Question about Miele T9820 Gas Dryer
Check filter/vent light is coming on. I have a Miele T9820 dryer
  • 291 Answers
SOURCE: pop the top miele t9820 dryer gas
Open the door, at the top of the recessed door opening you will see two round plastic caps. Remove these and you will see screw behind that you have to remove. Some models the caps are on the right and left hand sides. Slide the top towards the back after removing screws and the top will lift off. Good Luck, Appliance Specialists
Posted on Jan 06, 2010
paulc118
  • 15 Answers
SOURCE: how do i replace the dryer belt
Don't mess with it. Call Miele. The front seal is probably worn and caused the belt to break.
Posted on Feb 27, 2010
ginko
  • 19396 Answers
SOURCE: I just had the softwear
Hi.
Try holding down reset for several seconds. If that does not work, then there is a problem with sensitivity settings of the signal from the two sensors in the air duct. Call Miele and insist to get a tech at home, the problem is not your fault.
Here a discussion on the same issue.
Posted on Sep 10, 2010
  • 9 Answers
SOURCE: i have miele gas dryer
The problem is likely with the centrifugal switch on the dryer motor. This switch connects the start winding of the motor which provides additional torque at startup. Once the dryer is up to speed, the switch disconnects the start winding. If it malfunctions, the dryer will not turn and the motor will hum. By spinning the drum, you are providing enough torque for the start winding to be able to take over and bring the dryer up to speed.
You may be able to correct this by simply lubricating the centrifugal switch which may be sticking. I am not sure if the centrifugal switch is replacable, or if a new motor is necessary if lubricating does not solve your problem
Posted on Nov 28, 2010
  • 251 Answers
SOURCE: I have a Miele T9800
Hi - it makes me wonder as why we always tend to do things first prior to seeking the right/correct advice.
A T9800 Miele is not your everyday cheap dryer as you will know - the questions is have you still got your user Manual and if you do - have you read it carefully - it will tell where the problem lies and how to clean it.
I cannot grasp the fact that you would remove the rear access panel for a heater bank to check the resetable over temperature unit.
The machine clearly indicated a vent/filter error not a heat error - I know at this moment you have and are swearing & calling me names...
I will let you cool down a little ....................and I will tell you what you should have done instead of removing that panel Ok?
Posted on Jul 16, 2011
Miele t9820 service manual
did you get your software update done during the campaign? Call miele for the software update. while the tech is there, ask him any question you want. it is free of charge, and it is a safety issue on that dryer. 800 999 1360. dsc software update.
May 02, 2012 | Miele T9820 Gas Dryer
Cant get the clean filter lights to stop flashing
Think of this as a "low airflow" indicator. I know it says clean filter, but this error code is triggered when the temperature gets too high in the air duct sensor at the front of the machine as compared to the sensor at the rear of the machine. the most likely cause is a dirty filter. if you use dryer sheets, the fine mesh can get clogged with paraffin wax. if you hold your filter up to the light, and it looks cloudy and clogged, clean it in hot water to dissolve the paraffin.
if the light still comes on, check to make sure your ducting is not clogged and that the flapper door on the outside of your house where the duct exits is clear and that it opens when the dryer is running. you may need to unplug the dryer if the clean filter light is on and wont go off. plug it back in and try to run it.
Jul 09, 2011 | Miele T9820 Gas Dryer
Check filter/vent lights are on. we have cleaned everything and dryer stii wont work
there is a sensor below the lint screen, it has two screws, and this may have a film on it from the dryer sheets. The easiest and safest way to clean is take it apart(the dryer) gently/lightly wipe the sensor off. Be careful not to damage it, Good Luck Tim
Jan 16, 2011 | Miele T9820 Gas Dryer
The dryer doesn´t work
I had the same problem with my dryer. The Miele technician came and took a look at it. There was nothing wrong with any parts. My vent pipe was kind of crumbling, so he replaced that. He then scrubbed and washed the lint filter with dishwasher soap and
the green scrubber, He also did a PC update of the firmware. My
unit already had the latest version, but he did erase all the error codes.
After all these rather simple steps the dryer started working like a charm.
He said the most probable caused was gummed lint filter because of using the dryer sheets. Miele dryers are designed to prevent static cling and he advised not use these sheets as they contain wax-like substance.
I would suggest scrub cleaning the lint filter first and see if that helps.
Aug 02, 2010 | Miele T9820 Gas Dryer
Got a software update and now dryer is flashing all indicators
try turn power off to dry,if still not working call the tech back that did the software update
Apr 24, 2010 | Miele T9820 Gas Dryer
Clean filter / vent indicator stops unit after T9820 MIELE GAS DR
Call Miele and schedule a PC update. When the technician comes he will do the update, if needed, and will reset the error codes.
Apr 04, 2010 | Miele T9820 Gas Dryer
How do i replace the dryer belt on my t9820 miele gas dryer
Feb 04, 2010 | Miele T9820 Gas Dryer
Pop the top miele t9820 dryer gas
Jan 06, 2010 | Miele T9820 Gas Dryer
Miele T9820 runs except no heat
you have probably blown your thermostat especially if your condenser is blocked and hasn't been cleaned. this causes the unit to over heat and to protect the heater element the thermostat blows and breaks the electrical circuit. you will need a Miele service tech or service agent to repair the unit.
Sep 29, 2009 | Miele T9820 Gas Dryer
Check vent/lint indicator alert
Contact Miele 1800-999-1360 for a new blower fan
Jun 07, 2009 | Miele T9820 Gas Dryer
Miele T9820 Gas Dryer Logo
628 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
