Question about Roper RTW4305S Top Load Washer / Dryer
My Roper RTW4305S is making a LOUD ratcheting-clank sound every time the agitator is in use. Any ideas? Is it fatal to my washer, or is it just aggravating?
SOURCE: Kenmore top loader washer noisey agitator
agitator does not work
Posted on Oct 09, 2007
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Posted on Feb 11, 2008
  • 65 Answers
SOURCE: Roper RAX4232KQ - Top part of agitator won't turn
you need to install new agitator dogs . very in expensive. remove cap on top of agitator reach in and remove opaque cover. you should see a 1/2 " bolt remove that and pull up on agitator. pull apart two halves. disassemble. install four dogs. reassemble in reverse order
Posted on Feb 18, 2008
  • 12 Answers
SOURCE: My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Posted on Oct 26, 2008
  • 85 Answers
SOURCE: KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Posted on Dec 21, 2008
Washer fills and goes to agitation cylcle, but weak to no agitation. Upon final spin cycle, began making a loud rapid ratcheting sound and did not spin at all. Machine did drain. I did not observe the...
The direct drive coupling between the motor and transmission has stripped out.
It must be replaced.
This video will help in the repair.
http://www.youtube.com/watch?v=WLPGs2UMUJc&feature=player_embedded
Feb 03, 2011 | KitchenAid KAWS750L Top Load Washer
My GE wjre5550h1ww waher makes a continuos loud clank/bang noise when time the washer is in the soak/agitator cycle. Rinse and spine cycle, normal noise/sound. Please help! Thanks
The part (it has three prongs) that the transmission (yes your washing machine has a transmission) uses to cause the reciprocating motion of agitation has broken off 1 or 2 of the 3 prongs, and, if you
continue to use the washer (you might as well, the part is broken already - you may as well run it until it dies), the part will break completely, and you'll lose the soak/agitator cycle altogether.
FIX: replace the broken 3-prong plate, and give it a nice coating of automotive bearing grease to help it last for awhile (until the next thing breaks).
Dec 11, 2010 | GE WBSR3140DW Top Load Washer
Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Feb 26, 2010 | Amana NAV3330AW Top Load Washer
Removing retaing screw on agitator
its a 7/16 bolt. so with a longer extension on a ratchet and holding bak the agitator with the other hand, perhaps a sqirt of some 3-n-1 oil ,
Mar 07, 2009 | Roper RAS8445KQ Top Load Washer
Roper wash machine ras7133kq1
no theres something in your pump,,it up against the impeller in your pump.....onthejob
Jan 31, 2009 | Roper RAS6233KQ Top Load Washer
Agitator Noise of Roper RTW4305VQ
yes this noise is normal.its the dog ears ratcheting in the agitator
Jan 19, 2009 | Roper RAS8244KQ Top Load Washer
New washer, Maytag title, but RCA unit--knocks and clanks
Thank you for your complaint. It will be forwarded.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
I have a top load Roper washer that won't spin.Any ideas?
That sounds like a bad drum bearing, check and eventually replace the drum bearing.
Dec 28, 2008 | Roper RAS8445KQ Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Roper RTW4305S Top Load Washer / Dryer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
