Question about Logitech MX 700 Mouse
Stopped recharging When placing mouse on charge stand, it no longer charges the batteries. I've replaced the batteries with rechargables that I know are good, but still nothing. Also, the red laser light does not go off when the mouse is placed in the stand, which makes me think the connection is not being recognized. Any suggestions?
    Problem Solver:
  • 6 Answers
Get a new pencil..........use the eraser to clean terminals on mouse and stand/ please be gentle
Posted on Nov 29, 2009
Two things: 1) This mouse and charger does not like rechargeables larger than 1800mAH. The light on the front will(sometimes) go red if you use a higher rated battery than the 1800mAH. You said you replaced the batteries, but might want to check their rating. 2) My mouse gets harder and harder to get a good connection when putting it in the cradle. Might be the contacts are getting dirty. When you put it in the charger, you should see the optical beam (red on the back) go out and the green light on the front turn on. If this doesn't happen, it isn't connected.
You do have the cradle plugged in and the batteries installed the right direction in the mouse? I know it's obvious, but the questions always have to be asked.
Posted on Sep 01, 2008
How do i charge the mouse
Has it got a housing? If not, then you'll need to open it and either recharge (if rechargeable) or replace the batteries.
Feb 14, 2015 | Logitech Cordless Mouse
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
MTG 900 SAYING "CHARGE" AND I'VE BEEN PUTTING
I am assuming you are reading the battery charge correctly. If so you need a new rechargable battery. Special battery so it is a little expensive. Make sure the person knows it is a "rechargable battery" you want. A regular battery will not work properly or recharge.
Nov 02, 2011 | Casio Atomic-Solar MTG900 Watch
Batteries will not recharge on stand. Have used different rechargeable batteries but same result
It could be the metal contacts that's used for recharging the mouse that isn't making a proper connection. The most common cause for this, would be dirt & oil that would build up on the charging contacts over time.
I would try to clean the contacts with a dry tissue paper on both the mouse and the charging stand and see if the mouse will charge properly again.
If that doesn't work, then maybe it's just the recharging circuit inside the mouse that's broken.
Jun 03, 2010 | Logitech Cordless Mouse
When to recharge batter
hi right to be honest both ways are correct, but if your using it every day then its best to put it back on the charger after every use, but the problem with this is that the battery never goes totally flat, so never does a full recharge this reduces the life of the battery by upto 50% so if you are using it regular and need it charged daily then its best to once a month let the battery go totally flat so that it wont even make a sound then do a full recharge.
Doing this will ensure the battery remains at peak performance and make it last longer.
If how ever your only using it say once a week then its best to only charge after the battery has gone flat due to the fact that it would remain on charge longer and cause the battery to over heat reducing the life span of the battery.
But witch ever method you use always let the battery go totally flat once a month then do full recharge this will prolong the life of the battery and ensure it keeps working at full power.
Let me know if you have further questions ok
Jan 18, 2010 | Euro-Pro Shark Cordless Stick Vacuum...
Im having difficulty in charging my mouse -my stand is plugged in -i've cleaned the contacts -i've reset several times and it still doesnt charge
Verify with a tester that the cradle is supplying power. If it is, the mouse rechargeable battery might be gone; if it's one of the models with common NiMh AAAA ("pencil thin") batteries inside, you can even replace them by yourself.
Jan 03, 2010 | Logitech MX1000 Laser Cordless...
Microsoft wireless 5000 laser mouse battery level not working
The battery has long power. But it has to b recharged. place the mouse on the AC charging station to recharge.
Dec 09, 2009 | Microsoft Wireless Laser Mouse 5000
Targus Bluetooth Laser Mouse Rechargeable Battery Trouble
check batterys to make sure there placed in mouse properly.try other usb ports.Batterys may be bad from factory.try some other rechargeables in it.if you have a charger for rechargeable batterys place the batterys in that and see if they charge.if they do then your pc is not charging them correctly/
Jun 11, 2009 | Targus Bluetooth Laser Mouse...
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
Logitech MX 700 Mouse Logo
466 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
