Question about Acer Computers & Internet
Touch pad is very sensitive,can't drg cursuer to another point I want to go to.How do I remedy this?
    Habit-Forming:
    Scholar:
  • 76 Answers
Try going to Start > Control Panel > Mouse
You should be able to find the options to change the sensitivity of the touch pad there. If you can't find the Mouse option in Control Panel, click on the Classic View option on the left (for Windows 7 change the View option in the top right to Small Icons).
Posted on Apr 02, 2011
The cursor jumps from line or field on its own...I could typing away and before I know it, the cursor has moved to another field or to the middle of another word! real pain in the ****
You will probably want to adjust the pressure sensitivity on your laptop's touch pad to alleviate this problem. If you have Windows, enter the control panel from the start menu.
1. START > Control Panel
2. Find Mouse or Pointing Devices.
3. Enter the Pointing Devices Control Panel.
Things can vary a bit in this section. So you should look for anything that deals with Pressure settings or Pointing Settings. One setting should be labeled "Touch Sensitivity." This setting controls how much pressure is required on the touch pad.
-If you move the setting lower (or move the slider to the left) this decreases the sensitivity. It is harder to accidently move the cursor if you brush the touchpad while typing.
-If you move the setting higher (or move the slider to the right) this increases the sensitivity. It is easier to accidently move the cursor if you brush the touchpad while typing.
(Note that in some configurations, these are opposite - left to increase senstivity and right to decrease sensitivity).
Depending on your laptop there may also be a setting labeled Touchpad Pressure. It's a setting that resgisters if you are accidently leaning on the touch pad. It's designed to reduce the chance of accidental clicks or motions. This setting is generally controlled the same way the Touchpad Sensitivity setting is controlled, through left-right sliders. I've found that keeping the touchpad sensitivity low makes it easier to avoid accidental cursor motions. I also keep the Pressure setting relatively high as well. One thing you'll note that if you adjust these settings to far into one extreme or the other, you will have difficulty using your touchpad. Fine tune these two setting until you achieve the results you want.
Dec 05, 2010 | Computers & Internet
The touchpad is so sensitive I can't control it
You've got it, your touching the touch pad, annoying isn't it.
You can try a couple of things,
1) Go to Start - Control panel - Mouse/Touch panel - and see if you can reduce the sensitivity or,
2) Disable your touch pad (Same route) and use an ordinary mouse instead. That's what the wife does.
Jul 09, 2010 | Toshiba Satellite A100-S8111TD Notebook
Touch pad tapping on hp special edition L2310CU stopped working. Pointer works fine, buttons work fine. Can you help?
Go to control panel and check your touch pad settings.
Check the sensitivity of your touch pad device ,increase the sensitivity.
if it doesn't ,contact the nearest hp service center
Apr 22, 2010 | HP Special Edition L2000 LiveStrong Mobile...
Compaq presario V3105TU touch pad not sensitive
Try goign into the touch pad settings and tunring the sensitivity way up. either by its software or goto the control panel and mouse settings. hope this helps in some way.
Dec 03, 2009 | Compaq Presario Notebook
My touch pad is SUPER sensitive, when I type, my cursor ends up all over the place. I read up on hitting the f7 key, but I am totally computer illiterate. When you guys say hit the function key, do you...
From Dell:
Customizing the Touch PadYou can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start keyboar4.jpg , and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad.
    • Click the Touch Pad tab to adjust touch pad settings.
  5. Click OK to save the settings and close the window.
Oct 06, 2009 | Dell Inspiron 1526 Laptop
Pointer jumps around on screen when touching touch pad
hello, have you tryed adjusting the sensitivity of the touch pad to a less sensitive touch ?
Mar 31, 2009 | Acer Aspire 5610 Notebook
Cursor Shift
This could be either a driver glitch or the touch pad is going out, both are common on these models. Start by uninstalling the drivers for the touch pad (some times referred to as the synaptic pointing device), then restart the machine. The machine will find the touch pad and reinstall the drivers automatically. If it's a simple glitch, this will fix it. If it persists, then the pad is failing and will need replaced. The only other thing you might try is to adjust the cursor speed or touch pad sensitivity from the control panel. This will sometimes help to dampen the effect, but usually won't get rid of it entirely.
Sep 04, 2008 | Dell Latitude C610 Notebook
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Aug 26, 2008 | Acer NSK8458AN Keyboard
Sensitive touch pad
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Oct 02, 2007 | Dell F3534 Touchpad
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
