I bought a new Defy Daw 365 washing machine today where do i through in the washing powder and where do i through in the stasoft? (Bought it second hand so there is no manual)
  • 291 Answers
SOURCE: defy automaid instruction manual how to use
click the link below for defy automaid manuals and instructions guide:
http://www.defy.co.za/images/Manuals/BEKO_BOOK.pdf
thanks and plse do not forget to accept the solution.
Posted on Apr 03, 2009
barkencoa
  • 3463 Answers
SOURCE: where ecxactly do you put washing powder and stasoft
Washing powder should go in the right hand side compartment, if it is not going down, then check that water is coming into washer.
Conditioner should go in the smallest of the compartments.
Please rate my solution.
Thanks.
Posted on Jul 15, 2009
SOURCE: I have a 365 daw washing. I cleaned out the rubber
This ball is a non return device to stop the dirty water in the sump of the machine from mixing with the clean water of the rest of the wash.It should be a tight fit into the rubber lip inside the Sump hose.The ball now stuck in the drum may already be damaged if it stopped the drum and snapped the belt.The best thing to do if you suspect the ball is damaged is to cut it out and if you can get a replacement from your supplier all the good.If not the machine can run without it until you get a new one.
Hope this helped.
Posted on Jun 08, 2010
Testimonial: "I did manage to get hold of a tech at defy who suggested the same but also suggested the ball had little or no use and at the same time mentioned it contributed to the majority of faults in the machines that were sent in for repair. thank you for your help. I will definately use this service again."
SOURCE: WIRING DIAGRAM FOR A FRONT LOADER WASHING MACHINE
Diagram of internal wiring of ariston AV41washing machine
Posted on Mar 20, 2011
  • 6277 Answers
SOURCE: defy daw 366 washing machine
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 03, 2011
My Defy DAW 365 washing machine goes through the whole washing cycle but it just won't spin. It does drain between the washing cycles.
If the poly-vee drive belt in your washing machine has snapped, the motor will no longer be able to turn the drum. The drive belt is an important component of any washing machine as it drives the motion of the unit where the clothes are washed and spun. If your washing machine is making a loud noise or no longer spins, then the belt is probably worn or damaged.
Oct 23, 2015 | Washing Machines
Our defy automaid 600 daw 322, will wash, but will not spin or rinse
My Defy Automaid 600 spin and drain without washing but only drain and do not spin with washing in (i have put only 1 t-shirt in - and still don't spin)
Jan 23, 2011 | Washing Machines
Where ecxactly do you put washing powder and stasoft
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Defy automaid instruction manual how to use
Apr 03, 2009 | Washing Machines
go to macspares.co.za
They have couple of diagrams
Aug 13, 2008 | Washing Machines
Washing Machines Logo
354 people viewed this question
Top Washing Machines Experts
