Question about Amana Refrigerators
Compressor does not come on. fan runs. lights come on
    Sergeant:
    Champion:
  • 202 Answers
Hi.... yeah you have a bad run relay and start capacitor
Posted on Apr 02, 2011
A amana French door fridge no fan water or.icemaker lights come on but no fan turning on or cold
Many Amana model fridges have the freezer fan wired through the bi-metal thermostat that is clipped to the evaporator. Either your compressor has a bad start device and that is why it is not cooling, or the compressor IS running and the unit has lost its refrigerant charge. Running compressor with no cooling = buy a new fridge.
Compressor hot, but not running = start relay replacement to get the compressor going. Start Device 8201786
May 13, 2016 | Amana Refrigerators
My kenmore fridge with bottom freezer, model#596.785.83801. Both fridge and freezer won't stay cold. Fan on and lights are on. Help!!
Check to see if the compressor in back is running. It could need a new compressor start device. If it is running it could need a new compressor. The compressor cooling fan could be stalled and the compressor is overheating.
Sep 26, 2014 | Refrigerators
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
The refrigerator has quit working. Lights come on and fan appears to be running. Not cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Oct 12, 2010 | Maytag MSD2756G Side by Side Refrigerator
The Unit does not cool. The fan, lights, etc run
check if the compressor working if it working and you get frost in your freezer back panel then your problem is in your freezer area but if your compressor not working then and the fan next to it working then the starter unit for the compressor is bad....let me know if you need more help
911service today . com
Jan 01, 2010 | Whirlpool ES5FHAXS Side by Side...
The lights are on in the refrigerator and freezer, but neither unit is cold. The thermometer on the refrigerator registers 55 degrees. Why is it not cooling??
First, make sure the compressor is running. It is underneath the refrigerator body. If the compressor is running, and you still don't have cold air, check the compressor fan. This should be close to the compressor. This fan draws air across the coils and removes heat from them. The compressor and fan must both be operating properly to get cold air.
Oct 18, 2009 | Refrigerators
Compressor and Compressor Fan Not Working
Rotate the dial on the defrost thermostat, a big click is when it goes into defrost, a little more and it should turn the compressor back on. By overload protector, do you mean the one under the compressor cover?
May 03, 2009 | Refrigerators
Refrigerator not colling properly
Let it run until you have a problem again then look at the back wall of the inside of the freezer, if there is frost then it's not defrosting and that would be your problem (usually the defrost heater). If you don't see frost then you need to determine if the compressor is running or not. It's possible to hear the two fans run, but not the compressor. If the compressor is running, along with the 2 fans, then it is a sealed system problem and usually not worth fixing. If it's not running you'll need to check the compressor start relay on the side of the compressor. It is possible for a bad compressor to cause the relay to fail, so replacing it may or may not get you going again.
Jul 21, 2008 | Kenmore 53642 / 53644 Side by Side...
Lights on in frig and freezer but no compressor or fan running
Remove and test the fan. If it has failed the Compressor may not run.
May 03, 2008 | Amana ABB1921DE Bottom Freezer...
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
