Question about Carrier Heating & Cooling
My Carrier Central AC unit is acting strangely ... when I set it to cool the outdoor compressor (and comp. fan) kicks on as expected ... about 30 seconds later it shuts down but then restarts again in another 20 seconds or so only to shut off again shortly thereafter and it keeps repeating this cycle. I thought it might be a defective thermosat and I replaced it with a new one yet same proiblem ... any thoughts or suggestions ??? Thanks
  • 1 more comment
  • Harold McCormack Apr 02, 2011
    Thanks for the quick response ... this is a Carrier central air/elec furnace system ... the furnace works fine when I turn the thermostat to heat ... but when I tried to use the AC for the first time last week (it wokred fine last summer) the air handler fan that cirrculates the air in the house comes on and stays on (like it should) and the outside compressor and fan come on like they should ... but about 20 seconds later though the outside unit (compressor and fan) shut off but the indoor blower fan stays running ... after another 20 seconds or so the outdoor unit kicks on again only to shut off again in another 20 seconds or less ... it keeps cycling like that although I didn't let run too long for fear of damaging something ... we had an unusually cold winter this year could that have damaged something on the outside unit ??? ... this morning I took the panel off the indoor unit to check the evaporator coils for cleanliness and looked at the wiring from the thermostat to the electronics ... the coils were clean and I did not see any obvious wiring meltdowns although I'm really not sure what to expect ??? .. I bought the entire system new 6 years ago .. thanks
    clean what ??? .. the inside coils or the outside coils ... I cleaned the outside coils last summer and everything inside and out looks OK ... rm
  • Harold McCormack Apr 03, 2011
    Great info
  • Carrier Master
  • 3,740 Answers
Since you did not include a model number I can not verify this but there are a few things that cause this. the first being a low coolant switch that is being actuated because once the pump kicks on the pressure drops on the low pressure side below the switch actuation point. The 2nd reason would be the capacitor that is not maintaining enough run capacity to keep the compressor running. (i.e higher than normal internal resistance of the capacitor due to breakdown of the internal components of the capacitor. There is a contactor also can cause this problem if the springs that maintain contact tension are weak or the contacts are just not making good contact and they heat up rapidly. If your pretty savvy you can remove the contactor contacts and clean them up then reinstall them. The biggest hassle in this task is re-installing the contactors' contact tension springs. Just make sure you turn off the Power / AC CBkr before working on this.
Just a note some units do NOT have a system low pressure switch. Many do.
One question... Is the fan always running and the compressor kicking on and off? Or are they both cycling?
If both are cycling then suspect the contactor or low pressure switcfh. If only one is cycling suspect the capacitor.
Thanks for choosing FixYa,
Kelly
Posted on Apr 03, 2011
    Genius:
  • 1,622 Answers
Ok Let me make sure I understand. The inside fan goes off and on ot both inside and outside. When you say off and on how long does it stay off and on.
Are you talking about the condensing unit outside or the indoor fan? If it is the outdoor unit you COULD be short cycling on a pressure switch that auto resets. I thin k you should call a service tech.
I am sorry. I think this is a package unit, If the entire unit is shutting off it is high pressure or low pressure switch. Turn thermostat to the fan on position and see if fan runs. Get back to me.
Just trying to eliminate thermostat.. There is fan relay in air hanlder that is bad if thermostat is oK. It is a time delay relay and goes bad quite often on Goodman units. If you take the front off of the air ahndler you will see a small black sequencer. Turn power off before you look inside and check for loose or burnt wires on the unit.
Do you see the wiring that comes from thermostat. it may be on top of unit. There should be red ,yellow and green wire from thermostat. Turn power off. The wires these attach to at furnace twist together and turn power on and see if unit operates.
Fan relay should have 1 2 3 terminals on it. Fan motor goes to 1 wire off heat equencer goes to 2 and 3 to power. Jump 1 amd 3 .to see if fan runs
Posted on Apr 02, 2011
  • SANYADE  OMOTOLA
    SANYADE OMOTOLA Apr 02, 2011
    When last did you clean it ?
  • kamal May 15, 2013
    did you resolve the problem, if so then what was the casue, i got exact same problem now
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Carrier air conditioner isn't cooling the house. It is blowing air, but it doesn't seem to be cool air.
Check the outdoor unit to see if it is discharging hot air out of the top ofd the unit, check the insulated suction line to make sure it is cold or sweating. Try to listen to the outdoor fan and the compressor to make sure they are both operating
Jun 24, 2010 | Carrier 38CKC036 Air Conditioner
Does not cool
CHECK FREON LEVEL...IF GOOD CHECK FOR DISCONNECTED
THERMOSTAT OR COMPRESSOR OR CONTACTOR WIRE AT OUTDOOR UNIT WITH POWER OFF. CHECK FOR A BLOWN CAPACITOR OR UNIT GROUNDED OR BURNT WIRE. BAD BREAKER OR SEE IF OUTDOOR FAN COMES ON AND COMPRESSOR KICKS IN ( MAKES WHIRRING NOISE ) .
INSIDE CHECK BOARD FOR BLOWED FUSE, GROUNDED WIRE, MAKE SURE SYSTEM IS GETTING 24 VOLTS, IF NOT CHECK THERMOSTAT WIRES OR TRANSFORMER ON INDOOR UNIT.. IF YOU SET THERMOSTAT TO OFF AND ON AND THE INDOOR FAN COMES ON..YOUR GETTING 24 VOLTS.NOW YOU NARROWED TO THE BOARD OR LOOSE WIRE, FUSE OR THERMOSTAT. IF YOU TURN YOUR UNIT ON COOL AND AUTO AND THE INDOOR AND OUTDOOR FANS COME ON AND THE COMPRESSOR KICKS IN
BUT IS NOT COOLING...CHECK AND POSSIBLY ADD FREON...
ALSO CHECK AND MAKE SURE INDOOR BREAKER IS ON.
Apr 09, 2010 | Heating & Cooling
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Carrier central ac high efficiency
usually capacitor,burnt wires or bad compressor.kill the power and check the terminals at the compressor.they have been known to burn off if the connection is loose.
Sep 06, 2008 | Carrier 38CKC042 Air Conditioner
Compressor not doing much
I am assuming that you are talking about a central ac unit. On a central air unit the outside fan must be running whenever the compressor is. If it's not the compressor will shut off from overheating withing minutes. First you need to shut off the unit for several hours and let it cool completely down. Then turn it on briefly to see if the compressor starts and see if the fan tries to start.( I am assuming the compressor starts and runs.) If the fan won't start try testing the capacitors. There are usually two one for the fan one for the compressor. Sometimes there will be one combo one. Mark the wires and remove the capacitor. Get it tested and if bad replace it. This will probably do the job. If not test for current at the fan motor. Also test to see if it turns freely. The motor may need to be replaced. This will run about $50. The capacitor should always be replaced when the motor is changed anyway.
Jul 09, 2008 | Carrier 38BRC060 Air Conditioner
I have a carrier infinity system. On the thermostat it reads "sens error" where the outdoor temp is normally displayed. The inside unit is running but the outside unit is not. Any suggestions?
A burned or pitted contactor will/can cause a unit to not run. Outside fan. Just thinking out loud. Start with low voltage check at t.stat then check outside low volt. Set t.stat to on. If fan engages at least your transformer is good. Next set calling for cool. Drop t.stat 68-70. If nothing happens go outside and with a screwdriver depress the contactor in. If fan and compressor kicks in change the contactor. If contactor is pulled in check outside fan. Remove the wires from the compressor and see if the fan will run . If it does you have eliminated start components as good. The compressor has to be check. It needs to be ohmed out. Turn off power at disconnect. Pull the cover on the compressor. Check between pins; then pins to ground. Open or infinite is good.Have you checked fuses. Like small 3-5 amp fuses
Jul 03, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
1,213 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
