When i turn it on ,it will turn back off and the red light will flash 5 times and cont.to do this
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Best regards.
Posted on Apr 02, 2011
Goldair dehumidifier GD-2020 has stopped working? 'CONT' light on front panel flashing and now cannot get to operate?
cont button just means continuous run mode . the power light is lit , the full light is out . try reseating the water catch bucket a few times , most machines have a safety that wont allow the thing to operate if bucket isn't just perfect in its slot (you don't want water on your floor )
May 23, 2015 | Dehumidifiers
Tip
How to fix your gas furnice
most gas furneses have a red light on circuit board wich is located on intake. turn heater off then have someone turn it back on while you watch the circuit board. count the # of times the red light flashes before it pauses. it will flash in a cycle. for instance it flashe 3 times then pauses for 5 secounds then flashes 3 times again on and on. look on the back of the panel cover,their will be a diagram, in the diagram their will be dianostic report that will include what that # of flashing red light and what it means. for examle 3 flashing red lights ps stuck open. that means pressure switch stuck open. replace the part and your back up and running.
on Dec 18, 2009 | Heating & Cooling
I have a panasonic tv CT-34wx54j red light 5 blinks
The power supply probably has failed. The clicks indicate it is trying to start up but can't.
Dec 30, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Power green light will flash then flash red when first turned on
Please intimate exact model of your Sony TV to find out reason of no power up.
Jul 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Tv turns off but will turn right back on
Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
