Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Need to re format and erase data currently on cruzer
  • 39 Answers
Open "My Computer" simply right click on the cruzer and click format, it will give you some options, but once you select format the device will format. Please repost if you dont see it in "My Computer"
thanks
ZXR
Posted on Aug 05, 2008
I have micro cruzer 4GB USB and it givim me a error in IOCTL call how can i fix this
Usually this means the system can't detect the structure of the filesystem. You may have to format the drive.
In Windows, you can right-click the drive and choose "Format..."
In OSX go to Disk Utility, select the drive on the left, and click "Erase"
Mar 06, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Hi, have a cruzer titanium 8gb. Had it for over a year and been OK. Now just sits in the USB port & flashes about 8 times, pauses and the just repeats the flashing. Tried to open from 'my computer'...
You have lost all the data as it is. Unfortunately, you may have pulled the cruzer from the usb port by hand without using the EJECT Format. You should always EJECT a USB Dongle first to avoid STATIC Charge. Static erases the formatted device and washes away all data. In the Winter this condition is more active than when humidity is high. In many cases, the drive can not be formatted again.
Feb 06, 2018 | SanDisk 1GB Cruzer Titanium USB Flash...
Dear Team Today when i try to use my CRUZER U3 (8GB) I GET MESSAGE "you have reached the maximum number of failed password...
Each U3 smart drive comes with a pre-defined number of login attempts. When you have only 3 attempts remaining, you will receive a warning message to prevent losing your data unnecessarily.
SanDisk does not have any method to bypass the password security feature on Cruzer U3 flash drives. SanDisk has not built in any back door or password reset methods. If the password feature is enabled and you exceed the number of incorrect password attempts, the drive will lock. Once the drive is locked there is no way to unlock the drive or gain access to the data stored on the device. You can only select the format feature, which will perform a secure erase (drive wipe) and data recovery will NOT be possible. U3 Cruzer flash drives which are password protected use 128bit AES encryption for data security
http://kb.sandisk.com/app/answers/detail/a_id/191
Sep 23, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
My SanDisk Cruzer USB flash drive had problams with the U3 systam, So i uninstalled it by using the "renuve u3 luntch pad.exe." then I selected the "format adn keep my data" option, but the systam find a...
You have ruined the file integrity of the flash drive, There is a very slim chance that you will recover any data off of the drive. Most flash drives only have a read/write of about 8,000 to 9,000 times so depending on how much you actually used the drive, it is possible it finally went bad. To format the drive try going to my computer and right clicking on your cruzer drive letter and click format. "ALL DATA WILL BE ERASED WITH THIS OPTION"
Jun 21, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to remove write protection from Sandisk micro cruzer thumbdrive?
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format thumbdrive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Oct 07, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My cruzer micro 4gb flash needs compression but I get the message drive not formatted. How can I recover the data without formatting the flash drive since formatting will erase all of my data?
You can run a data recovery app on the drive and attempt to pull off any data still accessible. I recommend the GetDataBack Data Recovery apps from http://www.runtime.org . Get the one for the file system on your thumb drive and give it a try. These apps have recovered data from "dead" drives for me more times than I can count.
Aug 24, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 8gb cruzer not working
Bring the Sandisk cruzer to any computer store that offers data recovery and back up or data retrieval. We called them the Data Recovery Center.
Most of them has a software they use in cracking passwords and other secured programs. From their computer, they could actually back up your important files saved in your Sandisk. Then you may now reformat your device.
Hope this helps and have a great day!
Jul 25, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
How do I erase the data on my Sandisk Cruzer Micro
I had this problem before on my cruzer. The quick fix is to just plug it into a computer. Once that is done go to " My Computer" in the start menu and click on the USB drive that it is pluged into. Go to properties. There should be an option for you to format your disk. Click yes to format the disk. After that is done it should show that your Cruzer is emty with the full amount of free space available.
Feb 17, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Erase Data?
If you goto My computer and click on the Appropriate Letter for your flash Drive you can then Right click on it and go to "FORMAT" and then from there click Ok or Next. This will erase all data on the flash drive. You can also physically open the drive in my computer and select everything by pressing CTRL and A at the same time and then pressing the DELETE key on your keyboard, either one works fine and will delete the data off of a flash drive. Hope my answer gets you closer to a solution. Please Help rate me if I helped you out or not I am new but a very good tech.
Aug 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
159 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
