Question about Kyocera Office Equipment & Supplies
My Kyocera FS-1030D (duplex) has just started making spidery deposits of toner on the blank side of printed output. It means I can only print one sheet at a time because on a continuous run the loose toner on the back of each sheet spoils the printed face of the following copy. I thought it was a toner cartridge fault so just bought a new genuine Kyocera unit but absolutely no difference. It's like there's toner dribbling out somewhere. The machine is 4 years old, used regularly and, according to the Status Page, has printed 39k copies. Have I just wasted my money on a new toner??!
  • jes_holmes Apr 02, 2011
    Thank you very much. Have just followed those directions then tried a duplex booklet print of the manual. There was still toner spoilage for the first dozen copies but it gradually cleared up. Hopefully it's sorted! I really appreciate both the clear advice and the link - I didn't have a full manual.
    Regards, Jes Holmes, Lincolnshire, UK.
  • 823 Answers
You have not wasted your money on the new toner purchase. With a little maintenance, it can last a lifetime.
The "spidery deposits of toner" you are talking about could be caused by a dirty charger wire under the process unit. You mentioned that you just changed the toner cartridge, right? Did you remove the process unit and clean the charger wire under it after you changed the toner? The charger wire has to be cleaned with charger cleaner every time the toner container is replaced.
Do you have the manual which came with your printer? If so, then go to page 39 to find information on printer cleaning tasks. If you have not cleaned the charger wire, dust out the printer with a lint free dry cloth and change it when it looks soiled. Continue dusting and wiping until there is no dust on the cloth. Then remove the process unit (picture on page 39) and wipe out the area with a new lint free cloth until no dust is apparent on it.
Slide the green charger wire cleaner back and forth across the wire as instructed on page 43 of your manual. Reinsert the process unit.
The only other thing that can cause the problem with toner marks is if the registration roller is soiled with toner. Refer to page 18 for instructions on checking and fixing it.
If you dont have a manual, here is a link to get one for free:
http://www.kyoceramita.eu/dlc/eu/documentation/usermanual/fs-1030d-og-uk_pdf.-downloadcenteritem-Single-File.downloadcenteritem.tmp/FS-1030D-OG-UK.pdf
Posted on Apr 02, 2011
Constant paper jams
find some hard paper like trancparency plastic paper or some hard type paper leke certeficate printing paper and by opening the tray out and push the paper till u see it out around the touner cartirage place after doing so replace the tray and the toner cartirage hop the printer do not paper!!!
Apr 24, 2013 | Kyocera Mita FS-1030D Laser Printer
How do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
Nov 19, 2009 | Kyocera FS 1030D LASER 22PPM A4 PAR,USB...
Printer was printing OK then 4th red light started flashing and it stopped printing why?
4th light is for toner ......... replace the toner and check...........
if getting same please post the details error........
Oct 31, 2009 | Kyocera Mita FS-1030D Laser Printer
Duplex mode.
please select print in both side options when u giving any print then only it will print both side...
Jul 02, 2009 | Kyocera Mita FS-1030D Laser Printer
Print quality
replace your toner... and if condition remains the same... replace your drum
Apr 03, 2009 | Kyocera FS 1030D LASER 22PPM A4 PAR,USB...
Kyocera fs-1030d wont print frames on MSWORD2000
wrong... the kyocera only prints what you send to it... you need to go into your print settings and make the adjustments so it can print frames borders/ shadings... this has been my experience with explorer and photoshop... not very much fun but necessary...
Mar 06, 2009 | Kyocera Mita FS-1030D Laser Printer
My printer prints dust particles with the print ducument
Before your printer prints a page a small blade runs across the toner drum to clean it before the next page is printed. If the blade is broken or not functioning then you will get some toner particles on your paper. So you need to get it repaired at the local computer and repair shop. Remember it's just the blade so if they try and add some other stuff tell them no, just fix the blade...Good Luck and let me know if you have any questions. Don't forget to vote this solution with 4 stars before you log out.
Feb 10, 2009 | Kyocera FS-1030D Laser Printer
Kyocera Mita FS-1030D Laser Bottom 2 lights blinking.
I think the two lights flashing together indicates waste toner box missing or full but as this printer doesn't have a waste bottle I assume it means the processing unit (ie the drum bit) needs replacing.
Apr 22, 2008 | Kyocera Mita FS-1030D Laser Printer
166 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
