Question about 3Com OfficeConnect Router
OfficeConnect Router Web Admin screen open to all
I have configured my OfficeConnect ADSL Wireless Firewall Router to work with my 5 static IP addresses and everything seems okay, but the web admin screen is available to the world on the first IP address. I hoped it would only make it available to my other static IPs. Should I be worried? Or is there a way round this issue? All the instructions in the manual seem to be aimed at NAT setups.
  • 2,794 Answers
I'm not sure how 3 com routers work but I work with Linksys equipment and Actiontec a lot. Their systems have a toggle in the admin setup to disable remote access. If that is turned off and the admin needs a password to get into it, you should be fine.
Posted on Aug 05, 2008
Show me how to connect linksys wireless
Hi
The Router configuration is not that much difficult, only few thing you have sure,
1) Correct ADSL Connection User name & password,
2) Chose unique ip address in All host.
Follow the mention bellow instruction to configure and connect to Wifi Router,
  • Plug the network cable ( Mine was Blue ) which comes with the Router Box pack to your computer. The other end goes into any of the Router Ethernet Port ( 1 or 2 or 3 or 4 )
  • Now type in 192.168.1.1 in IE or Firefox or any browser. You will prompted for password which is admin. You must be logged into Linksys Router.
  • Now since your ADSL modem is also having the same IP , we will change the IP address for WRT54G2 Router to 192.168.5.1
  • Under Setup >Basic Setup look for Network Setup and Change Router IP. Change to 192.168.5.1 and Save changes.
  • Since the IP has changed you will need to close the Browser.
  • Sometimes the IP doesnt change automatically. Do a IPCONFIG / RELEASE and then IPCONFIG / Renew
Making WRT54G2 Router talk to ADSL broadband modem
  • Plugin the Ethernet cable which comes from the Modem into the port on Wrt54g2 router which says Internet.
  • Open Internet Explorer and Type in 192.168.5.1.
  • Type in same password ( admin )
  • You will be in Setup > Basic Setup
  • Take a look at Section , Internet Setup. The current selection should be Automatic Configuration DHCP. Select Static IP instead.
  • Add following details to it. In the first step we backed up All the IP configuration. Use them here
Internet IP Address: . . .
Subnet Mask: . . .
Gateway: . . .
Static DNS 1: . . .
Static DNS 2: . . .
Static DNS 3:
ADSL Modem Settings to Wrt54g2 Router
  • Once Done just save changes and you should be back at same page.
  • Now try to connect any application which talks to internet. You should be able to connect
Configuring for Wireless Connection :Now once your Router is talking with Modem, it is pretty easy to connect on Wireless. The only thing we need to setup here is Security. Lets get WIFI
  • Get to the Lynksys page again. Do all login and regualr stuff.
  • Now look for menu Wireless, click on it. You should land on Basic Wireless Settings.
  • Select wireless configuration to Manual .
  • Wireless network mode to Mixed.
  • Give a Wireless Network Name (SSID), make sure its unique.
  • Make Wireless channel selection 11 ( 11 - 2.463 GHZ)
  • Select Wireless SSID Broadcast to Enable
  • Save Settings and you will be back at the same page with changes you made.
Now Lets secure the Router :
  • Go to Wireless Security on the same page.
  • You will need to configure here Security Mode : WPA Personal, WPA Algorithms: TKIP
  • WPA Shared Key is what you will need when you connect to your router without wire. This key does the authentication and keep unwanted people away. Add 8 digit alphanumeric key.
  • As suggested in comments, there is a new mode which you can use : WPA2 with AES
  • Save changes.Just make sure you save that key to a notepad or remember it.
Wrt54g2 wireless security
  • Now last step, Move to next menu Security > Firewall .
  • Uncheck Block Anonymous Internet Requests .
  • Save Settings.
Wrt54g2 firewall settings
  • Remove the blue cable which you had connected with Router.
That's it. Now just turn on your WIFI and Search for the router. The name should be visible. Click to connect. At this stage it will ask you for the Password or Shared Key which we configures just above. It will connect and you will be able to connect to Internet.
That's all Folks. This is how you connect WRT54G2 Linksys router with Adsl Broadband Modem. If you have any questions feel free to comment.
Aug 03, 2011 | Linksys WRT54G2 Wireless Router
I forgot my admin password for Wirelles Router 3Com "Office Connect ADSL Wireless 11g Firewall Router" what i have to do ? i don't want to reset my Wireless Router couse that make's me have to reconfigure...
if you havnt changed the password to the router then it should either be "PASSWORD" "ADMIN" "ADMINASTRATOR" in the worst case senreio you may have to reset the router.
Apr 20, 2010 | 3Com OfficeConnect Wireless Router
What is the ip address of paradyne 6381 a3 300 router
To configure your router, open your web browser. Type the default IP address (http://192.168.1.1) into the Location field of your browser and press the Enter key. A Login screen will appear. Use the below to log into your router.
The default IP address is 192.168.1.1
The default user name is Admin
The default password is Admin
Both are case-sensitive.
Jan 08, 2010 | Paradyne ADSL/R 6381 Router (6381-a2-200)
Wireless side of 4port linksys router not working hard wired switch ports working unable to ping router using dhcp if i configure a static ip on my pc i can then ping 192.168.1.1
try a factury reset on the switch by holding the reset button and pluging in the power at the same time and holding for 5 seconds- reconfigure router as required.
Sep 30, 2009 | Linksys Wireless-G WRT54G Router
I can'yt open the firewall
if you are using windows xp go to the start button and in "run" box type "cmd" - a black window will open. then type in "ipconfig" you will then get a screen of information. then look for the ip address of your "Default Gateway". this is the ip address of your route... then go to a web browser and type this address in. you will then be taken to the web admin interface of your router.
Apr 28, 2009 | 3Com OFFICECONNECT VPN Firewall
3com officeconnect wireless 11g cable/dsl router
router default ip gateway will be the 192.168.1.1,so you can able to give the same ip address,so you configure only other ip address & try it.
May 25, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Zoom X6 Adsl Router
You must assign a static IP address on the Xbox 360 that it is outside of the Zoom X6 router's DHCP pool. Also, the Xbox 360 must be in a DMZ. This will prevent the firewall of the router from blocking connections to the Xbox 360.
  1. Assign a Static IP address on the Xbox 360 console:
    • Power on your Xbox 360 and go to the System area.
    • Select Network Settings and then Edit Settings.
    • Select IP Settings. The Edit IP Settings screen opens.
    • Select Manual and then enter the following settings:
      • IP Address: 10.0.0.150 (or any 10.0.0.x IP address, where x is between 100 and 250)
      • Subnet Mask: 255.255.255.0
      • Gateway: 10.0.0.2
    • Select Done, to go back to the Edit Settings screen.
    • Select DNS Settings. The Edit DNS Settings screen opens.
    • Select Manual and then enter the following setting:
      • Primary DNS Server: 10.0.0.2
      • It is not necessary to enter a Secondary DNS Server.
    • Select Done.
    • Power down your Xbox 360.
  2. Access the Zoom Configuration Manager:
    • From a computer that is connected to the Zoom X6, open a web browser and type http://10.0.0.2 in the address line and then press Enter (or Return).
    • Enter the User Name and Password (in lowercvase letters):
      • User Name: admin
      • Pasword: zoomadsl (where "l" is a lowercase letter L)
  3. Create a Virtual Server rule to put the Xbox 360 on a DMZ:
    • In the Zoom Configuration Manager, click on the Advanced Setup icon at the top page.
    • Click on the Virtual Server/DMZ button.
    • On the Virtual Server/DMZ page, enter the following settings:
      • Internal IP Address: 10.0.0.150 (or whichever Static IP address you selected per Step 1)
      • Protcol: DMZ
      • Start Port: 0
      • End Port: 0
    • Click Save Changes
    • Click the Enable box, if you have this option.
    • Click Write Settings to Flash
  4. Plug the Xbox 360 Wireless Networking Adapter in to the Xbox 360 console. If you are not sure how to do this, please refer to the manual that came with the Adapter.
  5. Select the Zoom wireless network on the Xbox 360. (Note: The following steps assume you have a working wireless network with WEP or WPA security enabled and you know the Key and SSID of the network. If you have not done this, please refer to theFAQ on setting up a wireless network with the Zoom X6.)
    • Power on your Xbox 360 and go the System area.
    • Select Network Settings and then Wireless Network.
    • Enter the SSID of your network
    • Enter the Security Key for your wireless encryption. This must be either WPA or WEP. If you use WEP, you must enter the HEX digits for the Key you are using.
    • Power the Xbox 360 off, wait a few seconds, and then power the Xbox 360 back on.
    • Go to the System area.
    • Select Network Settings.
    • Select Test Xbox Live Connection. If everything is configured correctly, all the tests will show Pass.
  6. Congratulations! You can now enjoy your Xbox 360 with Xbox Live.
May 23, 2008 | Zoom X6 Adsl Modem/router Rohs...
RG54SE II
In your wireless router,U want to configure the ip adress of internet,may R u static ip R dynamic ip address,
1. Statis ip customer means, configure the static ip address in your wireless router,
2. Dynamic ip customer means, configure the ip address of the ADSl modem ip.
May 20, 2008 | MSI Wireless-G RG54G3 Router
3Com OfficeConnect Router Logo
297 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
