Question about Cameras
When trying to import images from my camera using the Canon Utilites CameraWindow DC, I am just getting an error message saying "Failed to import images" Please Help.
  • 1 more comment
  • deborah_may6 Apr 02, 2011
    I do not have a blue direct transfer button on my phone and it is connected to a usb.
  • deborah_may6 Apr 03, 2011
    Hi, This is a problem I have trying to transfer even one picture at a time. And while I can get the pictures on to my pc direct from the camera without using the softwear, any videos won't play correctly. (just sound, no images). Also, as I have paid for this softwear, you should expect it to work and it galls that it doesn't even seem to try.
    Thanks.
  • deborah_may6 Apr 04, 2011
    I have already done this. No change.
  • 668 Answers
It tends to be the problem with the software. First uninstall the software completely and reinstall it once again. Since you are able to transfer pictures directly to pc then there tends to be the problem with the software.
Hope this helps.
If you still face any problem, let me know.
Shane
Posted on Apr 03, 2011
  • 977 Answers
Hi!
It seems like a known issue with Canon's software (and I've already answered it a couple of times, here on FixYa...) - with no solid solution so far... People inform that they get this error when trying to copy large amount of photos at once, but almost never when trying to copy smaller amount (about 25 photos each time).
Anyway, there are 2 work-arounds that I can advise you:
  1. Use a different software/method to transfer your photos. You can use the built-in Microsoft Scanner and Camera Wizard (instructions: Windows XP - here; Windows Vista/7 - make a shortcut to %systemdrive%\Windows\System32\control.exe /name Microsoft.ScannersAndCameras on your desktop, and run it). Alternatively, use Picasa to arrange/copy your photos (instructions - here).
  2. Use a card reader (or a SD card slot on your laptop, if exist) and copy the photos manually, using Windows (normal copy/paste procedure, from the new drive that will be shown under My Computer...). This, by the way, is my preferred method.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu.
  • Ran Kedar
    Ran Kedar Apr 03, 2011
    Hello again Deborah!
    You're right... You've paid for the software to do something it fails to do!
    Unfortunately, it seems that Canon's guys don't hurry up and/or work hard enough to solve this issue... "Solution" stays as I mentioned above.
    Regarding the videos, it's a totally different issue, which can easily be solved.
    It's a matter of missing codecs. To have them installed, download and install K-Lite Codec Pack; then restart the computer. The videos should play normally afterwards.
    (If any message of previous installed codecs appears while installing the codec pack - allow it to remove them!).
    Good luck again,
    Pelu.
  • Cameras Master
  • 17,970 Answers
I found this comment in the troubleshooting section in the manual. I tested it and the transfer speed is greatly reduced. Hopefully this is not the solution and Canon can fix thier software. USB 1.0 transfer speeds are painful.
I wasn't able to repro the error every time. It seems to only happen with a large amount of images. I don't get a repro with 25 images, but I get a failure about 1 in five times when have more than 75 images using setting A. No failures with setting B.
Additionally, the Canon helpdesk replied about this problem with:
'After connecting the camera and letting Zoombrowser open, or opening it manually, press the blue Direct Transfer button on the camera. This will override any problems with the Camera Window program, and should start the download.'
Tried that, didn't work - nothing happens when I press this button - so contacted them again, saying this, and their next suggestions were:
'Please ensure that you connect the device directly to a USB port and not via an external hub or adaptor.
You could also uninstall and reinstall the software to rule out a software issue. If the problem persists you could install and test it on a second PC to rule out a hardware fault.'
I'd tried all of those, all of my USB ports are direct but changing port didn't make a difference either. I haven't had a chance to try it on a second PC, but will do when I get access to another. In the meantime I'm doing the slightly ridiculous routine of putting the SD card into my PDA and downloading the pictures onto my PC from the card via the PDA!
Hope helps.
Posted on Apr 02, 2011
I have a Canon PowerShot A2000IS camera and I moved some files to a different hard drive and now I am unable to download any photos. The CameraWindow DC gives me an error message that says
rerun your installation software to install to your new picture folder location. Be careful not to overwrite your original folder. I would rename the original to be safe. Good Luck!
Jul 20, 2012 | Canon Powershot A2000 IS Digital Camera
CameraWindow won't open or will suddenly close before loading
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 03, 2012 | Canon PowerShot S90 Digital Camera
Unable to upload pictures on to my computer
Solve your problem by using a card reader to download your pics to a folder you create on your desktop.
Apr 09, 2010 | Canon PowerShot SD1000 Digital Camera
"failed to initialize" camerawindow-downloading images to macbook
Do what the pros do...use a card reader to download to a folder you create on your desktop.
Feb 20, 2010 | Canon PowerShot A470 Digital Camera
I have all the softwares installed in my computer. I have downloaded images no of times. But its not happening now 1) Camera gets connected to computer 2) The window appear on the computer Where i click on...
Find out where "Canon Camera Window" points to for its default pictures Folder and change that path or create a Folder in the location where it is pointing to ...
It seems to be directing the pictures to a non-existing Folder !
Sep 27, 2009 | Canon Digital IXUS 860 IS - Digital camera...
Save folder not found
The save folder it is looking for probably doesn't exist. If you are using Canon CameraWindow DC, cancel out of the download popup by choosing "operate on images on camera". Then click on the button that looks like a folder with the word "set" below it. Click browse and select the folder you want your images saved to. (For example, "My Pictures".) Now click the button that has an arrow pointing from a camera to a computer. Your images should begin downloading to your computer without any error.
Jul 21, 2009 | Canon PowerShot SD870 IS Digital Camera
How to down load the pictures from camera with microsft 2003
It's quite simple .Just connect your canon camera to your computer .when it's connected open the folder and simpley copy all jpeg images and past it where every you want
Jun 23, 2009 | Canon PowerShot A85 Digital Camera
I CANT DOWNLOAD THE PHOTOS ON MY PC!
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon A460; Downloading pics to computer
I have the exact same camera and all I did to put my photos on the computer was plug my camera into the computer using the USB cable provided. A wizard window should pop up and click on import photos. If that doesn't work, then I'm not sure what to do. I have windows Vista, by the way.
Dec 26, 2007 | Canon PowerShot A460 Digital Camera
Cameras Logo
2,023 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
