This is a Cabrio I take it. If you can tilt the washer back against the wall and look up from the bottom. On the
left hand side of the cabinet there should be a tech sheet. That is where you will find that code listed. Kinda
hard to get to, but you don't want to get to it the other way. It can be a pain if you've never seen it done.
I believe however this has something to do with the hot water. Make sure your washer is getting hot water.
If it is try unplugging the unit for awhile then try it again. If it persists the sensor is bad or the board is bad.
And with Cabrios chances are good it's the board...hope this helps.
