Question about Video Game Consoles & Games
My psp has the wrong memory card and its stuck
Find the right one and put it in
Posted on Aug 05, 2008
SOURCE:
When i save games on my psp memory card, it says "datat corrupted", so i got a new memory card and SAME PROBLEM! i tried reformatting both cards, but no luck! please help!
To be able to play games from the memory stick, your PSP must be hacked first. It's a complicated process.
There's nothing wrong with your memory sticks.
Aug 18, 2010 | Sony PlayStation Portable (PSP) Console
Memory stik problem
Have you tried another memory stick? Or have you tried this stick in another PSP? This will tell you whether the stick is faulty or there is something wrong with your PSP.
If the stick is faulty then buy another, otherwise take the PSP to a repair centre.
Apr 15, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
I dropped my psp and lost all data.now my psp wont read my memory stick but the pc does.whats wrong with my psp and how can i fix it? tnx..
Its the psp memory card reader thats broken...have you tried another memory card in the slot? i dont think you can fix it by urself..
Apr 01, 2010 | Sony PlayStation Portable (PSP) Console
PSP unable to detect games after putting in save data
maybe you place it in the wrong folder..or memory card is busted
Feb 23, 2010 | Sony PlayStation Portable (PSP) Console
My psp wont play the game
well if ur umd reader is damaged u may be stuck but if ur memory card stills works and plays music and such try modding it with this site
http://forums.afterdawn.com/thread_view.cfm/688507
Jun 18, 2009 | Sony PlayStation Portable (PSP) Console
My psp says that the memory stick is not in but the memory stick light says it is and i cant use the memory stick
Try formatting the Memory Stick. If it doesn't work, there is probably something wrong with either your psp or the Memory Stick.
May 28, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Memory card, not right one and stuck!
The PlayStation Portable system is only compatible with "Memory Stick Duo" and "Memory Stick PRO Duo" memory cards. You should have read that in the manual, or on the box, or directly on the unit.
Inserting by force any other type of memory card (including "Memory Stick PRO" that are not Duo) will break your PSP. There are dozens of types of memory cards on the market. They don't have the same shape and size, and they don't work the same way.
Trying to push another type of memory card in your PSP is acting like a kindergarten child who desperately tries to push a cube in a hole that is shaped like a circle.
Jan 03, 2009 | Sony PlayStation Portable (PSP) Console
PSP SanDisk Memory Card Duo corruption
The computer must have been writing to the card when you disconnected, and now it is damaged. You'll have to either purchase memory stick data recovery software or pay for an online data recovery system. I tried to find free software for this, but was unable to. This is the cheapest I found: http://www.datadoctor.in/data-recovery-software/memory-stick-data-recovery-software.html If that doesn't work for you, I think you're out of luck with this one.
Sep 14, 2007 | SanDisk Memory Media
Open Questions:
Just purchased a TTX Tech wireless PS3 controller that comes with a USB key fob that connects to one of the front USB ports of my PS3 console. I have successfully synced it to my PS3 only issue I'm having is how drastically different the configuration is from the usual sixaxis controllers. I noticed between the 2 controllers there are 2 clear differences amongst them. 1 being the trigger buttons are not the same and that the circular circumference for the analog sticks are alittle bit different in size. Basically comparing the size of a 25cent coin to a 5cent coin. I'm assuming because of the analog having less of a left to right and or a up and down travelling distance due to the difference of having a smaller analog circle that it could very well change the sensitivity aspects in the game of choice (COD Black ops 2) but I mean the difference between the two controllers is beyond noticeable I've experimented with lowering the sensitivity level from what was set when using the sixaxis controller compared to when using the TTX Tech controller. For example using the sixaxis I'm set to 13 for my sensitivity but when switching to the TTX Tech to become even close to having the same feel and view while using it in comparison to the sixaxis i have had to lower my sensitivity level to an 11 or a 10 instead of the 13 and yet it still is quite noticeably different from my sixaxis controller. Also I've found that the right analog for the TTX Tech is extremely sensitive gently applying upward downward and also side to side pressure on the analog causes a significantly noticeable jump or jolt that seems to never differ in speed regardless as to what has been set for the sensitivity level in game settings. In a nut shell basically I'm asking if anyone else has noticed these things I'm experiencing and if there may be a configuration manual or program that could some how configure the TTX Tech controller to act more as if it were a sixaxis controller in the aspects of the analog sensitivities and responding timing. Yes of course a new controller with a different shape and or feel will make for a "getting used to it" experience which does generally occur after a time period of using said controller more and more often. I am more or less meaning whether or not the smoothness and or the rythem you would have with one controller be more similar with one another. If anyone is a gamer and has gone from using a normal typical original PS3 controller and unfortunately having it be no longer able to be used to play games and switching to the TTX Tech controller immediately afterwards I'm sure will know exactly what I am trying to explain. Appreciate any insight and or knowledge towards my inquiry. Thank you kindly for the assistance and of course take it easy or take it any way you can get it :)
Oct 19, 2019 | The Video Game Consoles & Games
Video Game Consoles & Games Logo
20 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
