Question about Mantis 2-Cycle Tiller
I have a Parmi Gardenette model # LT-1011 tiller w/Tecumseh engine am looking for fuel tank and hoses.
  • ld36341 Apr 03, 2011
    could not find part i am looking for
  • 718 Answers
Go to (www.psep.biz) and look up Tecumseh on the page that pops up and you should find what you need. Good Luck..
Posted on Apr 02, 2011
  • vince janis
    vince janis Apr 03, 2011
    I just checked psep.biz and there are 20 different fuel tanks on that page! You need to do some research take your engine model numbers and and cross reference what you need to find. As far as the hose(s) it is most likely going to be a standard fuel hose that you can purchase for your local home center or True Value hardware store.
    Try this site but you need your ENGINES model number and other info to look up parts, jackssmallengines.com. Looking up the stuff is not rocket science, if you need someone to hold your hand or walk you through the process than you might want to go somewhere else for your info or take a class or something like that. Sorry just being real!! Good Luck... Hope you find what you are looking for.
I have a 6hp Tecumseh engine that want take the gas when it runing!
possible part blocked main jet or low fuel supply from blocked filter in the tank
May 10, 2016 | Tecumseh Garden
I have a Tecumseh OHH55 on a wood chipper. I replaced plug, oil, new fuel and cleaned up. I cannot get it to start. Carb was also cleaned. Any suggestions before I take to a repair shop.
Is fuel getting to the carb? Check the fuel line it may be plugged. The rubber deteriorates after many years and plugs up the line and or jets. Its always best to replace the fuel hose when you rebuild the carb. Have you checked for a spark at the plug?
Aug 09, 2014 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Why isn't engine getting gas thrugh carberator?
-Possibly fuel line is clogged between tank to carburetor. Or the line
is closed. (Most tiller has a Open/Closed valve that let you open and close the gas line)
Good luck
Mai
Jun 14, 2014 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How to change oil in 6.5 Tecumseh
You need to open its small tank and fill up the fuel.
Aug 23, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Have a tecumseh ohh50 4 cycler engine on a garden
Check for condensation in the tank. Fill with FRESH gas, then if no luck, proceed ...
Main jet partially blocked. Undo bowl nut. Some models have the jet in the side of the nut - check and clean. If not, the jet is in the emusion tube of the carb - accessible throught the bowl nut orifice. Clean out & test.
Jul 23, 2010 | Mtd Garden
I'm looking for blades for a tecumseh 5.5 formula, can you guys help me?
Copy and past this into your browser's address bar. Then hit enter! Tecumseh parts galore!
http://www.m-and-d.com/scan/se=TECUMSEH/sf=category/st=db/co=yes/op=eq/sp=brands_results/va=category_name=TECUMSEH/tf=sku/ml=20.html
May 10, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Could you tell me how to drain the gas tank.
easy way is to take the nut off the bottom of the carburetor bowl. It'll drain the tank, carb and fuel line. If you're not comfortable with this, then you can pull the fuel line off the carb or tank and let them drain this way too.
Mar 20, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Engine will not run/tecumseh enginelstall once it starts/hsk model
I assume this is on a snowblower?
Be sure you have fresh fuel.
You can also remove the bowl on the carb and spray carb cleaner in any orfice you see.
Always store a snowblower with fuel stabilizer in it. Otherwise it the fuel can "varnish" the inside of the carb and cause problem.
If it still doesn't start check compression.
Jan 09, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Carburetor is leaking through a small pin hole, this hole was made by manufacturer
the "hole" is an atmosphere vent, what is happening is the needle that shuts off the fuel to the carb when the bowl is full is not working properly, depending on model the carb repair kit that is most used to repair plastic tubed carbs is 632760b .....also be sure to flush out tank and fuel lines before adding fresh 89 octane fuel to the fuel system....hope this helps
Nov 19, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Ariens SnoThro w/5hp Tecumseh has no fire
Check the fuel. Pour some fuel into a clear jar and let it set. See if it seperates due to water in the fuel. Very common problem.
Rich
Jan 15, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Mantis 2-Cycle Tiller Logo
406 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
