Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
H20 is flashing on my hotpoint washing machine
    Sergeant:
    Champion:
  • 202 Answers
H20 indicates a problem with water supply.
Check the inlet hose/s for blockage or restriction, make sure the water supply is o/k, and the pressure is good, also check the inlet valve/s filters.
Posted on Apr 02, 2011
  • 3 Answers
SOURCE: All lights flashing on Hotpoint WF541G washing machine
It's probably a loose connection in the wiring in the machine. Seems to be a problem with the WF741 machines and is most likely a similar issue with yours. The probability is that the vibration from the machine is enough to work some connections loose. If you have someone competent to do this, then check that all connectors are pushed firmly onto their circuit boards. (I have posted a separate reply to this issue for the WF741 model on here.) See if this helps.
Posted on Oct 27, 2009
SOURCE: hotpoint washing machine aquarius super silent wf620
Dear stacey
Had a similar error message
turned out I hadnt turned the water taps on
check this and if not the problem could be the water sensor in the drum
G
Posted on Jun 27, 2009
mumma_1
  • 903 Answers
SOURCE: wash enhance & on/off flashing
The only time the lights kept flashing on my Hotpoint machine was when the outflow pipe going into the ubend was blocked,
Check for blockages, but make sure that you have a bucket or pan ready to collect the water flow.
I hope this helps
Posted on Nov 24, 2008
barkencoa
  • 3463 Answers
SOURCE: h20 fault is flashing on my hotpoint washing
H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose/s.
To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, thjn the valve will not operate properly..
If you are satisfied it is o/k then it is quite likely a valve fault, also check the filter built into the valve inlet.
Posted on Dec 08, 2009
barkencoa
  • 3463 Answers
SOURCE: fault code h20 flashing on indisit wie127 washing
H20 is indicating a problem with the incoming water supply to washer.
Check the inlet hose/s for kinks or other restriction, ensure that you have a good pressure to the washer, make sure tap/s are fully turned on.
If all o/k,then could be a problem with the inlet valve/s
Please rate my solution.
Thankyou.
Posted on Jan 21, 2010
My washing machine flashes H20
Try to put some hot water and drain it(not too hot)
Apr 08, 2014 | Hotpoint Ultima WF860 Front Load Washer
What is code H20 on hotpoint washing machine
Check to make sure that the water valves are open and water is getting to the machine.
May 29, 2012 | Hotpoint Washing Machines
My machine is flashing h20 and wont start why
hi my machine is flashing h20 what does it mean
Mar 26, 2011 | Hotpoint Aquarius WD640 Front Load...
Hi i got hotpoint ultima igot flashing h20 on screen
These are the notes I have-
Providing it is not in demo mode, H20 means 'no water is being supplied'.
Press and hold 'start/cancel', release then press again to cancel the drain. The machine should now be reset.
If H20 returns there is a problem with the water supply- the hoses are kinked or squashed, the taps are not turned on fully or the water inlet valve is malfunctioning, apparently!
Good luck,
John C
Mar 11, 2011 | Hotpoint Ultima WF860 Front Load Washer
H20 keeps flashing
  • H20 - Not fillings. Check tap, hose and inlet valves
  • If you have proper water pressure the your water inlet valve on the machine is bad and needs replacing.
Dec 21, 2010 | Hotpoint Washing Machines
Hotpoint aqualtis giving H20 error, looks like fill problem, but cannot see anything stopping the water flowing into the machine.
i have hotpoint aqualtis, it washes & empties but then starts flashing when ready to rinse. any suggestions?
Dec 04, 2009 | Washing Machines
My hotpoint washing machine will not wash and is flashing h20?
H20 is a fill fault. check water taps are turned on, inlet hoses are not kinked. if ok then a possible fault with the inlet valve(s).
Oct 30, 2009 | Electrolux Washing Machines
I have a hotpiont wf860 flashing fault code H20, please help
h20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
Jun 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Flashing H20
h20 means no water is getting to the machine. check your washing machine taps are on and water getting to the machine and the fill hose is not kinked.
Jan 26, 2009 | Washing Machines
Hotpoint Ultimasimply flashes H20.
witch one of theses are your washing machine?
lcd evo01
lcd evo02
or the V4
please let me know so i can get you the right term for the code.
Aug 14, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
1,210 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
