Question about Apex Digital AT2402 24" TV
My screen is cutting off about an inch all round, how do i fix this? there is no tuner adjustment knob and i dont't know how to enter the service mode
    President:
  • 1,623 Answers
Are you meaning that you have a black border on all sides of the tv. IF you have then all you need is to change the aspect ratio of the tv or the cable satellite box you are using.
Posted on Apr 02, 2011
How to adjust oiler on mcculloch timber bear
some saws dont have oiler adjustments and if it worked before it dont need adjusting some things you need to check are you using the correct viscosity of oil have you checked the chain bar is clean and free of sawdust and dirt especially where oil enters the bar. after you reassemble ,start the saw and hold it 2 inches from the ground and rev the engine up and down several times watch for oil sling before you cut wood if you have trouble after all this try motor oil instead of bar oil
Feb 12, 2015 | McCulloch Garden
Tip
How to Build: Antenna Tuners
Get you a metal box about 4 inches X 4 inches. Use 2 female Cb antenna inputs from old Cb radios or Radio Shack. Get a old Am radio tuner out of a AM radio(530-1700 khz.) Buy or scrap up some copper wire; big gauge I used. Wound 8-10 turns about " 1 inch round close tight wound. Solder to AM tuner- C1 it shall say on top of Am tuner. Solder Center of Am tuner to Ground(Metal box). For those who know electronics the Tuner is 0-365pf Am band 530-1700khz types. OK, back to assembly. drill a hole for the Two Female Cb Inputs on both sides of metal box. Attach copper wire inside to center taps of Inputs on both sides. Drill a hole for Am tuner and Screw on its lock nut and place a knob on it. Solder all grounds of Female Antenna inputs and Tuner Ground and all Grounds to metal box. Use a washer and Bolt to lock down Grounds to Box. This is how it operates after you use a Jumper to hook to TX of Cb radio. Antenna to other side. Its just a simple L/C network. The Tx travels through copper wire(coil) inside box and gets shunted to ground by the right level of PF Capacitance. The operator tunes it in to get a close to 1.1 to 1.5 SWR ratio. Its simple, but helps with bad Antennas.
on Apr 01, 2011 | Radio Communications
How may i enter menu option in Rangs Tv Model - RC2180F ? Let me know plz.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Nov 13, 2014 | Televison & Video
Am I missing something simple? Read the manual and can't set the time or date on KDC MP628.
Step 1:
In standby mode:
Enter Menu mode:
Press the [MENU] button for at least 1 second.
"Menu" is displayed.
Step 2:
Select Clock Adjustment mode:
Push the Control knob to [FM] or [AM].
Select the "Clock Adjust" display.
Step 3:
Enter Clock Adjust mode:
Press the Control knob for at least 1 second.
The clock display blinks
Step 4:
Adjust the hours:
Adjust the minutes:
Push the Control knob to [Back Search] or [Forward Search].
Step 5:
Exit Clock adjustment mode
Press the [MENU] button.
Step 6:
Date Adjustment...
Select Date Adjust mode
Push the knob to [FM] or [AM].
Select the "Date Adjust" display
Step 7:
Enter Date Adjust mode
The date display blinks.
Step 8:
Selecting the item (day, month, or year) to
adjust
The items that are blinking are items that can be
adjusted.
Step 9:
Adjust each item
Step 10:
Repeat step 8 and 9 operation and adjust the
date
Step 11:
Exit Date adjustment mode
Step 12:
Setting the date format.
Select Date Mode
Select the "Date Mode" display.
Step 13:
Select the date format
Step 14:
Exit Menu mode
Hope this helps.
Cheers,
Scott
Jan 14, 2013 | Kenwood KDC-MP628 CD Player
I have a euro-pro sewing machine that i got second hand, came with no manual so i dont know whot to set it to basic stich it has all these knobs and i have no idea how to run it normally
Hello
The stitch dial for the length is located all the way on the right side of the machine and is factory set at the setting "3," which is a 3mm or 1/8 inch length. Turn the dial up or down to adjust the length. For example, the setting "4" is 4mm (5/32 inch) and "2" is 2mm (5/64 inch).
The width of the serged seam is dependent on the needle or by adjusting the knob for the width. With the left needle only sewing, the width is set to 7/32 inch, and with the right needle only sewing, it is set to 9/64 inches. Additionally, by pushing in the width adjustment knob behind the front cover, the stitching can be adjusted manually from 1/8 inch to 17/64 inch wide.
Jul 23, 2011 | Euro-Pro Deluxe 6130 Mechanical Sewing...
Windage and elevation not working barska 8-32*50mm
I doubt if there is anything wrong with your scope.
The Baraska model A10810 Reticle adjustments are 1/8 ( 1/8 inch) MOA (minute of angle).
For instance, Look at the top turret (The ELEVATION Adjustment Knob). You will see that there are little vertical 'hashmarks' all the way around the knob starting with a '0' then a series of the verticle hashmarks, then a '1' and another series of the marks, then a '2' and so on. YOUR scope will have 8 of those vertical 'hashmarks' between each 'number'. These little 'hashmarks are referred to as 'Clicks' or 'Minute of Angle' adjustments.
Now imagine that you are set up on the 100 yard line and you have fired a round at your target, say a one inch diameter dot or any size for that matter, and the bullet strike was one (1) inch LOW and two (2) inches to the RIGHT and of course you now want your next round to impact in the target dot.
To bring your bullets point of impact UP to coincide with your point of aim (you have your 'crosshairs or RETICLES centered on the dot), you will be turning the TOP adjustment knob CLOCKWISE, ONE 'click' at a time. EACH one of those 'Clicks' will actually move the horizontal Reticle UP (Elevation) or DOWN 1/8 of an inch at a time. If the bullets point of impact was 1 inch LOW, you would need to turn the adjustment knob clockwise Eight (8) clicks which will equal ONE (1) inch.
Now you must adjust the knob on the RIGHT side of the scope. This one is the WINDAGE Adjustment knob which controls the VERTICAL Reticle and moves the point of impact Right or Left. This knob will also have the 'hashmark' increments around its perimeter and like the Elevation knob each 'Click' will move the Reticle 1/8 of an inch but in this case the Reticle and point of impact moves Right or Left.
Remember the bullets point of impact was 2 inches to the RIGHT. This means you must adjust the Reticle or point of impact to the LEFT so that your point of impact will coincide with your point of aim and will be in the target dot. Turn the adjustment knob COUNTER CLOCKWISE Sixteen (16) Clicks. Keeping your POINT of AIM (crosshairs centered on the dot), your next round should be inside the dot and you can then fine tune it from there.
As you can see from this example, the Reticle (crosshairs)and point of impact does not travel very far at all inside your scope at the 100 yard distance so it is not hard to imagine that you thought they were not adjusting to get you on target, when in fact they WERE adjusting, but in tiny increments.
Now, as you create more distance between you and your target, these 'tiny' increments and point of impact will be larger as your distance increases. For example, at 200 YARDS each 'click' will move your Point Of Impact 1/4 of an inch right,left,up, or down. So if your bullet point of impact was one (1) inch low from the 200 yd line you would adjust your Elevation Reticle 4 Clicks to raise your point of impact in order to be on target. At the 300 yd line each Click will adjust the point of impact up,down,right or left, ONE (1) inch.
If you wish, I would be happy to walk you through the 'ZEROing In' of your scope and rifle even if you do not have a Zero Bore Scope. With-in about 9 rounds you can be hitting where you are aiming instead of 'chasing' bullet holes all over the paper.
If you are interested, respond back and I will be glad to assist you. Enjoy. :)
Apr 07, 2009 | Optics
Picture is cut off on the bottom of my Hitachi 57F500
Verical position is hard to adjust and is in service menu. A service manual will get you there, but you might get lucky with the vertical size adjustment. If you open the front of the TV, the vertical size is adjusted with a knob on the deflection board. Remove the speaker grille and take off the access panel. You will see two knobs, one horizontal and one vertical. Be careful, those red wires have 30,000 volts on then, don't touch anything but those knobs. If its just an adjustment, the v-size knob will fix. Set it so ESPN ticker is just above the bottom of the screen. *Service mode - the manual tells little but entering is done by "press and hold the input button, press the power button, release both after you hear HV come up" .. the v-pos parameter is in there, but this manual doesn't say where or how to adjust, procede at your own risk. If you get into trouble, pull the power so you don't save any settings. I believe you just navigate through the menus to find the parameter and use arrows to adjust. Enter may save. Sorry the service manual I have tells nothing much.
Dec 07, 2008 | Hitachi 57F500 57" Rear Projection...
02 VW GTI Radio says CHECK
This worked for me (radio in 2003 VW Golf):
Radio says "CHECK" but is otherwise unresponsive. Turning car or radio on/off doesn't help.
On the far right of the radio, there's a round TUNER button. Press it for 5 seconds. Your screen will then show some digits, but the unit is still unresponsive.
Press tuner button again for 5 seconds. Radio should now be 100% again. Let me know if this works for you.
Nov 21, 2008 | 2002 Volkswagen GTI
My VCT/DVD will only play in black and white
tv is probably off the right channel or if it is an old tv you might need to manually adjust the tv tuner by pushing down and turning the round tuner adjust knob one way or the other.
Apr 28, 2008 | Televison & Video
Service Mode for Apex PF2720
On a standard PU1 chassis use the following:
1. Decrease the volume to 0
2. On remote press and hold the MUTE button till the color of MUTE displayed changes color. At the same time press MENU on the front of the Tv.
CH +/- to select
Vol +/- to change value
All other chassis:
Decrease the volume to 0, Press mute and video at the same time.
Adjust the TV with menu select buttons on remote.
Exit with the power button.
Hope this helps.
Bill
Nov 25, 2007 | Apex Digital PF2720 27" TV
Apex Digital AT2402 24" TV Logo
173 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
