Question about Sony MV-7101DS Car DVD Player
I need new cables for the to the connection bax xa-115
Bajaj caliber 115 no sparking how to fix
Hi, Muger and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.xbhp.com/talkies/help-me/16176-caliber-115-mileage-problems.html
How to diagnose no spark situation on motorcycle
http://arbazdailynews.com/Id-2507380/bajaj-caliber-115-service-manual.pdf
Shop At Bajaj CALIBER 115 Bike Parts And Accessories Online Store...
Free Bajaj Motorcycle Service Manuals for download
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 29, 2017 | Bajaj Motorcycles
Why I can not turn my PC RoHs]
I am not sure what country you are in but in the USA it is 115.
Nov 30, 2014 | Pool & Spa
Changed the battery in a scion xa and the alarm keeps going off when the battery is connected back
Scion XA PDF Manuals online Download Links at Scion ...
scionmanuals.com/scion-xa-pdf-manuals-online-download-links/
Here at Scion XA PDF Manuals online Download Links page,intended to offer Scion XA Owners available Electrical ... Scion XA 2004,2005,2006,2007,2008:
How To Replace Scion XA Key Fob Battery 2004 - 2006 ...
? 1:45
www.youtube.com/watch?v=1AWHK_flb9s
Aug 4, 2014 - Uploaded by Keyless Entry Remote Inc
This video will show you how to replace a key fob battery for a 2004 2005 & 2006 Scion XA.
Jan 21, 2013 | 2005 Scion xA
How to install 2006 xA driver side mirror?
just the mirror or the entire housing ???
just mirror
  • remove old mirror (pry out)
  • unscrew from holder
  • screw new mirror into holder
  • press holder back into housing
entire housing
  • open door
  • pry off mirror shield (might need to unscrew) the shield is inside the door which hides the bolts holding the housing
  • unscrew housing
  • remove power cable (if any)
  • plug in cable to new housing (if any)
  • bolt the new housing in place
  • replace shield.
Sep 14, 2010 | 2006 Scion xA
Have tri zone 36k elect. 230/208 we only have 115/230 the connection says line ground natural thats 115, were do I hook the other 115 to get 230.
Hi, I am not quite sure of what kind of set-up you are saying you have when you say it says line ground natural? If you have a 115/230 volt power supply, this should be very easy to tie into. Look at the wiring diagram on the new unit real good and locate the 2- hot wires that should say line one or L-! and L-2. Your 230 volt wires will connect one to each side of those 2 connections, and will have a ground wire that grounds to a metal lug or screw on the unit. Look over the diagram for field wiring connections for high voltage and this will tell you where you need to hook your 230 volt wires and ground to. If this new unit is 208/230 volts, you should have connections like I have said either L-1 or t-1 and L-2 or T-2 that you will tie in your 230 volts to. Just look over the diagram and you will see where the beginning of the 2 hot wires come into the unit. There should be either 2 good sized black hot wires that are for your incoming hot wires to connect to, or they are already connected to the contactor, and you will need to connect yours to the line side of the contactor. I see what you are saying now, that they are only showing you 1- 115 volt connection to the new unit so you will have only 115 volts to run it. You want to know where the other 115 volt conductor hooks up for 230 volts. This is why you need to look at the schematic and wiring diagram that shows both of the 208/230 volt connections on this new unit so you can connect both hot wires to it. I can't pull up a picture of this on the Internet, but it will show you on the schematic on where they connect. This line ground neutral connection sounds as though its not for a hot wire, but for your ground, or if you happen to have a neutral wire that is being used for a ground. Please keep looking for the 2- line in connections as this is what you will need to find and where both 115 volt wires connect. They are your line voltage wires, so they need to connect to the load voltage hot wires at the L-1 and L-2 connections of this unit. This should be fairly laid out for you, but sounds like they have made it difficult? Look for what I have said and the schematic drawing and you will find the connections. Please don't forget to rate me as I know you will be kind. I will be checking back with you as I keep all of your information on file so I can look you back up if I need to. You can contact me by my user name below if you need me also. I wish you the best and follow my instructions and I know you will get it right.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 02, 2010 | LG Heating & Cooling
HOW CAN BE CONNECTED WIRE ON 12 VOLT BATTERY OF SONY XA-CA340?? HOW CAN BE CONNECTED THIS IN 220 VOLT A.C. SUPPLY??
battery has two terminals the red color or + symbol are positive and the black color or - symbol are negative but from the sony xa-ca340 the yellow color of wire and red are both connected.to connect 220v you purchase a power converter the output is 12 volt
Aug 07, 2010 | Car Audio & Video
I have a gateway desktop computer. Recently moved
Before you actually replace the power supply, check some other things first:
1. Wall socket
2. Power strip/surge protector
3. Power cable
4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
5. Make sure that the power cable is not connected to a regular extension cord. Power cable must plug directly into a surge protector that is not daisy-chained to another power strip, surge protector, or normal (household) extension cord. Surge protector must be directly plugged into wall socket.
If none of the above solve the problem, open up the case and ensure that all power connections are secure. Also check ALL other components' connections. Any loose connections can cause problems for you.
If everything is secure and the problem persists, replace the power supply.
Nov 27, 2009 | Office Equipment & Supplies
Monitor XVM-R70, NO SE ENCIENDE NI SE PONE EN MARCHA.
Tengo el mismo problema, lo pudiste solucionar.?, gracias
Mar 15, 2009 | Sony XVM-R70 7 in. Car Monitor
XA HD500 not recognized
visit at yourfreesoftwares.blogspot.com
Feb 11, 2008 | Computers & Internet
Sony MV-7101DS Car DVD Player Logo
50 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
