Question about Haier HNSB03 Compact Refrigerator
My compact refrigerator is too cold even turned way down almost off. Freezes soda cans and makes them blow up.
  • Haier Master
  • 43,501 Answers
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Apr 03, 2011
Won't stop running even on the off position on temperature. Freezes everything
the "o" position is as cold as you can get
try setting up around 4 and see what happens
Apr 29, 2015 | Black and Decker USA Black & Decker 2.7 cu...
Refrigerator freezes sodas in the fridge part
May be simple as dirty condensor coil try looking under the bottom where the compressor is there is a coil with a fan blowing on it. Try cleaning the coil and make sure the fan is working
Aug 10, 2012 | Refrigerators
Our GE compact refrigerator freezes everything in it. Where should the dial be set to control this?
Usually about midway. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 06, 2010 | GE Refrigerators
Food freezes in the fridge part even at the highest
If it is freezing, either you need to turn both temp down to 2nd to lowest setting. Cold air does sink, so that is why crisper gets colder. There is a flap and vent for air between the fridge and freezer. The flap can get stuck in one direction, or the acutator that moves it can become faulty. A leaky door seal will also make the opposite compartment colder.
Oct 11, 2009 | Frigidaire GLRS263ZD Side by Side...
Fishy odor
Make sure you wash the refrigerator and freezer with a baking soda and water solution.
Then, place a few charcoal briquets in the fridge and freezer areas.
The charcoal will absorb odors. It works wonders.
In one month, you can remove the briquets and scrape the outer layer off to renew the usefulness of the charcoal.
Oct 09, 2009 | Refrigerators
Too Cold
Friend, the control is malfunctioning thats why it wont work when selected.try to clean the parts inside
Aug 22, 2009 | DCS UR624 Compact Refrigerator
Small refrigerator freezes everything
Adjust its thermostat. or if its broken try getting it fixed. if not then you just have to buy a new one :D
Jul 21, 2009 | Sanyo SR-3660S Compact Refrigerator
Freezer melts then freezes again
hi thanks for the question is this a new fridge . if it is the fridge does shut down to enable the freezer to thaw. if it did not do that do that the freezer would ice up . not cooling the fridge part thanks for the question
Sep 28, 2008 | Kenmore Stainless Steel Compact...
Propane refrigerator is too cold
You have a defective thermostat. Change it.
Nov 18, 2007 | Danby DPAC10061 Air Conditioner
Refrigerator freezes contents
Get a new cold control for it
Sep 01, 2007 | Refrigerators
Haier HNSB03 Compact Refrigerator Logo
850 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
