Question about Husqvarna Designer I
I was winding a bobbin on my Viking Designer I. I used the start/stop button. When it stopped I tried to remove the bobbin from the winder, but it will not remove. It appears to be locked onto the winder and I don't know how to get it off.
  • 4 Answers
Are you sure the bobbin and winder are slid all the way to the top of the machine before trying to remove the bobbin?
Posted on Apr 11, 2011
Designer 2. Why isn't bobbin winder working?
For ~$25 you can buy a stand-alone bobbin winder from the local fabric store (JoAnns or Hancocks) or even online (Amazon.com).
Oct 24, 2015 | Husqvarna Sewing Machines
Bobbin winder is malfunctioning. Has difficulty engaging in place and will not wind.
VIKING QUILT DESIGNER II USER MANUAL Pdf Download.
www.manualslib.com > ... > Sewing Machine > Quilt Designer II
View and Download Viking Quilt Designer II user manual online. Quilt Designer IISewing Machine pdf manual download.
Viking Husquavarna Designer II Sewing Machine - YouTube
? 1:27
www.youtube.com/watch?v=k0mXebnmzT4
May 30, 2008 - Uploaded by proudpop9pj
Here you can view my Viking Designer II Sewing Machine at work. The first two times I used the foot pedal, the ...
Aug 12, 2015 | Husqvarna Designer I
How to fix viking designer 1 broken bobbin winder
If you mean the bobbin winder mechanism where the bobbin slips on to the spindle is loose, the pin that holds it in place has come out. It's an easy fix but requires that all the covers be removed. Suggest taking it to an authorized Viking dealer for repair. You can find your local dealer by going to the Viking website - http://www.husqvarnaviking.com/us and click on Locate a Dealer.
Jun 09, 2014 | Husqvarna Viking 1
I owe a Topaz 30, lesser than 1 year old. Today I've got problems with the bobin winding. I set it on its place as usually and when I tried to start it and push the ok button, there was a click and than...
I don't have a Topaz, but a Designer 1. I think the bobbin winding setup is similar on these machines. One time I had accidentally pushed too hard on the bobbin winder spindle when I put the empty bobbin on, and the mechanism had gone back inside the machine a little and would not work. I was able to pull it back into place myself without needing to go to the repair shop. Look carefully at your bobbin winder and see if it is in the right place - this might just be your problem and is easily fixed. I am very careful now not to push too hard when I put on the empty bobbin. Also make sure you have pushed the bobbin completly towards the bobbin stop. Does the bobbin winding pop-up appear on your screen?
Nov 10, 2010 | Husqvarna Designer I
My Viking Designer SE Bobbin does not stop winding
I have a Designer Topaz, very similar to yours. There is a small eccentric-shaped piece that rides the thread as the bobbin is filling. On my machine, it can be turned via the little star shaped "torx" depression. This determines the point at which the drive disengages the winding process. In the alternative, when the bobbin is as full as you want it, just push the rider away from the bobbin; the same effect is achieved.
Feb 19, 2010 | Husqvarna Sewing Machines
The bobbin winder is slipping and will not wind the bobbin thread. Is this something that I can fix myselfZ?
Probably not. The covers will have to be removed and the bobbin winder inspected to determine the problem. You might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jan 05, 2010 | Husqvarna Designer I
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Can't put a bobbin on the winder Husqvana Viking 6020
Is this a Designer 1 or a #1? There is no moving lever on the pin of a Deigner 1,they are fixed. If it's a #1, use sewing machine oil or Triflow. NEVER use 3 in 1 oil. It will gum up and cause problems later on.
Aug 31, 2009 | Husqvarna Viking 1
I have a designer 1 that won't release the bobbin.
Winding too tight;
Whenever your bobbin won’t come off any Viking, Designer 1 included, it’s because it wound too tight. This is how you know. It went on easy! To get it off, don’t pry, slowly unwind all thread, it will change shapes and let go of the bobbin winder. My favorite way to wind a bobbin on a Viking is to thread the machine through the needle and go under the foot then up to the bobbin winder (it has to be under the foot or it winds too tight. If it still winds too tight, lay your thread down instead of standing it up, the weight of the thread can increase tension on the winding process also check that you use a spool cap as large as or slightly larger than your spool. If it still winds tight. I’ll explain what bad thread can do.
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test (tip: always check your thread this way when you thread your machine)
Mar 12, 2009 | Husqvarna Designer I
I filled the Bobbin, now how do I get it to go back to sewing
Something didn't click back in place when you removed the bobbin from the winding mechanism. Try winding another bobbin. Make sure it stops, then remove it. If the problem continues, take it to an authorized Husqvarna Viking dealer. They should still be able to take a look at it. Check Husqvarna Viking website for dealer closest too you.
Dec 16, 2008 | Husqvarna Viking 1
Sewing Machines Logo
117 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
