Question about LittleLan Mp3nity
MP3nity doesn't recognize files on a CD. It works fine for every other audiobook CD I've tried to rip, but for one particular set of CD's it recognizes none of the files on none of the CDs. Win Media recognizes and rips these CDs. Thanks.
I am trying to download an audiobook file (WMA) from my library website to my Coby 601. The library uses a program called overdrive to download to handheld devices. It says my Coby does not recognize WMA...
The player does in fact play WMA files. However, if the audiobook is a protected audiobook that you purchased, the Coby device cannot play what is called DRM protected files. While Overdrive supports the playback of these files, the Coby player may not, or you no longer have authorization to play the file.
Apr 18, 2011 | Coby MP601 MP3 Player
Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Sep 23, 2009 | Alpine CDE-102Ri CD Reciever, iPod and USB...
Won't recognize an MP3 format CD
Usually a disc with audio files is not encoded with MP3's, but, rather, audio files. You can check this by manually opening the disc (right click on the player when the disc is in it), and looking at the files. If you only see marker (files of a few kilobits) in "MP3" format, then the disc needs to be "ripped" into MP3 format.
The ratio for audio to MP3 is 10 :1--this means a CD of 700 MB size with 10 tracks will become an MP3 collection of 10 tracks approximately 70 MB in size (this is a standard 128kbps audio quality CD) If the encoding is less (64 or 32kbps), the size of the resulting MP3 is smaller.
The hands down best ripping software to convert your audio CD to MP3's is called Goldwave. Although Nero and Winamp have functionality on a limited basis for this task, Goldwave is a far superior software package to not only rip, but also edit your creations. Once you have installed Goldwave, you use the OPEN CD button to read your files---then save them to your hard drive (in what CODEC or quality you want---MP3, Apple AIF, OggVorbis, etc.etc
Mar 27, 2009 | Pioneer DVR-107D DVD±RW Burner
I have a Philips GOgear SA5285 and I can load the audible audiobooks and they go to the audiobook file but when I load my library books from Netlibrary.com they load as songs and do not have book marks, so...
If you are a newbie, and you primarily want the mp3 player for audiobooks, then go ahead and take this player back to the store - I'll tell you why:
The deal between Audible and Philips fell through before the latest series of GoGear's was released. Therefore, even though the player has an Audible folder, it will not properly play Audible audiobook files. Sad, but true.
Your post reminds me that I need to write a Consumer Watch article on mp3 players that claim to play audiobooks - 90% of them will not easily allow you to play audiobooks - you will have to jump through hoops.
If you still want to try, here is what you want to do:
1. Delete any audiobooks off the GoGear, but make sure that you have a copy of the audibooks on your computer itself.
2. Open Windows Media Player. Find your audiobook files in your library. If they don't show up, then you will have to move your mouse over the Library tab - a small black arrow should appear underneath the word "Library" - click the black arrow and select "Add to Library". Click "Add" and find the folder in which your Audible files are stored. It may take several minutes, but Windows Media Player will add these files to Windows Media Player.
3. Right-click an Audiobook file starting with Chapter 1 of whatever book, and select "Advanced Tag Editor". One-by-one, manually assign an a track number to each audiobook chapter - Track 1 for Chapter 1, Track 2 for Chpater 2, etc.
4. Now, re-add the audiobook files to your GoGear.
5. You might additionally have to go into the Settings menu of your GoGear, and turn Shuffle mode off - your user's manual can show you how to do this.
Sound like a lot of work? You betcherbottom dollar it's a lot of work. This particular mp3 player is not the best for audiobooks.
-Tha Mp3 Doctor
Mar 11, 2009 | Philips GoGear SA5285/37 Digital Media...
I cant organize my downloads, and I listen to audio books and would like to see if there is a way to bookmark or save the place in my book where I left off. I have to sit there and hold to fwd button...
-Tha Mp3 Doctor
Mar 07, 2009 | Philips GoGear SA5285/37 Digital Media...
Fast forwarding for listening to books
I use a Creative Zen V Plus, but have a similar problem.
First, an explanation: the issue is probably with the timecode in the audio track. This can happen when the audio file is created on a computer. The audiobook was likely "ripped" to a file from the original audiobook CD, and your player may not like the format the file is in. The best solution in this case is to recreate the audio files yourself. First remove all of the files from your Sansa for that particular book. Then use CD-burning software on your computer to create an audio CD (not a data CD!) from the files you got from the library. Finally, use the software that came with your Sansa to transfer the audio CD back to your Sansa. This way you know you are getting a correct format on your player.
If you have an additional issue (like me) where the tracks are too long and go back to the beginning every time you turn your player off, you may have to use an audio editor such as Audacity to chop the long tracks up into smaller tracks, but this is quite time consuming. It is best to acquire audiobooks in smaller tracks in the first place. This is the problem I have been faced with while using Audible.com to listen to audiobooks.
Jan 21, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
GOGEAR SA 3345/37 - Computer is not recognizing player as a player
The 5125 recognizes copyright-encryption and has an Audiobook feature
The 3345 does not recognize copyright-encryption, and does not support audiobooks - if you want some laughs - the file system in the 3345 has an Audible folder, but the player does not recognize Audible - it was a design fluke
Philips 2008 models are a step down for the 2007 models, if you ask me
Jul 25, 2008 | Philips GOGEAR SA6045 MP3 Player
RCA TH1100A track order problems
Here's how I resolved the Play-Order Problem with my TH1101A using Windows Exporer:
1. I put every file (MP3 and WMA) in one folder on my computer.
2. I renamed the files 001.mp3, 002.mp3, etc in the order I want them to play.
3. On the FOLDER, Right click - Properties - Customize Tab
4. In dropdown, change to "Documents (for any file type), click Apply
5. General Tab, "Advanced..." button - UNcheck "For fast searching, allow Indexing..."
6. then click "OK" "Apply" "OK" to exit folder properties.
7. In explorer, all the files in the right pane should be sorted by name in proper order.
8. Copy the files to the Pearl.
This worked for me, but of course, I can't guarantee anything.
Oct 29, 2007 | RCA TH1101 MP3 Player
Computers & Internet Logo
24 people viewed this question
Top LittleLan Computers & Internet Experts
David Payne
David Payne
Are you a LittleLan Computer and Internet Expert? Answer questions, earn points and help others
