Question about Westinghouse Electric Westinghouse Lighting 3speed Ceiling Fan Switch 7707500
I forgot to write down the color connections. my options are L 1 2 3 my wire colors are, blacr, purple, yellow, blue. which goes where?
    Scholar:
  • 133 Answers
One line on the fan goes to the house common and should be white. this one is separate from the new switch. The other 3 lines on the fan are the 3 speeds. "L" is for the hot line coming into the fan and should be BLACK or RED. It should also be in the same box connector as the white above.
1,2 and 3 are the 3 fan speeds and tie to the 3 leads on the fan.
Try 1=purple 2= blue 3=yellow
You may need to move them after testing but darkest to lightest is usually the 1,2,3 order. Please let me know how much this has helped. Thank you!
Roger
Posted on Apr 02, 2011
Rodeo fuel pump rewire
Usually on these it is the fuel pump sending unit. But here is how the wires connect. Here is what you need to do about the different wire colors. First disconnect your negative battery. Drop the fuel tank and replace pump. Remember to have a splice kit in hand. Ok now here is how you connect the different colored wires. Black goes with black. Gray goes with black and orange wire. Purple goes wit blue and yellow. And the last wires goes together. I hope this helps.
Sep 30, 2014 | Cars & Trucks
Have have a westing house switch no.77286 with a l123 and colored black yellow blue and white color wire which color goes to those no.
The black usually goes to the L. The others you'll have to play with, If it's the correct switch. You should mark down what color wire goes into which slot BEFORE you take them out. DO NOT CUT WIRES!
fanman9952@aol.com
Sep 18, 2014 | Dryers
Don't know radio connector color code
This should help.
1987-88 Plymouth Voyager Stereo Wiring
Constant 12V+
Red
Switched 12V+
Red/White
Ground
Ground/Back Strap
Illumination
n/a
Dimmer
Orange/White
Antenna Trigger
Yellow
Antenna
Right Front
Front Speakers
5 1/4" Dash
Left Front (+)
Green
Left Front (-)
Green/Yellow
Right Front (+)
Purple
Right Front (-)
Purple/Yellow
Rear Speakers
6" x 9" Tail Gate
Left Rear (+)
Brown
Left Rear (-)
Brown/Yellow
Right Rear (+)
Blue/Red
Right Rear (-)
Blue/White
Sep 20, 2011 | 1987 Plymouth Voyager
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
I am changing my run capacitor on my ac unit. it has 3 separate connector locations. 1 is for the fan(my wire is a brown one). my problem is, which wires go to the hermm and which go to the other...
You have two yellow colors , i think you change the 1 yellow to color blue or black , because if it is 2 yellow colors, you don't know what it is common or running ..
May 11, 2011 | Carrier 38CKC024 Air Conditioner
Connect color-coded wires properly;especially the
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate people arnt rating hope this helps
Apr 22, 2010 | Clarion DB245 CD Player
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
Radio wiring diagram for 1992 dodge dynasty
I would buy a adapter but if thats not an option here is the wiring .
Radio Constant 12V+ Wire: Red
Radio Ignition Switched 12V+ Wire: Red/White
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Orange/White
Radio Antenna Trigger Wire: Yellow
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 3 1/2′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Green/Yellow
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Purple/Yellow
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Brown/Yellow
Right Rear Speaker Wire (+): Blue/Red
Right Rear Speaker Wire (-): Blue/White
Mar 27, 2009 | Pioneer DEH-P44 CD Player
Map sensor pin arrangement dodge cavan 2003
Hello, here is a picture of the connector and wiring.
85cdf8a.gif MANIFOLD ABSOLUTE PRESSURE SENSOR (GAS) - BLACK 3 WAY CAV CIRCUIT FUNCTION 1 K1 18VT/BR (3.3L/3.8L) MANIFOLD ABSOLUTE PRESSURE SENSOR SIGNAL 1 K1 18VT/BR (2.4L) MAP SIGNAL 2 K900 18DB/DG SENSOR GROUND 3 F855 18PK/YL 5 VOLT SUPPLY
Pink/Yellow is #3, Blue is #2, and Purple is #1. Your colors may appear slightly different
Oct 06, 2008 | 2003 Dodge Grand Caravan AWD
Westinghouse Electric Westinghouse Lighting 3speed Ceiling Fan Switch 7707500 Logo
292 people viewed this question
Top Westinghouse Electric Electrical Supplies Experts
AJMAL KHAN
Gene Haynes
Are you a Westinghouse Electric Electrical Supply Expert? Answer questions, earn points and help others
