Question about HP Compaq 6720s Notebook
I have just recieved external speakers for compaq 6720s but not sure where to attatch it,please help.
    Scholar:
  • 57 Answers
You would normally connect external speakers to a laptop using the laptop's headphone port. The cable coming from the speakers would normally have a green connector on the end and would plug directly in.
If you have a bigger, more complex speaker system then you would need to determine what connections are possible to the speakers and what outputs are provided on your laptop. The most common audio out ports (for PC's, not so much laptops) are SP-DIF Coaxial and Optical. These would provide full digital surround sound signals from your computer but are not found commonly on laptops.
My best guess would be the above green connector to headphone port setup. The rest is a bit optimistic for an everyday laptop.
Posted on Apr 02, 2011
Compaq 6720s internal speaker not working
Make sure the internal speakers are selected in the output section of Sound mixer. These are not digital speakers.
Apr 03, 2014 | HP Compaq Computer Speakers
No sound in the inter speaker! except if I connect external speaker or headphones!!!
As sound is coming to external speaker then need to check the connection or change your laptop speakers.
Aug 21, 2010 | HP Compaq 6720s Notebook
I have a laptop which is hp widows vista,compaq 6720s. my little boy went on it and the screen side is has crack and doesn't work. what should i do HOW MUCH DOES IT COST TO FIX IT
The replacement panels for the Compaq 6720s range between $85.00 USD and $110.00 USD depending on where you order them from. The replacement is a relatively easy procedure, but I don't recommend it for a first-time novice do-it-yourselfer.
Here are links to some places where you can order the display panel:
http://www.blisscomputers.net/hp-compaq-6720s-laptop-lcd-screen-15-4-wxga-glossy-ccfl.aspx
http://www.screencountry.com/index.php?section=products&model=HP%20COMPAQ%206720S&brand=HP-Compaq
http://www.r3electronics.com/index.php?option=com_virtuemart&Itemid=1&page=shop.product_details&flypage=flypage.tpl&product_id=1147&category_id=38
Now the good news is you can still use your laptop if you have an external monitor. You can use the appropriate "Fn" key combination to switch your display output to the external device. I believe for the Compaq 6720 is the "Fn" key & the "F4" key. Connect the external monitor then power on your machine, Press the Fn and F4 key simultaneously until you get the display showing on the external device.
One more thing, you will need to go set the laptop to not do anything when the lid is closed. You can do this via Start -> Control Panel -> Power Settings. Change the custom power settings for both "A/C" Power and "Battery Power" to "do nothing" when the lid is closed. By doing so, you can close the laptop lid without shutting off the computer. Of course you will need to add an external mouse and keyboard to continue using the computer, but by following these instructions, you can basically use the laptop, even with a damaged screen, pretty much the same way you would use a desktop. The portability is lost, but the function is retained until you can have a new display panel installed.
Hope this helps FixYa! Please take some time to leave some feedback and a testimonial if you found this information helpful.
May 08, 2010 | HP Computers & Internet
The drivers for this device are not installed(Code 28) for hp compaq 6720s
Remove all external peripherals and then restart the PC in BIOS and do a BIOS Default... Should work....
Feb 23, 2010 | HP Compaq 6720s Notebook
Hp 6720s speakers not workig
go to speaker icon in bottom corner of screen, right click , go to properties, make sure speakers are enabled and volume turned up and speakers are set to default
Aug 27, 2009 | HP Compaq 6720s PC Notebook
Hp compaq 6720s
Check the display on External monitor, if the external monitor works fine, it could be an issue with the LCD and controller for the system board, better to replace the LCD.
but before that just be in a safer side.
Update graphics driver and new version of BIOS from Hp.com
Jul 06, 2009 | HP Compaq 6720s Notebook
My lap speakers are not functioning when i use to play any songs the speakers in the lap are not functioning but when i use to connect lap to any external out put device then the device gives sound. i want...
hello sir
first you please tell me your speaker company.......ok doesn't matter much
are you sure it is not muted..........or tell me did u install or remove any sofware programme
tell me so that we can solve your problem as soon we can
May 06, 2009 | HP Compaq 6720s Notebook
HP Compaq 6720s Sound problems!!!!
pls. check the internal speaker audio cable is ok or not. and also check the audio cable is connected on the audio section of motherboard.
Feb 16, 2009 | HP Compaq 6720s Notebook
My speakers of laptop are not working.
reinstall the driver or use external audio drivers
Jan 08, 2009 | Office Equipment & Supplies
Connecting creative 4.1 speakers with my HP Compaq 6720s laptop
Go 4 setting of audio device in ur laptop.
n check is there 4.1 speaker system is available r not.
Then u can fix ur 4.1 creative to ur laptop.
Aug 01, 2008 | HP Smart Buy Notebook
HP Compaq 6720s Notebook Logo
62 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
