Question about Samsung RS2530BSH (25 cu ft) Side by Side Refrigerator
The freezer works but not the refrigerator side where is the fan for the refrigerator side
    Sergeant:
    Champion:
  • 202 Answers
There is no fan on the refrigerator side ... is the fan running on the freezer side?? look to see if you have frost on the back wall of the freezer .... if you have frost then your not defrosting
Posted on Apr 02, 2011
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Amana side by side. Freezer is working. Refrigerator isn't'!
  1. take all from freezer side out
  2. open back wall
  3. check if the fan is damage
  4. check the heater element
  5. check thermostat
  6. one of them is bad
  7. good luck
Jan 01, 2010 | Refrigerators
Side by side, refrigerator works, but freezer does not The freezer just started thawing everything. We can still hear something running in the refrigerator.
This is unusual. The more common set of circumstances is that the freezer works but the refrigerator doesn't. The cold air in a side-by-side is produced on the freezer side and is than transferred throughout the freezer and to the refrigerator by a fan in the freezer.
You say you hear something running in the refrigerator. This could be the freezer fan. It is located behind an access panel in the freezer. This fan should run.
You should also hear the compressor (underneath the refrigerator) running. If this doesn't run, you will not get cooling. Also, there should be a compressor fan (underneath the refrigerator close to the compressor) running. This fan removes heat from the refrigerant coils and transfers the heat to the outside. If this fan doesn't run, proper cooling cannot be obtained.
Check these things out.
Oct 20, 2009 | Refrigerators
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
Aug 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Maytag refrigerator side stopped working -freezer side fine #MSD2758GEW
SOunds like it is the FF(Freezer Fan) this problem is very hard to detect as the fan will turn, but not enough to circulate the air thru the freezer and refrigerator. The minimum cost to repair/replace the fan assembly is around $300.00
Jul 27, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Whirlpool gs2shaxnl00 freezer working but not fridge not
The possibility is that the freezer fan is not working or the passage from the freezer to the refrigerator where the fan blows the cool air from the evaporator is blocked. Also if you say you manually defrost it could be that it is not self defrosting which can also cause this problem because the evaporator will build up ice and block the flow of the fan air
Jul 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Side by side refrigerator freezer side working other side isnt
check defrost timer and manuly turn and see if it works!!!!!!!!!!!!!!!!!!!!!!
Feb 19, 2009 | Frigidaire GLRS263ZD Side by Side...
Refrigerator will not defrost or cool
Either your fan is going out or you have a blockage.Replace the fan after you totally defrost it.
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation but your freezer may look likes its working becuse it is still frozen,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
Len West
Feb 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Aug 03, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RS2530BSH (25 cu ft) Side by Side Refrigerator Logo
214 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
