Question about Hitachi Televison & Video
HiliHellow,please help my tv model c 2156 ms 192 after switch on takes few second then go to standby
  • Hitachi Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Apr 02, 2011
Remote makes tv start to operate then flicks of to standby immediately
Hi Barrym,
You have not mentioned anything about the make and model of your TV. If you do so, it will help us to suggest you the solution. Your TV is going in the protection mode as soon as you switch it on. There can be several things responsible for this. A proper check can decide the actual cause. Please consult some local TV tech.
May 31, 2015 | Televison & Video
The TV switches it self off
Sorry to here about your TV problems but it is almost imposable to help someone with technical problems if they don't list a product, model or P/N number.
Either-way, I would try moving the unit in an area where it has more breathing space if poss-able.
Also, is the unit in a air conditioned area or in a Damp basement or Florida room ?
I would also, go on line and see if Panasonic has any call backs on this unit.
This may be a feature which can be reset without to much trouble.
Next time please list the size & model #.
Jun 16, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I have 54 tv telefunken model No. MR701, ineed to now the posion No. of the capacitor CP50
My MR701 Telefunken TV set does not want to switch on with its remote control.When I switch of the plus nad then on again. It switches on and a sign with the key and wording MENU appears after few seconds it switches off again.Some times it does swtch on with a universal remote. The red light where the sensor is keeps on lickering when its on standby.Under normal circumstances it stays red without flickering when the TV set is
on standby. Please help.
Feb 22, 2009 | Curtis-Mathis CM25011 25" TV
Onida stand by problem
sir my onida tv 21'' ineed un lock
Nov 07, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Standby mode intermittently.
Hello, FixYa
I have normal tv model CNT 2588 code 981, remote control was out of order and I tried to buy a new one from many places in UAE, Suadi Arabia & Egypt but I failed due to it is old model and no spare parts. So I use the tv function through Satel Decoder and use tv main power button for swithing on and off. It seems that caused a problem and tv now could not get power to switch on. Would you e-mail me with the repair manual including the Elect.Circuit to try to repair the problem. Also if you can arrange to send me a new remote control model CNT 2588 code 980. Since the TV Picture and sound are still in an excellant condition, please e-mail me you kind response with the cost if any to send you my Address and money.
Thanks in advanced.
Mohamed Said
Oct 30, 2008 | Televison & Video
Standby mode
what brand and model??
Oct 29, 2008 | Televison & Video
Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
May 10, 2008 | Samsung TXJ2754 27" TV
Philips DVDR610. When in standby switches on briefly
Hide all remotes from the line of sight of the unit and see if this helps....accordianman
Feb 22, 2008 | JVC XV-N212 DVD Player
TV cut out and stay on standby
hold the power switch in from off for 10 seconds, worked for me.
Jan 06, 2007 | Sony FD Trinitron KV-28FQ75 28" TV
Televison & Video Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
