Question about Refrigerators
My U-Line 1175bev refrigerator has a flashing "E5" error code, and it's now hot inside.
2 Suggested Answers
SOURCE: E5 flashing error code
I have the same error on my U-Line beverage refrigerator. U-Line said the error indicates the thermostat was out of range for over 12 hours (perhaps due to a recent power outage). My fridge seems to be working just fine so I am not planning on calling a technician until something more serious breaks down.
Posted on Aug 11, 2010
Glass door has condensation outside and slightly inside. 75bev
That would be normal if the day is very humid. Any cold surface will change the water in the air to a liquid. Like steamed up glass when you shower.
Aug 20, 2016 | U-Line 1175BEV Beverage Cooler
Why I'm getting E5 error code on my Haier refrigerator
you can go and google to get the reason for the error code E5. You will need to put in the model# along with the brand.
Jul 23, 2015 | Haier Refrigerators
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
Error code e5
Hi friend, I appreciate your post!
I understand that your Electrolux refrigerator is showing an "E5" error code and not cooling. "E5" typically stands for Showroom mode, you can press and hold the "Up" and "Down" keys simultaneously and that should restart your refrigerator back to normal operation. Could you reply back if that corrected the issue? Thank you. -Matt
Jul 27, 2014 | Electrolux Refrigerators
Not cooling
You can ohm the compressor to see if it is shorted but if the compressor is running it cannot be the overload or relay , if not running sometimes you can pull the relay and shake it if you hear any rattling in it it is bad
Apr 01, 2013 | U-Line 1175BEV Beverage Cooler
Audible alarm sounded--"F2 "appeared on
Your model is actually a 911. Roper (Whirlpool)
The F2 error code is
E0 - Shorted keypad (also called touch pad)
E1 - Keypad cable unplugged
E5 - Cancel key drive line open
E6 - Cancel key drive line open
Solutions:
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 30, 2011 | Ovens
I am getting a flashing message E5 where the temp is normally displayed on my U-Line Beverage Center. I could not find info in the manual on this code?
E5 means that the unit is 10 degrees warmer than the set point for more than 12 hours. You may need service to help you find out if its a sealed system or maybe a thermistor in the wrong location
Sep 28, 2009 | U-Line 2175BEVS-01 Uline Beverage Center...
Apr 25, 2009 | Refrigerators
Refrigerators Logo
236 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
