Question about Garden
I need a srvie manual for a honda f720 i also need two cluch cables and a properset of cotter pins any help gratefully recieved
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Brand new machine unbalanced (really
oh yea sounds like there still in there alright!!!, tip the unit back if possible and give a look underneath, you see2 or 3( depending on model) plastic tubes approx 2in long mounted to the under carriage around the base. They are there for the sole purpose of "catching" the cotter pins after pulling the rip cord. there should be a cotter pin in each of the tubes. if you see any empty ones look directly above it and youll find the pin, you may have to manually grab the cotter pin to release it withe a set of needle nose pliers or something but the definitely need to be removed.
Posted on Mar 10, 2008
  • 122 Answers
SOURCE: Im installing the drivers side window regulator.
I normally use needle nose pliers or a flat blade screwdriver to help push them in, you also might have to adjust the window up and down to make sure they can slide in freely, good luck
Posted on Sep 24, 2009
rycgl
  • 1545 Answers
SOURCE: I need a cotter pin
You can get a cotter pin at any hardware, auto parts or big box store...just look in the hardware section.
Posted on Dec 12, 2010
TheMobilian
  • 8220 Answers
SOURCE: Cotter pin removal
That is called a C clip. use a small flat blade screw driver to back it off the shaft in one of the dimples on either side of the center.
Posted on May 08, 2013
Shift cable won't stay attached to transmission
As far as the shifter cable not staying attached to the ******, (AT), My solution was to shave the plastic end thinner so it will go further on the shifter rod. This will allow room for a washer and cotter pin to be attached to the rod. (holding the shifter cable in place. It's easier to remove the shifter arm as you will need to drill a small hole for the cotter pin. This is the cheapest solution that works. The shifter cable is over $40 and a headache to install. Hope this helps.
Aug 12, 2011 | 1994 Pontiac Firebird
How do you replace burners on Jenn-air 720-0337
First, remove the grill grates, then the flame tamers to access the burners. As you face the grill, carefully lift up the end of the burner farthest from you (It may or may not have a cotter pin holding it in. If it does, remove the cotter pin with a pair of needle nose pliers). As you lift it up, it should pull away from the burner orifice (inside the control panel). And that's all there is to it.To reinstall the burner, do everything in reverse. But, there is no need to replace the cotter pin. It was there for shipping purposes.
Hope this helped you. Please let me know. Happy Grilling!!
Jun 12, 2011 | Jenn-Air Grilling
How do you remove the burners so I can clean out the gas ports?
The fairly simple to remove. Turn OFF the gas, Remove the cooking grates and flame deflectors to access the burners. On the end of the burner, farthest from you, underneath the burner there is a Cotter Pin. Remove it with a screwdriver of needle nose pliers. Once the pin is removed, lift that burner end up and away from you and the burner will clear the grill.
May 01, 2011 | Char-Broil 463254405 All-in-One Grill /...
I have an Allis -Chalmers 416 tractor with mower deck I need to know how to install the deck (I have lost the manual) It is an older model serial number 26002395 Can you help
There are 2 holes at the front on the frame you need to put a pin and cotter pin through each side to hold the front of the mower. Then there will be a hangin piece of straight metal about 2-3 inches long with a hole in it that you need to hook up the chain to also with a pin with a hole in it and a cotter pin. This will allow you to raise and lower the deck with the electric lift. If you need pics let me know i'd be happy to help.That's all there is to it besides putting the belt on.
Jan 21, 2011 | RTO Allis Chalmers Tractor 7010, 7020,...
I'm trying to replace a clutch cable in a '90 subbie legacy. The manual says nothing about removing the cable from the metal bracket that holds it inside the drivers compartment well.. it only says to...
It is not a cotter pin. It us a pin with a clip. Get a screwdriver or blade behind the clip to push it off. The clip is #16 in the pic. Make sure to use a new clip to install the cable.
Aug 18, 2017 | 1990 Subaru Legacy
Do i need any special tools to change hub bearing on a 95 honda passport
No special tools needed, this Honda has the old type inner and outer wheel bearing's, remove cotter pin, spindle nut slide rotor out, remove wheel bearing, repack new bearing with grease and don't forget to replace grease seal's, install new part's adjust spindle nut and install cotter pin.Good luck,hope this was very helpful.
May 13, 2010 | 1995 Honda Passport
How do you replace a burner on a ducane gas grill
Hello : Here are two solutions , just look which one of them is the most helpful .
  1. Turn off the gas supply and bleed the lines leading to the grill. Remove the gas tank if possible.
  2. Open the grill and remove the grates. In some cases you will need to
    detach the hoses from under the grill using simple hand tools. Other grills may have simple "float in" style of burner. These styles look as if the tubes from the burner leading to the gas supply lines simply "float" into each other. Look for clamps of holders that may need to be removed.
  3. Remove the damaged burner and remove from grill. Take a moment to inspect the other burners and any other hoses in case you need to replace more than one piece. Place the burner in a plastic bag and take it to the home store so you can get the exact parts you need. This removes all guess work.
  4. Before replacing the burner/burners etc, take a moment to clean any material, grease etc from the bottom of the grill. Replace the burners and hoses as needed. Check the connections before reconnecting the gas supply. Turn the gas on and start to flow of gas to the burners without lighting the grill. Make sure the flow is working. Be sure to turn the gas off, let the fuel dissipate before lighting.
  5. With everything working, fire up the grill and enjoy.
Or try these help here :
  1. Turn off the gas supply valve on the tank. Remove the fuel line from the fuel tank by turning the connection nut counter-clockwise with your hand.
  2. Open the Char-Broil gas grill and remove the main cooking grate. You do not need to remove the upper warming racks to change the burners.
  3. Remove the lava rocks from the grill and pull the rock grate out. Unhook the flame spreader from each end where the spreader attaches to the inside body of the grill. The spreader is the angled piece that sits over the burner.
  4. Locate the cotter pin that secures the front of the burner to the grill body. Remove the cotter pin with a pair of needle nose pliers. Lift the burner up and pull the burner venturi tubes out of the gas valve.
  5. Set the new burner inside the grill with the venturi tubes inside the gas valve opening. Install the cotter pin to secure the burner to the grill body. Place the flame spreader back inside the grill and hook the ends to the grill body.
  6. Place the rock grate, lava rocks and cooking grate back inside the grill. Reattach the fuel line to the fuel tank.
Here you need Needle nose pliers.
Please report me which one helped the most .
good luck .
and rate if useful please !
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Feb 20, 2010 | Ducane 30400040 Stainless Steel Grill
1991 Honda Accord - Cannot get the axel nut on the wheel to loosen. Is it reverse thread or do I just need more man power?
Did you remove the cotter pin? If so, you will need more manpower. Should not be reverse thread..........lefty loosey, righty tighty!
Jul 16, 2009 | 1991 Honda Accord
Torque specs needed
on a 1999 Honda Accord, the torque for the front axle nut is 181 ft lbs. For the most part, sung it up and then go a bit further. If you are reusing the old axle nut, tighten it until the stake mark on the nut lines up with the notch in the axle (make sure to re-stake it). check out alldata.com/diy for individual vehicle subscriptions which have all the repair info you will ever need. If you had the steering knuckle out, tighten the balljoint nuts on the upper and lower control arms until they are tight and then tighten until the hole lines up to recieve the cotter pin.
Mar 18, 2009 | 1997 Honda Accord
Brand new machine unbalanced (really unbalanced) during spin cycle. When unpacking there are two plastic "rip cords" that are supposed to remove a total of three cotter pins. Only one cotter pin came out...
Mar 10, 2008 | Washing Machines
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
