I need wire print of low voltage for ac series 7995
    Genius:
  • 1,157 Answers
Hi nnoles,
May I ask for the brand, type and model name of your Air Conditioner?
Thank you for using FixYa.
Posted on Apr 02, 2011
I have a Coleman mach 3 ac unit. ive replaced everything except the compressor. the fan will come on but when i put it on ac it blows the fuse in the thermostat.
Fuse in the tstat?? First inspect the low voltage wire outside for imperfections, such as bare wires. Unhook the low voltage wires to condenser outside and cap with existing wire nuts. Then replace fuse and turn system on with cooling. If fuse still good then you have a short in the contactor coil in the condenser. Need new contactor. If fuse only blows when a call for cooling it's in the wire for low voltage or the contactor itself.
May 21, 2017 | Coleman Heating & Cooling
WIREIN HEAT PUMP FOR COOLING ONLY
You must wire Orange from heatpump low voltage wire to gether with your yellow s and you must have a common wire usealy common comeing out of heatpump should be black color than what ever color wire you have connected to common at t-stat and airhandler connect that to black wire at heatpump. To make sure blablack I s common follow wire up to board and it will be connected to C terminal now you will have ac all time. If you want heat remve Orange wire from reds at heatpump and you will get heat only.note when doing your wireing make sure high voltage is off to heatpump and airhandler hope this helps
Feb 27, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
Error code 16 coming up on my treadmill 956i
Precor Error 16, AC Input Voltage Too Low Probable Cause 1. AC input voltage is incorrect.
2. Treadmill operating on undersized AC wiring and/or is drawing high current.
Corrective Action
  1. Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
  2. The AC wiring must be sized to handle 20 amps of current over the loop length of the AC wiring. Voltage drop across the AC input wiring is a result of the length of the wire run multiplied by the amount of current being demanded by the treadmill. The longer the run and the higher the current the large the wire must be.Verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error 16
Mar 28, 2014 | Precor Exercise & Fitness
Treadmill error code 16
Corrective Action
Precor Error 16
Flashing service code, indicates brownout, checked electricity to computer, 240volts, what next?
A brownout can be detected by checking the dc voltage being supplied to the electronics in the main controller board. If anything upstream of this point is causing a lower than normal voltage from getting to the controller board. The condition is checked with a comparator circuit, comparing this voltage to a reference voltage. Here are some possible causes:
1. Lower than normal input voltage (brownout).
2. Bad connection in the power wiring.
2. Defective voltage reducing transformer.
3. Faulty rectifying and filtering circuitry.
4. Defective comparator or reference voltage circuit.
5. Defective micro-controller reading the under voltage signal.
What I would do if one of my customers had this issue is prepare to take voltage measurements on the heater by being able to open it up and having a volt/ohm meter available. I would then call the Haywardtechnical support at 908-355-7995 and see if they can lead me into measuring the dc voltage on the board that has the comparator circuit and the ac voltage being supplied to this board.
If the voltage is low it needs to be corrected, maybe by replacing the transformer or repairing a bad connection. If the voltages are normal then I would suggest that it is a false alarm. If the heater still works then I would discuss with the customer that the heater was getting a false alarm but continued to heat. The customer could then decide weather they wanted to replace the board to correct the alarm or tolerate the false alarm.
Please fill me in on what happens and ask any further questions. Thank you.
Aug 30, 2011 | Hayward H-series Electronic Gas Pool...
Heater will not light
There are several things that can cause this symptom. If you have a volt/ohm meter and call the Hayward technical support at 908-355-7995 they might be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 24, 2011 | Hayward H Series Induced Draft Abg 100,000...
I need to know the which color of wire goes to what pin number on the connector that on the back of alpine CDA-7995.
You need a wire harness for your vehicle make. Its like 15 bucks. You plug it into your car harness where the radio goes. It has a little peice of paper to tell you what the color codes are. You need to know what the wires on the receiver are though. For example mine are labeled with small tape that say ground,front left, right rear, Ect. Leave good feedback if this helps. Thanks
May 09, 2011 | Alpine CDA-7995 CD Player
My ac circuit breaker keep tripping
If your outside condenser has a locked rotor or short circuit, than the unit WILL trip the breaker - as it should. On the other hand if a breaker is tripped a few times it will have less of a capacity that the rating, (this is designed in it). You will need to determine if the unit is locked (and broken) or the breaker has become too sensitive.
Apr 20, 2008 | Heating & Cooling
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
