Question about Samsung DV337 Electric Dryer
Two sets of sheets and the dryer wads the sheets in a ball and takes forever to dry. Then I untangle them and try again and still the same wadding up. Checked with other front loader owners and it doesn't happen with Whirlpool etc.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
I have Design a new solution it is the Dwadder.
Dwadder made from HDPE plastic. The Dwadder is the first ever Dryer Device that does dry your sheets and blankets faster! The Dwadder keeps your sheets and blankets from wadding up in the dryer. This will save you Time and Money when drying. Dwadder can cut your drying time up to 30 mins or more. Two sheets or blankets can be strapped to the Dwadder at a time to keep from wadding up in the dryer.
One of the most time-consuming uses of a dryer is drying blankets and sheets. The reason it takes so long is the blanket or sheet can be twisted into a tight wad or ball during the drying cycle. Once this happens the dryer is incapable of drying the center of the wadded blanket or sheet. The solution today is to take the blanket or sheet out of the dryer halfway through the drying cycle and unwad the bundle of sheets or blankets. Then place the blanket or sheet back into the dryer to restart the dryer cycle over and over again until the blanket or sheet is dried. If you forget to unwad the blanket or sheet when you get ready to make the bed, the blanket and or the sheet will be wet.In order to fix this problem, the Dwadder is strapped to the sheet or blanket using a silicone cord before it is placed in the dryer. Once the dryer is started the blanket or sheet will wrap around the Dwadder allowing a space to be in the center of the blanket or sheet. With the space that is created by the Dwadder the center of your blanket and sheet will dry faster and will not roll into a tight ball or cylinder shape. This will help save time drying your sheets and blankets. The device will also prevent wadding of your sheets and blankets so you don't have to unwad your blankets and sheets half way between the drying cycles.
How to Use the Dwadder
Simply pull half of your blanket or sheet out of the washer. Then pull the silicone cord to slide the blanket or sheet between the silicone cord and the Dwadder. Slide the Dwadder to the center of the sheet or blanket then put your blanket or sheet in the dryer with the Dwadder attach to your blanket or sheet. You can use both silicone cords for two small blankets or sheets just don't place 2 blankets or sheet on top of each other or it will take longer to dry. For Video instructions please go to the website at www.Defuturesolutions.com or Youtube.
Two sets of sheets and the dryer wads the sheets - dewadder black back ground cut out-k3utksoxgppon4bw3hvininy-5-0.jpg
Posted on Nov 20, 2017
3 Suggested Answers
glasgowlove
  • 40 Answers
SOURCE: When I dry king size sheets in the dryer they form
Try bounce .
Posted on Oct 29, 2009
  • 5 Answers
SOURCE: We purchased a Samsung DV419AE
dry the blanket alone and come back several times and fluff the blanket up keeping it from balling up. It's not the dryer's fault.
Posted on Nov 26, 2010
Clothes roll into a ball on matag dryer
THE DWADDER
One of the most time-consuming uses of a dryer is drying blankets and sheets. The reason it takes so long is the blanket or sheet can be twisted into a tightwad or ball during the drying cycle. Once this happens the dryer is incapable of drying the center of the wadded blanket or sheet. The solution today is to take the blanket or sheet out of the dryer halfway through the drying cycle and unwad the bundle of sheets or blankets.
unwad the blanket or sheet when you get ready to make the bed, the blanket and or the sheet will be wet. In order the fix this problem the Dwadder is strapped to the sheet or blanket using a silicone cord before it is placed into the dryer. Once the dryer is started the blanket or sheet will wrap around the device allowing a space to be in the center of the blanket or sheet. With the space that is created by the
The Dwadder will save you time and money. It can save up to 30 minutes off your drying time. This will save you energy. You will save time and worry less about your blanket or sheet not being completely dried when the drying process is finished. As an added feature the HDPE plastic ball opens to allow for a dryer safe fragrance to be placed inside the ball. This will reduce the use of dryer sheets.
We would love to have you as our customer. We know that the Dwadder will save you time, money and
lower the frustration of drying laundry.
For more information and
videos on how to assemble and use the Dwadder come visit us at
WWW. Defuturesolutions.com
http://www.defurturesolutions.com/
Jan 10, 2013 | Dryers
Tip
How to make a forever dryer sheet
Wad up a ball of aluminum foil till it is the size of a baseball. Put it in your dryer and leave it there. The aluminum will remove static from your clothes and also works as a fabric softener. No more need for dryer sheets after every load.
on Jan 09, 2010 | Dryers
When I dry sheets they ball up into a twisted wad and do not dry evenly. Do you have advice for this problem?
Lisa I find if you put sheets in with other items such as towels this can work to prevent them rolling into a ball and not drying evenly.
Jan 20, 2011 | Kitchen Ranges
Sheets and bedding get balled up in dryer and don't get dry.
DESIGNING FUTURE SOLUTIONS defuturesolutions com
Feb 02, 2018 | Samsung DV448AEE Electric Dryer
Sheets twisted in a tight wad
hi there......this is usually caused by older dryers which didnt have a reversing tumble facility...or if a lifter is missing from the drum..check that your dryer is or is not a reverse action....and if it is a reverse action that it actually does reverse...you may have a programmer fault if its not reversing
regards Sir Galahad
Aug 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sheets wind together in a damp ball
I have a different model Bosch dryer, but I have the same problem.
I've found that the flat sheets dry okay if you have them in with other things (like pillowcases and t-shirts). I learned long ago though that you can't put those things in with deep fitted sheets; the little stuff winds up caught in the corners in damp wrinkly wads.
So I dry the fitted sheet separately, and throw in a couple of clean tennis balls. They're noisy, but harmless, and they keep the sheet from balling up.
Oct 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Can i unlock a nintendo wii console to play NTSC games
right u want to soft mod your wii it is realy easy to do this ist u need is an sd card
http://bannerbomb.qoid.us/aads/aad1f_v108.zip
http://www.yafaze.com/wii/files/4.0softmod.rar
Put the contents of both zips on your SD Card as it is in the zip, just drag all to SD Card.
Go to Data Management then choose Channels followed by SD
Choose "Yes" to load boot.dol
LoadMii will then load.
Press "A" on the WiiMote.
Go down to DowngraderIOS35.dol and run it by pressing "A" on the WiiMote.
Choose downgrade IOS35 and then let it go, then choose exit (ignore the patchmii and dvdx)
You'll be back in LoadMii now.
Go down and run Wad Manager 1.4 by pressing "A" on WiiMote.
Just select normal settings (don't change IOS)
Install IOS35.wad.
Exit Wad Manager 1.4 by pressing "HOME"
You'll be back in LoadMii.
Run Wad Manager again, Select IOS35 when it asked what IOS to use.
Install the CIOSv7.wad.
Press "Home" to exit.
Then Run Wad Manager again.
Tell it to use IOS249.
Install IOS36.wad, BUL3g.wad & HBC.wad
Sep 29, 2008 | Nintendo Wii Console
Can someone please help
Ok, the PSP emulator is a program that emulates the work of PSP on your computer, and take a portion of your PC's CPU to emulate the PSP's Processor. Or you can say it's a program that runs your PSP games through a window. To Run your "Doom on PSP" I can paste some text from the readme.txt inside this file: http://psp-news.dcemu.co.uk/files/doompspv005plus.zip Release Notes for Doom-PSP 0.05 plus: To Install fw 1.0 and 2.0(with loader) 1. Create Doom dir under Games. 2. Copy save, wads, inst, config.ini, and timidity.cfg into doom folder. 3. copy eboot.pbp from fw10 into doom dir. 4. copy any main wads into doom/wads dir and pwads into doom/wads/pwads dir. 5. launch game, select wads and play! to set up controls press L+R+Start and follow instructions. fw 1.5 1. Create Doom dir under Games. 2. Create Doom% dir under Games. 2. Copy save, wads, inst, config.ini, and timidity.cfg into doom folder. 3. copy eboot.pbp from fw15/Doom into doom dir. 5. copy eboot.pbp from fw15/Doom% into doom% dir. 4. copy any main wads into doom/wads dir and pwads into doom/wads/pwads dir. 5. launch game, select wads and play! to set up controls press L+R+Start and follow instructions. Then give us feedback. Play nice with your PSP. Goodluck
May 17, 2007 | Sony PlayStation Portable (PSP) Console
Samsung DV337 Electric Dryer Logo
156 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
