Question about Apple iPhone Smartphone
Iphone 4 voiceover makes it impossible to enter passcode
    Problem Solver:
  • 8 Answers
Restore the iphone using the restore function of iTunes on the iPhone page when it is plugged in. This should resolve this query.
Posted on May 04, 2011
Can I make a new password
Yes, you can
Use passcode with your iPhone iPad or iPod touch
Set your Passcode
    1)Go to settings > Touch ID & Passcode. On devices without Touch ID, go to Settings > Passcode.
    2)Tap turn passcode on
    3)Enter a 6-digit passcode
    4)Enter passcode again to confirm Change passcode or passcode settings
    To change your passcode or passcode settings, go to Settings. Touch ID and passcode. On devices without touch ID, go to settings > passcode.
Nov 19, 2015 | Cell Phones
How do I turn off the security on my iphone4s
iOS 7 instructions:-
1. Open "Settings" App on your iPhone or iPad, or iPod Touch devices.
2. Scroll down below and select "Touch Id & Passcode" or simply "Passcode" option
3. Enter your current passcode to continue.
4. Then scroll down and tap on "Turn Passcode Off". Enter your current passcode to continue. Se below.
iPhone:
Oct 07, 2014 | Apple iPhone4 4G iPhone 4
I need to disable the pass code on my iPhone 4s
1. Open "Settings App" on your iPhone
2. Then select "General" from left panel
3. Select "Passcode Lock" on right side. Enter your current passcode to continue.
4. Now tap on "Turn Passcode Off". Enter your current passcode to continue. Now Passcode lock will be turned off.
May 30, 2014 | Cell Phones
My iPhone 4 is locked on VoiceOver. I can't get past my password to turn it off. Can someone help?
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Jan 11, 2013 | Apple iPhone 4 Black Smartphone
I forgot my iPhone Passcode. What can I do to unlock it?
iPhone setting:*
- Auto-Lock: 1 Minute;*
- Passcode Lock: On, require passcode immediately, after 15 min or 4 hours etc;*
- Network: Turn 3G Off
Scenario 1: Home screen is active with screen on*
1. Press power button for seconds until asked to '"slide to power off"
2. Slide to power off
3. press power button to turn on iPhone
4.*When asked to enter passcode, touch the "Cancel" key, then slide to unlock
5. bypassed passcode
Scenario 2:*
1. On the screen of being asked to enter passcode, press power button for seconds until asked to '"slide to power off"
2.*Slide to power off
4.*When asked to enter passcode, DO NOT touch any key on the screen, press power button for seconds until asked to '"slide to power off"
5. Slide to power off
6. press power button to turn on iPhone
7.*When asked to enter passcode, touch the "Cancel" key on the right bottom corner, then slide to unlock
8. bypassed passcode
Notes:
1. When Network setting changes to Enable 3G: ON, "3G" signal shows up, passcode CANNOT be passed through
Go to a underground parking lot or a lift where 3G signal is weak, when 3G signal switches to "E" (Edge), passcode CAN be passed through following above steps
2. When no 3G or Edge signal, above steps don't work
Conclusion:
Seems passcode security is related to network status
Possible security hole under Edge
Jan 15, 2011 | Apple iPhone 3G
I accidently enabled the voiceover on by IPhone and need to disable it. The home screen says "slide or tap twice to unlock". I slide it by tapping twice (voiceover on) and then get the 4 boxes to enter my...
If you have your phone synced with itunes you can hook your phone to your computer by opening itunes on your computer and connecting your phone. Then click on your IPhone when it appears in the column on the left. Choose the option to restore to last backup or reset to factory defaults.
Hope this helps
Aug 17, 2010 | Apple iPhone 3G
Ipod touch is disabled itunes won't connect says the ipod needs a passcode before connecting to itunes
If you have forgotten your iPhone’s Passcode you will need to restore your phone via iTunes.
1. First you have to put your phone into the restore mode which is a slightly fiddly process.
2. Plug your iPhone into your PC or Mac with the USB cable
3. Press and hold the power button at the top and then slide to power off the iPhone
4. Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
5. After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
6. Open up iTunes and click on the Summary tab
7. Click on Restore to restore your iPhone. This will reset all your iPhone’s setting to the factory defaults, including the Passcode.
You should then follow these steps below to activate the passcode again.
  1. Click the Home button to bring up the main menu
  2. Click on Settings
  3. In the Settings screen click on General
  4. In the General screen click on Passcode Lock
  5. This will open the Set Passcode screen. Enter a memorable 4-figure code and re-enter it when prompted
  6. You will now be at the Passcode Lock screen. You can change when you are prompted to enter the Passcode. The default setting – Immediately – means you will be asked to enter it as soon as your start using the iPhone. But you can change the setting so that the prompt appears after a certain period of use
  7. Press the Home button to return to the main menu.
Jan 15, 2010 | Apple iPod touch
What do i do after locking my iphone with too many passcode attempts
Jan 15, 2010 | Apple iPhone Smartphone
Forgot my passcode
Bad News... you may have to Restore from iTunes. Here is some info from the users manual:
Passcode Lock By default, iPhone doesn’t require you to enter a passcode to unlock it. Set a passcode: Choose General > Passcode Lock and enter a 4-digit passcode, then enter the passcode again to verify it. iPhone then requires you to enter the passcode to unlock it or to display the passcode lock settings.
Turn passcode lock off: Choose General > Passcode Lock, enter your passcode, and tap Turn Passcode Off, then enter your passcode again. Change the passcode: Choose General > Passcode Lock, enter your passcode, and tap Change Passcode. Enter your passcode again, then enter and reenter your new passcode.
If you forget your passcode, you must restore the iPhone software. See “Updating and Restoring iPhone Software” on page 204.
Set how long before your passcode is required: Choose General > Passcode Lock and enter your passcode. Tap Require Passcode, then select how long iPhone can be idle before you need to enter a passcode to unlock it.
Nov 10, 2009 | Apple iPhone 3G
Apple iPhone Smartphone Logo
211 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
