Question about Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset
Bluetooth code I need code for a samsung wep210
  • Samsung Master
  • 2,794 Answers
Usually with headsets code 0000 works by default.
Posted on Aug 05, 2008
Pleez give me codo tu bluetooth wep210 device codo.pleez send my whit [email protected]
Posted on Oct 20, 2008
SOURCE:
Samsung WEP210 work on PS3
yes they do work on ps3.......read your manuall for both items and the solutions are there
Feb 17, 2011 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
I m unable to pair my wep210 headset with my samsung omnia i900 mobile
the wep210 multifunction button needs to be pressed till blue light flashes then stops on blue light continuious this is when you ask your phone to find bluetooth devices it will pick it up
Jan 28, 2010 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
SAMSUNG MOBILE CANT LOCATE THIS HANDSET
I have bluetooth samsung 210 and I just bought it todaty , ,my mobile does nit see it
Jan 06, 2010 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
SAMSUNG BLUETOOTH WEP210 NEED TO KNOW HOW TO PAIR TO PHONE
Your manual can be found here... it should walk you through the connection process fairly easily.
Mar 23, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
J can't use the bluetooth headset wep210
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Searching for the headset on the Blackberry
4) The Blackberry should search for any available Bluetooth devices and display what was found
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Wireless headset pairing
With the Samsung WEP210 this is a common problem (which is actually just a user error)
This is what you do:
1. Of coarse make sure the headset is charged
2. Make sure the bluetooth headset if OFF
3. PRESS and HOLD the top/middle (on/off) button until the light stays on (it will blink then should stay on continuously). That means it is now in pairing mode.
4. Tell you phone to search for bluetooth devices.
5. It should find the headset, and by default type "0000" to pair your new headset**
**You can use whatever pin code you like......but I would recommend the default which is four zeros.
Jun 05, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Bluetooth headset
The reason is because the headset onlys pairs once
Nov 09, 2007 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset Logo
116 people viewed this question
Top Samsung Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
