Question about Garden
Oil pump is not working - Garden
  • 2,239 Answers
Oil pumps are normally driven by either a gear fixed onto the crank, driving a pump shaft at right angles to it, or by a gear driven by the sprocket, there will be a pick up pipe and filter in the oil tank, if you can get at the filter through the oil filler hole then remove and clean it, if not try flushiong the tank out with a suitable cleaning fluid, if this does not help it may be a gear stipped on the pump shaft, to get to this you will need to remove the clutch and sprocket.
Posted on Apr 02, 2011
It is not pumping engine oil
You need a working oil pump to pump the oil around the engine. If the oil is not being pumped through, the oil pump has failed or there is a blockage in the lubrication system.
Most likely the oil pump has failed and needs to be replaced.
Sep 28, 2015 | Cars & Trucks
Where Is The Oil Pump Located>? And How Do I Replace The Oil Pump
Here you go. BIG Job!
http://www.ehow.com/how_4506339_replace-oil-pump-ford-taurus.html
The oil pump is an essential piece of equipment that keeps your Ford Taurus running. It lubricates the engine by keeping the oil circulating. Without this lubrication, the engine wouldn't run. An oil pump is usually located in the oil pan. If you want to change the oil pump and replace it with a new one, roll up your sleeves and get ready for some dirty work.
How to Check if an Oil Pump Is Bad
Things You'll Need
  • Wrench
  • New oil pump
  • New A/C bolts
Remove Old Oil Pump
  1. Drive your Ford Taurus up onto ramps or lifts so you have room to work as you pull out the oil pump. You could also use a jack, but make sure you brace the front wheels so they don't roll. In addition, set the emergency break firmly into position so the car doesn't roll.
  2. Take the engine out and put it on an engine stand then remove the upper intake manifold. Take off the valve covers then the accessory drive belt.
  3. Remove the power steering pump and the alternator. The water pump is the next component to remove, followed by the A/C compressor and bracket.
  4. Rotate the pulley shaft clockwise to remove the crankshaft pulley. It has left-handed threads.
  5. Pull out the oil pan and the oil pump screen and tube. Take off the front cover and the timing chains and remove the crankshaft timing gears. Finally, remove the oil pump, taking note of the bolts you removed and in which order you remove them.
Insert New Oil Pump
  1. Install the new oil pump and put the bolts back on in the same manner you removed them. Tighten these bolts to 71 to 106 in-lb.
  2. Reinsert the crankshaft timing gears, timing chains and front cover. Put the oil pump screen and tube back on, torquing the bolts to 71 to 106 in-lb, and torque the nut to 15 to 22 ft-lb.
  3. Put the oil pan back in, then the crankshaft pulley. Install the A/C compressor and bracket using new bolts for the A/C. Add the water pump, alternator, power steering pump, the accessory drive belt, valve covers and upper intake manifold.
  4. Replace the engine back into your Ford Taurus and fill the crankcase. Start your engine and look for leaks in the area you were working.
Read more : http://www.ehow.com/how_4506339_replace-oil-pump-ford-taurus.html
Aug 06, 2015 | 2004 Ford Taurus
Nissan XTRAIL QR20 OIL PUMP NOT WORKING
New oil pumps will not work until they are primed . Pull the pump and remove the gears cover Fill the space around the gears with Vaseline / grease and replace the cover/pump. When the engine starts to spin the gears will move the Vaseline out into the oil galleys and create a vacuum which will suck up the oil. The Vaseline/ grease will disperse back into the sump with no ill effects. Ensure the oil pick up pipe is securely in place.
Jun 07, 2013 | Cars & Trucks
Oil pump does not work
Checlk the oil worm gear is driving the pump. If this isnt the problem then try the following:-
The type of oil pump fitted to these models is prone to getting blocked.
Remove the oil pump. The gear on top should turn freely, give the pump a clean and clean the oil pipe to the tank by removing the oil cap and blowing through with an air line. If the oil in the tank contains alot of dirt, empty/clean and replace. The filter on the oil is an open plastic cage type and often will draw large sawdust particles through it. Easily rectified tho.
Aug 24, 2012 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Oil pump
oil pump is driven by the camshaft gear by an oil pump drive shaft located under the throttle body/intake plenum. the oil pump is located inside the oil pan/engine block.
May 23, 2012 | 1999 Pontiac Grand Am GT
Motor oil spewing out of the intake manifold of a 05 road king when it's running
"Spewing out of the intake manifold". Check you oil tank. If the level is really low, it sounds like the scavenge side of your oil pump is not working. If the oil is coming out of the intake that bad, the engine is full of oil.
The Harley oil system is a "dry sump" type of system in that the oil is not carried in the crankcase like in the Japanese bikes but rather in an external oil tank. The oil pump has two sections in it. A "feed" section to pump oil into the engine and a "scavenger" section to pump oil out of the engine and back to the oil tank. If the scavenge section is not working, the pump will pump all the oil into the crankcase but it cannot pump it back out. When this happens, the oil is blown out of the crankcase vent system and into the intake manifold.
You need to check the operation of your oil pump.
Good Luck
Steve
Jan 15, 2011 | Harley Davidson Motorcycles
I have a 1997 Chevy Blazer that has oil, but no pressure
There's something you can do to check if the oil pump is still working screw off the oil filter and start it only for a few seconds if oil shoots out the pump is working if it doesn't the pump could be clogged or it lose prime if it's working check the wire going to the oil pressure switch may be broken.
Jan 04, 2010 | 1997 Chevrolet Blazer
OIL LIGTH
TRY TO REMOVE THE OIL FILLER CAP WHILE ENGINE IS RUNNING, IF THERE IS SPRINKLING OF OIL THAT YOU WILL NOTICE THEN MAYBE THE OIL SENDER IS NOT WORKING BUT IF THERE IS NO SPRINKLING OF OIL THEN MAYBE TRY TO REPLACE YOUR OIL FILTER IF IT IS NOT YET WORKING MAYBE THE OIL PUMP IS NOT WORKING TRY TO REPLACE IT,YOU CAN SEE THE OIL PUMP WHEN YOU REMOVE THE OIL PAN.
Dec 27, 2008 | 2002 Toyota RAV4
PUMP OIL NOT WORKING ?
oil pump in engine is like heart in human body ! do not run engine with out fix it .ck the oil pan,oil screen for mud and tar, oil filter for clogs, the oil pump is located in the L side of engine behand the timing cover next to the water pump
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
