Question about Vacuums
I have the Kenmore upright model number 116 35922500. It has become almost impossible to push. Someone told me the bearings probably needed to be cleaned. I have all the screws off the bottom plate but still cannot remove it.
SOURCE: kenmore progressive canister Sweeper
I figured it out ..by pushing the lever down and pry a screw driver into three different spots on the top, to release the rewind bar. Looks like three little j hooks hold it down. It took a flashlight and night time for me to see it.
Posted on Mar 20, 2008
reddevil6
  • 1673 Answers
SOURCE: Brush roller on Hoover upright stops turning
There should be a belt tensioner for the V belt, maybe it is not contacting the belt when you tilt the handle back. If this is less then 1 year old, then it is under warranty, take it in to a warranty servicer for warranty repair.
Posted on Dec 29, 2008
  • 134 Answers
SOURCE: Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Posted on Mar 12, 2009
  • 5 Answers
SOURCE: Need to change belts on a Bissell 1699 model
Here is the manual. Also you can go to Bissell.com and use the problemsolver.
http://www.bissell.com/images/UserGuides/7901_1008.pdf
Posted on Mar 28, 2009
  • 70 Answers
SOURCE: Kenmore 3.9 with power-mate Model 116 2839581.
You have to take off the top of the power nozzel that has the light lense. There are two pressure locks,one on each side. Use a screw driver to release. You will see the screws.Take the two screws out and on some models, there are two pressure locks on the back of the nozzel. Again use the screw driver to release. The top should come right off.Hope this helps.
Posted on Oct 18, 2009
Is there an easy way to see if a drive belt may be broken? It's so difficult to push my Kenmore upright vacuum!
Well there is only turning the vacuum over and see if the brush is rotating.
If it is not moving then you need to replace the belt.
If you need to know how to remove the bottom plate to replace the belt, please post the model number, the numbers you posted above are not the kenmore model numbers, the model numbers will look like this
316135912,FPF311PHSB, FGF316WGSK
Feb 15, 2010 | Kenmore 35912 / 35913 Progressive Upright...
Kenmore upright vac model 33922 - good suction but developed loud whining noise after accidentally vacuuming room without bag. Added bag and changed both filters. Still makes noise. How can I stop noise?
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Sep 14, 2009 | Kenmore 33922 Direct Drive Bagged Upright...
When pushing foreward the vacuum is hard to push and if pushed on to hard it will turn over on itself.
Check the brush. That could be the problem. Check the belt also. Your brush roller may need to be lubed or even replaced.
Sep 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Kenmore progressive 300 smells like it is burning
These vacs use Ametek motors which are practically designed to fail. Frequent complaints are a burning smell and louder than usual noise in the canister. The problem is the poor quality
bearings Ametek uses in the motors in the units. They have low-end ball bearings with a nylon "crown" that breaks up and gums up the bearing. Further the fan end of the motor is a bear to get to because of poor (intentionally?) design. With great difficulty I WAS able to remove the fan and housing and inspect the bearing. Since finding a replacement is too much trouble or impossible, I cleaned up the ball bearings and switched the bearings on the two ends moving the remaining good one from the brush end to the fan end where I assume the load is. I packed the damaged one with grease.
Now the motor runs smoothly. I doubt however this jury rig will last very long. It is very irritating to toss a $120 motor because of a failed bearing. Kenmore and Ametek should be embarassed but I'm sure they are NOT!
Jul 15, 2009 | Oreck XL2200 Bagged Upright Vacuum
My dyson vacumn is hard to push on carpeting. How do i fix it?
This happens when the bristles in the brush roll get worn down too short. Put in a new brush roll and the machine will pull itself over the carpet, so you hardly have to push at all.
May 19, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Motor comes on-brush not turning
Most power heads use a belt to turn the brush roller. Open it up and u'll probably find the broken belt laying in there
May 15, 2009 | Kenmore Vacuums
Kenmore upright model number 86039259990. The
don'thave to smell, the belt just snapped in half.unplug the vacuum and try to turn the brush roller by hand,if it turns real freely the belt is broke.it should be kind of hard to turn by hand if the belt was good
Mar 04, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore Elegance Upright Bagged Vacuum Belt Broken and Smelling
It sounds like the brushroll has caused your belt problem and will be the cause of your burning smell as well. What commonly occurs is that carpet fiber,hair,string, thread,etc got wound around the brushroll and some will get caught in the end caps which is where the bearings are.The end caps need to be removed and cleaned so that the bearings can allow the brush to rotate freely.Check that there is no melting of the end caps or the base plate where the end caps fit into the machine._Good Luck
Oct 26, 2008 | Kenmore 34612 Bagged Upright Vacuum
Dyson suddenly hard to push on carpet
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
Jun 02, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
