Question about Tradesman 8480K 38Inch to 114Inch 2in1 StaplerBrad Nailer with 5000
Need parts for #8480 2 in 1 gun specifically the safety trip tip
Nail gun will not shoot a nail
Check the safety trip make sure it is pushing back far enough. If it doesn't then it won't do anything. When it was fine just moments earlier.
Feb 05, 2013 | Dewalt D51822 Clipped Head 2Inch to...
How do i adjust the nail depth on my bostitch n80 sb
The part of the gun that touches the work surface and acts as the safety so the gun won't fire unless pressed down on something is two peices bolted together. If you losten the nuts the bottom part will slide up and down. If you make the tip longer, the nail will be left higher (proud) in the workpeice. If you make the tip shorter the nail will be set deeper (counter sunk) into the workpeice.
Aug 26, 2012 | Stanley Air Tools & Compressors
Bostitch RN46 will not fire nail, only releases air when trigger is held and firing tip is touched to surface of material. Any ideas on what is wrong?
Gun will not fire if air is leaking past orings in head /headvalve or safety /trigger is not pushing trigger pin all the way into trigger valve. Test: Remove trigger to expose trigger valve pin. Remove nails. Place nose of gun against thick rubber mat or coiled rubber hose to absorb blow of driver. Very quickly and deliberately press trigger pin all the way in. If gun fires, safety foo or trigger is not pushing trigger pin all the way in. Make adjustments or replace worn parts. If gun still does not fire, remove head and pull out headvalve. Apply lots of silicone paste lube on the orings and the surface of the head where orings make contact. Reinstall head and test as above. If the gun fires then orings were leaking. Replace orings and sand any scratches on body of cap with very fine sand paper. Parts are at www.toolpartsdirect.com Good luck
Mar 06, 2011 | Stanley Factory Reconditioned Bostitch...
In use for 1 hour and did not want to continue working just stopped.
You posted under spray gun.
I don't know if you are taking about the gun stopping or the spray rig stopping
The gun stopping:
We used airless spray guns for years.
Maybe your tip is clogged.
With our guns we reversed the tip, and could shoot the clog out.
The spray rig stopping:
Add a comment with more specific information about the type equipment you are using.
What material you are spraying.
What settings you have on the rig that can be adjusted.
How old the equipment is, if it's been cleaned well in the past.
Maybe GFCI tripped if you're outdoors.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 10, 2011 | Air Tools & Compressors
Saftey tips fusing a gluegun
* Never leave the gun unattended if it's plugged in. * Don't forget to unplug the gun when finished.
Aug 27, 2008 | Craftsman Bookcase with Five Shelves Prima...
Heat Guns Safety tips
Although safer than using a naked-flame blowlamp, care is still required when using a heat gun. Specific point are: * Because of the power of these tools (up to 2000W), when an extension lead is necessary, only use a lead rated at 10 amp or greater and always completely unwind the lead. * Never obstruct or cover the air inlet grills. If the air flow is reduced the heat gun will overheat and possible catch fire. * Never operate the heat gun with the outlet nozzle hard up against a surface, this will reduce the air and can have the same effect as obstructing the air inlet grills, * Do not use a heat gun near inflammable materials. * Always switch the tool off before putting it down on any surface. * Allow the tool to cool before storing it. * Do not place the nozzle next to anything whilst it is hot. * Never touch the hot metal nozzle with clothing or skin. * Do not use for stripping lead-based paints. * Do not allow any paint to stick to the nozzle - and if some paint does stick, allow the gun to cool down and remove the paint. * Do not look down the nozzle while the gun is turned on. * Do not insert anything down the nozzle with the gun.
Aug 27, 2008 | Master Heaters 200-300DEG 120V MASTER HEAT...
Nail Guns Safety problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Aug 27, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Tradesman 8480K 38Inch to 114Inch 2in1 StaplerBrad Nailer with 5000 Logo
324 people viewed this question
Top Tradesman Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Tradesman Air Tool and Compressor Expert? Answer questions, earn points and help others
