Question about Coleman 6.5hp - 80 Gallon Vertical ASME Oil - Lube Air Compressor CV6548049
6.5hp 80gallon cfm psi? - Coleman 6.5hp - 80 Gallon Vertical ASME Oil - Lube Air Compressor CV6548049
    Problem Solver:
  • 5 Answers
MY DEAR FRIEND;
GALLON IS TO MEASURE THE VOLUME,BUT CFM(CUBIC FEET PER MINUTE) IS USED FOR FLOW.AND ALSO PSI IS FOR PRESSURE.THUS THEY ARE NOT ANY WAY RELATED.
IF IS IMPORTANT TO KNOW THOSE FACTORS, ESTIMATE THE TIME IT TAKES TO FILL THE TANK AND MEASURE THE FLOW AND READ THE MAXIMUM PRESSURE AND THOSE WILL APPLY
IMMAN OSTOVAR
Posted on Apr 05, 2011
Will a air compressor that runs at 11.8 cfm at 90 psi run at 10 cfm at 100 psi?
if it is a 11cfm compressor then it produces 11.8 cfm of air regardless of the pressure
pressure has nothing to do with cfm but with the restriction to air flow
for example the tire inflator -air hawk- has a very small cfm but as the tire restrict the air flow the pressure builds up to set pressure on the gauge
so if you want 100psi from the 11.8cfm unit just adjust the pressure switch to shut off at 100psi
Cfm is only important when using air tools as a compressor that is not capable of maintaining the cfm thereby the pressure to run the tools is not a good idea
as an example
a sand blaster that uses 11.8 cfm at 100 psi will not work on your compressor
that unit will require a 20cfm compressor to run it peoperly
Sep 25, 2017 | Psi Air Tools & Compressors
I need a 4 piston A/C compressor or a 4 piston hydraulic pump for a project. do you know which models have this
http://www.boge.com/in/artikel/download/Brochure304_EN_Piston.pdf
Devair/DeVilbiss Piston Air Compressors
www.centrair.ca/piston_compressors.html 5hp piston air compressor, 7.5hp piston air compressor, 10hp piston air compressor, 15hp piston air compressor, 25hp ... PUMP: 2 x 447 (2 stage 4 cylinder)
10HP 4 Cylinder 2 Stage Air Compressor Pump
https://www.eatoncompressor.com/10hp-4-cylinder-2-stage-air-compress... Solid cast iron 2-stage V-4 piston series pump, oil lubricated design to extend pump ... This is our 10 HP, 4 Cylinder, 2-Stage, air compressor pump with 43 CFM ... Compressor Stages‎: ‎Two Stage CFM @ 100 PSI‎: ‎43 CFM Compressor Type‎: ‎Bare Piston Pump Horse Power‎: ‎43 CFM
Petstar 4 - Ingersoll Rand
www.ingersollrandproducts.com > ... > PET Compressed Air Solutions Ingersoll Rand PETStar® 4 reciprocating air compressors offer durability and ... pistons with heavy-duty Class 40 cast iron cylinder construction; Piston rings and ...
Jan 31, 2016 | Air Tools & Compressors
Which type of a compressor machine has a better to a plant consuming 500 CFM of air at an average of 120 psig screw type or piston type
A screw type compressor will be the better solution. Screw compressors are made to run. You can also get screw compressors with variable speed with means electrical savings. Ingersoll has screws that are up to 150 psi. Atlas Copco has screws that I know go up to 175 psi. I don't know if it's still available but the Government had assistance plans or grants if purchasing a compressor with a power savings feature.
Jun 22, 2011 | Ingersoll Rand SS5L5 Ir Electric...
I just got my 60 gallon CH air compressor yesterday and it is leaking oil. I have it in the garage and the temperature is around the freezing point. It has not been hooked up or operated at all. Do I...
Won't be worth the shipping
That is a good machine
My 12 gallon lasted 30 years
Now I have a 28 gallon like yours
Get a gasket set for the cyl head, etc
from campbell.
Call them,they may give you whatever
is bad ,if it is new
Dec 20, 2010 | Campbell Hausfeld Electric Stationary Air...
Oil leak
did you over fill it? How old is the compressor?
May 27, 2010 | Campbell Hausfeld Electric Stationary Air...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Coleman 6.5hp - 80 Gallon Vertical ASME Oil - Lube Air Compressor CV6548049 Logo
96 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
