F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
Nov 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Keeps on coding F21 - we have adjusted the hose several times but still seems to be giving us problems
Hi
Error F21 means F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Kenmore HE2 Plus Front Load Washer
F21 flashes on the time screen -- am unable to power washer off
Lets see: F21 Long drain Possible cause: Clogged filter0c09ded.jpg, clogged/failed pump Remove the bottom panel299686f.jpg go for the pump cleanout, get the googus outb1cfae3.jpg. Tech sheet is located behind the white box to the left which is the motor control unit (MCU). The tech sheet is an excellent tool which gives directions on diagnosing those pesky fault code. LOL7b78889.jpg
May 18, 2010 | Kenmore Elite 45986 Front Load Washer
F21 on Whirlpool front load duet washer
"F21" is a Long Drain error code. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
In most cases this is simply caused by a clogged drain pump and all that is required is a good cleaning. Read through the instructions provided in the link on how to do this. Make sure the washer is unplugged while servicing any of the internal components.
If the problem persists, you may have a drain pump that is malfunctioning or is damaged. The manufacturer recommends replacing the pump if this is the case.
Let me know if you have any questions. I hope this helps you.
Jun 12, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer don't work (F21) message
The "F21" error is a "Long Drain" error code. The following link explains:
If you still require assistance, please let me know.
Jan 07, 2009 | Kenmore 46462 Front Load Washer
F21 error code on a Kenmore HE2 front load washer
Unscrew the pump, there is probably objects in the pump, I get that error every month or so, I find coins in my pump all the time, if too much stuff gets in there the code F21 or sometimes SD comes up.
Jul 24, 2008 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
240 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
