Question about Laminar Research X-Plane for iPad
On the jet liners I have green horizontal lines along the plane body -should this be sp???? Colin
  • 30 Answers
Try messing with your settings until it disappears
Posted on May 10, 2011
I have heavy lines both horizontally and vertically. If something is over-driven, how do I get to it for adjustment?
1.- Are lines overimposed to the normal picture?
2.- Horizontal lines? Maybe slanted or diagonal.
It looks like you have screen voltage problem.
Or 185 volts is too low for driving the 3 (red - green - blue) transistors.
Adjustment should be by the flyback body itself.
Feb 16, 2016 | Televison & Video
2005 225 optimax. Had a little stall getting on plane. Changed the fuel filter and made it worse. Barely gets on plane and when on plane don't run like it used to. Any ideas?
it appears to be a fuel starvationproblem
it can be from the tank vent still locked close
fule lines collapsing internally
fuel pump diaphragm fai;lure
blockage in the main jets
even tye hand pump bulge in the line can be failing and blocking the fuel lines
Jul 07, 2015 | Cars & Trucks
How do I fix horizontal lines on the viewer and pictures of my Olympus SP-560 UZ
If you have both, lines on the display, and on the pictures, I'm afraid something is wring with the sensor, or with the connections to the sensor. That is if you have the same lines on every picture.
If you only have horizontal lines, when taking pictures of bright lights in a dark area, it is just a phenomena of the camera. In almost all digital camera's this can happen.
Jun 30, 2014 | Olympus SP-560 UZ Digital Camera
Horizontal black lines on print jobs Ricoh SP C430DN
Are theses along the border? You may need to replace the Black Drum unit
Dec 20, 2013 | Ricoh SP C430DN Laser Printer
Should I move around the plane during the flight?
You should stand up and sit down every hour or two and sometimes get up and walk around the plane in order to stream your blood around your body and avoid blood clots.
Feb 06, 2013 | Luggage & Travel
What kind of engine is used in airplanes?
The type of engine that airplanes use is the turbine gas engine, or jet engines. They have been in use since World War 2.
Aug 29, 2012 | Champion Sport & Outdoor - Others
No work is done by gravity on a bowling ball that is rolled along a bowling alley because why?
If the bowling alley is perfectly horizontal, the center of gravity of the ball will remain at the same height measured in a fixed system of reference. As you know the gravity force is directed vertically downward. To calculate the elementary work of that force you evaluate the inner product dW= vec(g).differential of vec(5). However since the displacement vector vec(r) remains in a horizontal plane ( Prependicular to the direction of vec(g), and the ball does not bounce and leave the horizontal plane) the angle between vec(g) and vec(r) is equal to 90 degrees. the inner (scalar product is =0).
A simpler way to remember it is that the work is equal to g*(difference in height)
Jan 07, 2012 | iPhone Apps
Samsung Plasma TV has horizontal lines of colored dots
I have the same problem, currently searching for a solution. Have you resolved your problem yet? Looking to repair myself, any tips or ideas that you have/expirenced would be greatly appreciated. Thanks, Todd
Apr 10, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Laminar Research X-Plane for iPad Logo
88 people viewed this question
Top Laminar Research Apps Experts
Erin Wood
Erin Wood
Are you a Laminar Research App Expert? Answer questions, earn points and help others
