Question about Bunn Dual SH DBC Coffee Maker
Hi I have a bunn commercial brewer. its a sh dbc brewer. the brewer keeps heating the water all thw way to 225 degrees and keeps going.
    President:
  • 1,618 Answers
Sounds like the thermostat needs to be replaced adjusted or the probe to the thermostat is covered in scale, and it cannot read the temp correctly. Remove top panel and check probe, if fine no buildup, follow probe line to thermostat and set to a lower setting, if same problem replace thermostat.
Posted on Apr 03, 2011
I have a commerical Bunn coffee maker. I ran vinegar to clean it out. It dripped very slow. Now, I get a 6 minute pot, the coffee is 180 degrees, but the coffee is very weak! What is up?
Coffee maker is not pre-heating the water.The brew cycle should take about two minutes, and the coffee should be 200°F when it comes out, that is why it's weak. To clarify, is it a commercial model, or a home model (like the one pictured)? Home models will have a 'vacation switch' on the side of the unit that needs to be on to get the water pre-heated properly.
Jan 19, 2011 | Bunn 10 Cup Home Coffee Brewer
Reservoir heats but won't dispense
If you are pouring water in the manual brew basin, then check the sprayhead holes, then the spray tube, those could be blocked. If using the auto brew, check the solenoid and or brew switch.
Apr 26, 2010 | Bunn 12 Cup Coffee Brewers with 3 Lower...
Will not percolate. Water is poured, it heats up, no coffee brew
Bunn Home brewers don't perculate. They work the same way that commercial brewers do. Fillit with water, let it heat for about 20 minutes, then put your filter and coffee grounds in the funnel, pour a pot of water into the machine, put the pot on the warmer, and let the water run through. Then enjoy a nice hot cup of coffee.
Apr 12, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
I have a Bunn Dual SH coffee brewer that does not dispense the same amount of coffee every time
The problem is either the liquid control board or there is something blocking the solenoid, or drawing water from the same line pressure. Also check the sprayhead for buildup.
Oct 26, 2009 | Bunn Dual SH DBC Coffee Maker
Breaker keeps tripping
Hello. Here is what I think, not looking at the unit myself, I would start by checking the heaters, both of them, and the heating circuit for a short to ground through the water, here is a link to the manual,
http://www.bunnomatic.com/pdfs/commercial/manuals/41746.0000.pdf
and from page 34 on has the proper diagrams. An electrician should be able to handle a resistance check of this circuit, with a multimeter. If not you need a repair person that can, look in your phone book for Restaurant repair service.
The other thing I have seen with these, is the solenoid coils have shorted out, and cause intermittent problems, but these usually blow the main board, this would be evident by black scorching either on the front or back of the board.
Hope that helped, and thank you.
Ask me if you need more help.
Apr 05, 2009 | Bunn Dual SH DBC
How do I set the amount of water dispensed w/ Bunn CDBCF35 Digita
Hello. You will need to set the timer, this is done, if the settings are not locked out, using the brew button on the front, holding it until 3 clicks are heard, then just let it brew until you are satisfied with the level, and turn the brew off. This does take a little practice, and may need to be done repeatedly, and you should be prepared for overflowing, just in case :) Here is a link to your manual, please read the section that is for your unit, as it is for several.
http://www.bunnomatic.com/pdfs/commercial/manuals/29079.0000.pdf
Hope that helped, thank you.
Mar 03, 2009 | Bunn CDBCF35 (DBC) Digital Brewer Control
Slow recovery on bunn o matic for next cycle
You could have scale building up on the heating element and thermostat probe. try running a 1/3 white vinigar - 2/3 water mix into the brewer, let it heat up completely, then run several pots of clear water through the unit. keep pouring water through it until the vinigar smell is out of the water,
Jan 05, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Bunn Dual SH DBC Coffee Maker Logo
95 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
