Question about Teac FD-05PUB External Floppy Drive
I have xp in my pc. I used usb disk driver but it did not work ... I do not know where is the problem
  • 8,064 Answers
You must go to the BIOS setup and enable USB floppy drive support, and while you are at it, enable the so-called legacy drive support. Save the configuration and restart the computer.
How you access the Bios setup utility depends on your computer: At boot, you press F1 or F2 or F10, .... Check your user's manual.
Posted on Aug 28, 2011
I installed linux ubuntu remix on my ASUS Eee 1001PXB-BK301 multiboot, then i deleted ubuntu after not using it anymore using windows xp disk mangement and found myself without a mbr with grub saying grub...
What you need is SATA controller drivers to be downloaded while starting windows xp disk or ERD Commander.
Since Asus Eee does not have an internal Floppy Disk Drive (FDD), you need to use an external USB FDD.:
Step one: You would like to connect an external USB FDD.
Step two: copy scsi/sata Hardware Access Layer (HAL) Drivers for you laptop to a floppy disk
Step three: during the XP boot process press F6 and follow the prompts to insert a floppy disk with HAL scsi/sata drivers.
Step four: Finish the boot process and run fix MBR.
There is another easy way:
If you can get a Knoppix USB flash drive, you can boot it up from Knoppix and run the following command in the terminal window: sudo ms-sys -m /dev/sda.
Hope This Helps
Jan 29, 2011 | ASUS Eee PC Netbook
I have a Pfaff 2170 with a USB connection to my PC. It won't run using either Windows XP or Windows 7. I ran a fix hardware check--the computer does recognize it has something new plugged in, and the...
If you have the original 3D file manager disk, the drivers are on there. In XP, With the sewing machine unplugged from the computer, insert the disk in the cd drive and explore the disk. Copy the "drivers" folder to your desktop. Plug in the Pfaff 2140/2170 to the usb port. Windows will ask for a driver disk. browse to the drivers folder on your desktop and open it, windows will highlight the driver it needs and click "OK". This worked on my wife's 2140 upgraded to 2170 software and you must always use the same usb port, or go through this routing again.
Nov 20, 2010 | Computers & Internet
Belkin FSD7050v4 driver for Windows 7
just installed my belkin wireless g usb adapter on windows 7 64 bit down loade driver from belkin right click run in compaterbilty mode windows vista service pack 2 and install
Apr 28, 2009 | Computers & Internet
XP INSTALLING
The drivers can be obtained from this website.
If you haven't dumped the OS, use DriverMax to backup your drivers to a USB stick and restore them under XP.
If you have a second computer and are feeling adventurous, you can use the drivers, your XP disk and a program called nLite to create a custom XP disk with the drivers built in. You can also load Service Packs in case your disk is out of date.
Dec 15, 2008 | Acer Aspire 4720 Notebook
Need to install driver for sony digital 8 700x
Please mention exact model number of your Sony camera and Windows version in your PC to help you out.
Nov 27, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
Please help me to solve my problem, whenever i need to install window,Mother board (P5RD1-VM) require sata drivers from floppy drive and you know floppy is hard to find, or where from i get the floppy in...
use Nlight research this software in the net and you will find the answer works on laptops too the process is called slipstreaming. the process of witch you integrate the sata driver to the xp intallation disk to provide the necessary driver you required first download the driver you need then use Nlight to integrate the driver to the xp installation disk of course you will need another writable disk to accomplish this. thank you
Nov 21, 2008 | ASUS P5RD1-VM Motherboard
Cannot install Windows XP Professional on Acer Aspire 4720Z Laptop
yu need to go to the the bios before you start the installation and change the Sata hard disk mode to IDE.then it will detect the hard disk.
May 05, 2008 | Acer Aspire 5610-4648 Notebook
I am not able to use my san disk 2 gb on my office system on xp
Just a few questions about your system and we should be able to resolve your problem fairly quickly. Firstly is your xp a service pack 2 installation, secondly is your usb ports usb 2.0, and finally does other usb devices work properly when plugged into the same physical usb port on your pc?
Scan disk drives have the driver and application software on a partition built onto the drive thats not accessible for write access, meaning you cant format that partition. Other systems see that partition just fine, but it seems your system is having trouble doing so. Theres a few reasons for this trouble. If you can provide me with the detail i need about your system im shure we can resolve your issue promptly.
Nov 29, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Teac FD-05PUB External Floppy Drive Logo
137 people viewed this question
Top Teac Computers & Internet Experts
Starnley Johnwells
Starnley Johnwells
k24674
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
