Ventless gas logs sets off smoke alarm - Heating & Cooling
2 Suggested Answers
  • 90 Answers
SOURCE: ventless gas log odor
is it L.P.G if it is does odor come when bottles nearly empty cause if it is its what they mix with the gas to give it an odor so you can smell the gas and is usually really bad when bottles are nearly empty its a common thing if this is it!
Posted on Nov 18, 2010
What makes a ventless gas heater put out carbon monoxide fumes
Any gas appliance that burns gas puts out Carbon Monoxide. The trick is to make it not too much, however, how much is too much. Read this;
http://www.ventfree.org/content/view/42/18/
and there are warnings here too;
https://www.angieslist.com/articles/are-ventless-fireplaces-safe.htm
and a list of the potentially dangerous gases they omit;
https://www.abe.iastate.edu/extension-and-outreach/carbon-monoxide-poisoning-unvented-gas-space-heating-appliances-aen-204/
I would not use one unless I had good ventilatioon and a better Carbon Monoxide alarm.
What makes ventless gas heater put out carbon monoxide fumes Google Search
Jan 19, 2017 | Heating & Cooling
Soot from ventless gas heaterlogs
Oh really? That's too bad. Do you have a question to ask about lawn mowers though?
Sep 19, 2014 | Poulan Pro PR550N22SH 22Inch Briggs ...
Emberglow ventless gas logs (set to burn on porpane gas). Pilot lights, but not logs.
It needs 14'' wc to work , hose could be too small for load .
Dec 06, 2012 | Heating & Cooling
What causes black soot to smoke up our complete house with ventless logs
Take the pilot and burnner assembly all apart and blow it out with compressed air then reassemble and make sure that the air shutter is totally open. The soot is cause by a bad air/fuel misture that is too rich and cause carbon to form from incomplete combustion. If the burner continues to make soot then reduce the gas pressure to the gas log at the pressure regulator.
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 24, 2010 | Empire DV-215 Direct Vent Natural Gas...
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Jan 03, 2010 | Desa International Unvented Gas Space...
Ventless gas log odor
kINDLY HELP WITH a description of this odor. If it is setting off your smoke alarm the flame or combustion is not complete or thorough.Are these new loggs or previously used without problem?Is the flue open on the chimney? The venting is apparently very poor if at all and the house is fulling with fumes. Turn the gas off, Open up the house to clear the air and check the flue, making sure it is open. Be safe.Ned
Oct 07, 2009 | Heating & Cooling
Oven smells like gas when on
If the oven is new and has never been used, it should be cured before using. There is a curing your oven page in all manuals before use. You have to wash and burn off all the chemicals used in making the thing. Are u sure it sets off the smoke alarm and not the carbon monoxide alarm. Be careful some alarms are equipped with both now a days and people cant tell the difference. Get your gas company there to check it. Carbon monoxide is undetectable to the nose and is deadly so please be very careful! If there is smoke and u have cured ur oven then there maybe some old food on the burner, remove the bottom plate and check. If there is no smoke and no food on the burner then u need to change ur ignitor. It maybe old, cracked or both. Typical repair cost on high end range is 300 - 400 for 1 ignitor. Good luck. And I urge u to see if it is Carbon Monoxide!
Sep 04, 2009 | Hotpoint RGB745 Gas Kitchen Range
Will not light, sems like gas is not geeting to logs
Try taking a can of compresssed air and blow it in the pilot assembly wait about a min and try to light it. it is normal if it smells funny.
Nov 01, 2008 | Desa International CCL3924PTA 24" LP Gas...
Heating & Cooling Logo
178 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
