Question about Sony PSP-3000 Black Console
When i put the memory card of other psp 3k my psp din't open anymore.... then i get my memory card and make all the files as the same as the other memory card and then my psp is not yet opening what should i do?
    Problem Solver:
  • 14 Answers
You should format the memory stick
Posted on May 05, 2011
I have connected my psp to pc through data transfer usb cable, when i connect it my computer recongize the psp as a storage hardware but i cannot see the components of the psp when i open it. and wen i...
The only thing that the psp allows you to see when you plug it in is the contents of the memory card. To be able to view videos and music on the psp the mp3/mp4 files must be put in the /MUSIC/ or /VIDEO/ folders (without the / 's ) on the root of the memory card, otherwise the psp cannot see the files.
Mar 21, 2011 | Sony PlayStation Portable (PSP) Console
I have many games but when i open the memory stick there are no games..i eject the card then i put it back, but there's no games at all : (
If it is CFW make sure the ISO/CSO files are in X:/ISO folder and .pbp files in X:/PSP/GAME folder. Another tip backup all your saves/ games data etc from the memory stick. Then on the psp go to System>Format Memory Stick it will delete everything on your psp and make all the file errors be corrected.
Feb 23, 2011 | Sony PlayStation Portable (PSP) Slim...
How to put music on a psp
There are two ways to go about this:
Hook your psp up via USB or take the Memory stick out and use a card read to being up the contents on your computer.
Look inside the contents and you should see several folders. Look for one named "music" and open it. Drop all mp3 files into the folder and be sure to disconnect the memory stick via windows on bottom right hand corner in windows.
turn on your PSP and in the menus go to the music area. Go down to memory card and open it. It should list all the files you dropped.
Let me know if you have any trouble and I hope I helped!!
Apr 27, 2010 | Sony PlayStation Portable (PSP) Console
My psp memory card dont let me put stuff in
you may have to format the card. Also make sure your card is not placed in the lock position.
    How to Fix a PSP Memory Stick
  1. Step 1 Upgrade your PSP's Firmware (its operating system) before doing anything else. Firmware 5.0 solves many software problems that are encountered with older memory sticks. You can upgrade it by simply connecting your PSP to any wireless connection through its WiFi. Once a connection is established, the PSP will update itself automatically.
  2. Step 2 Check to see that your memory stick's plastic tongs, the small sticks that separate each connection, are straight. If one is bent, your PSP will not recognize the stick.
  3. Step 3 Remove your memory stick if it still does not work. Insert it into a PC with a memory stick slot. You will most likely be able to see all of your saved files. If so, continue to the next step. If you still cannot see your files, then your memory stick is defective, and it is not the PSP's fault.
  4. Step 4 Copy your files from the memory stick to the hard drive.
  5. Step 5 Format your memory stick using the "Format Disk" option in Windows. Open Windows Explorer, and find your memory stick listed in the "Drives" section. Right-click on the memory stick, and click "Format." Follow the on-screen instructions in the windows that pop up.
  6. Step 6 Insert your memory stick into your PSP. It should recognize the disk now. However, you now need to format the memory disk again with the PSP.
  7. Step 7 Go the PSP main menu, and select "Settings." Then select "Format Memory Disk."
  8. Step 8 Put your memory stick back in your PC, and return the files you removed earlier. When you reinsert the stick into your PSP, it should now see all the files.
Mar 25, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
How to put music on psp?
You need a memory card for your psp, as well as a usb cable....plug the usb into your pc and go to system settings in the psp and turn on usb mode (your computer should recognise the psp as an external drive in the MY COMPUTER window) open the drive. Open the file called PSP and look for a file called MUSIC, open it then copy your music files to this folder......If you do not see a psp file on the memory stick duo just save a game to it from the psp.....this will create the folders you need, then repeat my instructional...Good Luck
Oct 02, 2009 | Video Game Consoles & Games
How do i download onto my psp?
You have format your memory stick, if you did that, skip step 1
1. go to settings-system-format memory stick, this create all folders for you
2. setup your psp to go with your wifi, read the instructions that came with the psp
3. go on the internet browser
4. download a file, it will autochoose which folder to put it in
Oct 01, 2009 | Sony PlayStation Portable (PSP) Console
I need to transfer memory card memory to a nother memory card
this is how u tranfer ur save games. got to save data press x than choose ur save data that u want to copy press tiangle press copy than it will ask u to take it out andput the other memory than press ok and that how u tranfer ur save data to another memory card. if u want to move ur games hook it up to ur computer and transfer ur games to ur computer than to the other psp
Jul 02, 2009 | Sony PlayStation Portable (PSP) Console
PSP not detecting files on a 4gb memory stick PRO Duo
There are certain folders that the PSP puts on the stick when it formats it. Format the new stick on the PSP first. Then, you can transfer you files to it.
Jun 28, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
PSP not reading Memeory Stick.
If it is not a psp memory stick,or a compatible psp memory stick,IT will not work.Most memory sticks are not compatible with the psp.
Please take time to rate this fixya
May 12, 2009 | Sony PlayStation Portable (PSP) Console
I want to put music, Movies, and videos on the PSP and dont know how. I want to put my things in my iTunes on the PSP. Can I do that and if so how?
I am not sure how to put them on from iTunes. But to put things on the PSP you need a memory card and either a USB cord to connect the PSP to the USB port in your computer or a SD card reader in your computer. After you have done either of those, you have to plug in either the PSP (with the memory card inserted in the PSP) or the memory card in SD card reader. Once you have done this, a screen should pop up on your computer, asking you how to open the files on the memory card or PSP. Select the one where the picture is a folder (should say browse) and open up the memory card folder. Open up the folder in your computer with the desired files. Highlight the files, right-click on the mouse and select Copy. Then go back to the memory card folder and right click on an open spot and select Paste. This should copy the files over, but, even though they copy over, that does not mean you can acess them through the PSP. That I know of, Microsoft Word files cannot be acessed through the PSP. That seems to be one of the only files unable to be used with the PSP.
Apr 30, 2009 | Sony PSP-3000 Silver Console
Sony PSP-3000 Black Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
