Question about Saeco Royal Cappuccino Espresso Machine
I have a Saeco Royal Coffee Bar that will intermittently fail to dispense espresso. It will grind the coffee but instead of dispensing the coffee, it dumps the (dry) coffee into the dreg drawer and resets - goes back to "please select product" screen. I can hear a gurgling sound when it fails to dispense coffee. I've got it running from a direct water source that comes off a reverse osmosis water system and I just descaled the unit to try to fix it. I've also switched back to using water from the tank with the same result. Thanks!
  • 1,089 Answers
Hi
Its not the water. More than likley its the lever on the right side of the machine at the top middle of the door. Its pushed all the way to the back or positive. Move it 1 mark towards the front of the machine and try again. If you put too much coffee in the brew unit, it can't compress it and kicks it out. It could also be your grind is too coarse. It should look like auto drip coffee.
Posted on Apr 03, 2011
I am getting no coffee to dispense out of the coffee output. It gives me no error message. It grinds the coffee and acts like it is dispensing the coffee. But nothing comes out. My coffee grounds...
firs of all try to make preground coffee ,but without coffee powder if the water come out then you have to change the pump. If no water come out -your machine needs to be descaling
Oct 18, 2013 | Saeco Royal Professional Espresso Machine
What is coffee dispenser, i have a saeco royal coffee machine, its screen keeps telling me "COFFEE DISPENSER BLOCKED", can you share me your information, a picture will be most helpful, thanks a...
The dispenser is the brew unit in the back of the machine above the drain tray, open door and remove the black unit within and check the screen above the red o-ring.
Jul 17, 2011 | Saeco Royal Digital Plus Coffee...
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco digital plus not grinding
Sounds like your grinder is clogged and do you hear a clack, clack? That would be the solenoid opening the doser box.
Oct 13, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Royal Digital Not brewing Coffee
If you try to make a cup of coffee, hold the button to see if there will comes some coffee, it can be the memory that have loose the settings. If so you have to program the machine again.
Best regards
/Mirran
After descaling the Saeco Royal Professional, all features remain functional except for the coffee dispensing. It will grind and the brew unit will go through its usual cycle, but no coffee will get...
The first descaling cycle likey dislodged some calcium which then found its way into a valve or water line. A second descaling cycle resolved the problem.
Oct 06, 2008 | Saeco Royal Professional Espresso Machine
Saece Talea - Dispensing failed
Take out the brewing unit and clean it in hot water.
/Mirran
Aug 30, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Royal Digital won't brew coffee
normaly descale it gonna affect the water . in the waste cointainer do you have coffee that goes there i tink the brewer is the problem the pvc thing inside the machine that can be remove .remove check it visualy something blocking it cheers
Jan 11, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Cappuccino Espresso Machine Logo
326 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
